Re: Laber-Ecke 24. September 2010 05:25 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.886 |
Re: Laber-Ecke 24. September 2010 10:29 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 7.505 |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: Laber-Ecke 24. September 2010 13:54 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Laber-Ecke 24. September 2010 14:12 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 833 |
Re: Laber-Ecke 24. September 2010 15:41 |
Re: Laber-Ecke 25. September 2010 09:12 |
Re: Laber-Ecke 28. September 2010 06:22 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 470 |
Re: Laber-Ecke 28. September 2010 09:01 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 3.742 |
Re: Laber-Ecke 28. September 2010 09:21 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 548 |
Re: Laber-Ecke 01. October 2010 02:02 |
Re: Laber-Ecke 01. October 2010 04:04 |
Traumflug
Dort ist der Bug-Tracker ein ganz zentrales Element eines Projekts.
Re: Laber-Ecke 01. October 2010 06:07 |
Re: Laber-Ecke 01. October 2010 06:30 |
Re: Laber-Ecke 01. October 2010 07:48 |
Re: Laber-Ecke 01. October 2010 08:56 |
Re: Laber-Ecke 01. October 2010 09:08 |
Re: Laber-Ecke 01. October 2010 09:29 |
Re: Laber-Ecke 01. October 2010 10:22 |
Re: Laber-Ecke 01. October 2010 10:27 |
Re: Laber-Ecke 01. October 2010 10:32 |
Re: Laber-Ecke 01. October 2010 10:34 |
Re: Laber-Ecke 01. October 2010 10:37 |
Re: Laber-Ecke 01. October 2010 10:39 |
Re: Laber-Ecke 01. October 2010 10:50 |
[16:37] and dont expect rocket science of my new hot end ;p [16:37] its very simple... hehe [16:37] i optimized for production / cost also ;p [16:37] but it works like a charm.. and is very strong and stable [16:37] few more mins [16:37] [www.mendel-parts.com] [16:37] already done.. [16:38] [www.mendel-parts.com] [16:38] final layout [16:38] ill share cad files soon.. 2d cross sections etc [16:38] once in webshop [16:38] and bit more tested [16:38] there is thread inside the peek [16:39] so i can bolt the nut etc.. how do i say this in english [16:39] lock the nut [16:39] "borgen" in dutch ;p; [16:39] the insulator is all peak? [16:40] no.. peek wont work with PLA.. [16:40] white part is PTFE [16:40] and grey is peek [16:40] and its all inthe small details ;p [16:40] thats why i draw everything in 3d... [16:41] ok [16:41] <-- nkumar hat den Server verlassen (Quit: Leaving). [16:41] so there is m6 thread inside the ptfe.. but also in the peek [16:41] so you replaced Adrians holder from metal to peak for one? [16:41] --> genehacker hat den Kanal betreten ([email protected]). [16:41] huh? [16:41] adrian latest looks a bit simular.. [16:41] but way too complicated.. and weak [16:42] ok [16:42] [reprap.org] [16:42] he had a metal piece to lock in the ptfe, u replaced it with peak [16:42] check that.. one [16:42] Hi folks! I'm prolly a bit slow, buti can't get the Mendel BOM to add up, can someone tell me which ballbearings and how many of each i need for a mendel? [16:43] 48x 624ZZ and 2x 608ZZ [16:43] excl extruder... [16:43] that is [16:43] and inc? [16:43] [www.mendel-parts.com] [16:43] depends.. [16:43] adrian or wade's ? [16:43] adrian has 3 extra 624ZZ bearings.. which we include in our bearings kit [16:43] Camiel|G: sorry...but i don't really see anything new here...just a variant on the same old problematic design... [16:43] well its not that new.. true [16:43] but its simple [16:44] adrian uses too much materials [16:44] and larger ones [16:44] i can still use m6 this way [16:44] and he doenst have thread in the peek.. so cant lock the brass part [16:44] works a bit diff.. [16:44] but its true.. its not brand new ;p [16:44] but it works so good.. and you can replace ptfe now without need for rewiring brass [16:44] its much more stable [16:44] stiff i mean [16:44] Adrians seems to be a work in progress [16:45] and no more glue [16:45] thats a major plus [16:45] so the peek and brass parts are combined.. you cant get that loose i mean [16:45] thats the "borging" i meant [16:45] or with force.. but they are locked in each other [16:46] <-- mhensen hat den Kanal verlassen. [16:46] and this still uses m6.. while adrian went bigger now [16:46] --> mhensen hat den Kanal betreten ([email protected]). [16:46] ok, so if i order 155 624ZZ bearings and 10 608ZZ i should be fine building three mendels then? [16:46] get the temp wrong and you can easily ruin it... [16:46] This is probably a stupid question, but what is the notch for in the mendel print bed? [16:46] <-- orzo hat den Server verlassen (Ping timeout: 276 seconds). [16:47] what can you ruin MG_Rick [16:47] ? [16:47] the ptfe [16:47] how.. [16:47] its compressed [16:47] and inside.. i told before.. small details ;p[ [16:47] <-- Scorpia hat den Server verlassen (Ping timeout: 272 seconds). [16:47] i have very sharp edge on brass.. so it cuts in ptfe.. [16:47] diff. to explain [16:47] that is simply not how it works Camiel|G [16:48] what u mean? [16:48] compression does not solve the problem [16:48] sharp threads do not solve the problem [16:48] well because inside brasss is very short now.. short melt zone.. its also smoother to push through [16:48] so less force also.. [16:48] well i can only say.. it works same als old type.. but is much more stable.. [16:49] and is cheap [16:49] however i totally agree this is experiment still
Re: Laber-Ecke 01. October 2010 10:56 |
Re: Laber-Ecke 01. October 2010 10:59 |
Re: Laber-Ecke 01. October 2010 11:02 |
Re: Laber-Ecke 01. October 2010 11:03 |
Re: Laber-Ecke 01. October 2010 11:10 |
