Re: Laber-Ecke 15. February 2011 13:11 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 1.918 |
Re: Laber-Ecke 16. February 2011 02:44 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 7.505 |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: Laber-Ecke 16. February 2011 03:04 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 3.742 |
Re: Laber-Ecke 16. February 2011 03:48 |
Re: Laber-Ecke 16. February 2011 06:53 |
Extruder Build time is 33 hours 17 minutes 48 seconds. Distance extruded is 1999364.6 mm. Distance traveled is 2511847.2 mm. Extruder speed is 30.0 Extruder was extruding 79.6 percent of the time. Extruder was toggled 51990 times. Operating flow rate is 4.7 mm3/s. Feed rate average is 21.0 mm/s, (1257.3 mm/min). Filament Cross section area is 0.2 mm2. Extrusion diameter is 0.5 mm. Extrusion fill density ratio is 0.68 Material Mass extruded is 422.1 grams. Volume extruded is 392.6 cc. The volume extruded is 392.6 cc. (= ca. 5557 cm ) Meta Text has 1063615 lines and a size of 35401.0 KB. Version is 10.12.18
Re: Laber-Ecke 16. February 2011 07:12 |
Re: Laber-Ecke 16. February 2011 15:33 |
Re: Laber-Ecke 16. February 2011 16:35 |
Re: Laber-Ecke 17. February 2011 02:30 |
Re: Laber-Ecke 17. February 2011 03:28 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.874 |
Re: Laber-Ecke 17. February 2011 04:53 |
Re: Laber-Ecke 18. February 2011 06:46 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 161 |
Re: Laber-Ecke 18. February 2011 06:56 |
Re: Laber-Ecke 18. February 2011 07:00 |
Re: Laber-Ecke 18. February 2011 07:30 |
Re: Laber-Ecke 18. February 2011 10:35 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Laber-Ecke 18. February 2011 15:21 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 395 |
Re: Laber-Ecke 19. February 2011 06:08 |
Re: Laber-Ecke 19. February 2011 06:21 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 326 |
Re: Laber-Ecke 19. February 2011 07:25 |
vertex_height=20; dxf_linear_extrude(file = "vertex-body-fixed-qcad.dxf",height=vertex_height,center=true);
Re: Laber-Ecke 19. February 2011 08:05 |
Re: Laber-Ecke 19. February 2011 08:47 |
Re: Laber-Ecke 20. February 2011 06:13 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 470 |
Re: Laber-Ecke 22. February 2011 13:53 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 258 |
Re: Laber-Ecke 22. February 2011 14:19 |
Re: Laber-Ecke 22. February 2011 14:39 |
Re: Laber-Ecke 22. February 2011 14:58 |
Re: Laber-Ecke 23. February 2011 06:28 |
Trotz der bestechenden Idee - allzu viele Anwender gibt es nicht. In Berlin beispielsweise, [...]
Re: Laber-Ecke 23. February 2011 06:34 |
Re: Laber-Ecke 23. February 2011 07:59 |
