Prusa i3 endstop-definition 18. November 2014 13:04 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1 |
// coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Disable max endstops for compatibility with endstop checking routine #if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS) #define DISABLE_MAX_ENDSTOPS #endif // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops false // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 190 #define X_MIN_POS 0 #define Y_MAX_POS 163.3 #define Y_MIN_POS 0 #define Z_MAX_POS 180 #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
Re: Prusa i3 endstop-definition 18. November 2014 13:50 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 344 |
Re: Prusa i3 endstop-definition 19. November 2014 03:39 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 513 |
Re: Prusa i3 endstop-definition 19. November 2014 08:58 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 518 |
Re: Prusa i3 endstop-definition 19. November 2014 12:19 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 107 |
Re: Prusa i3 endstop-definition 19. November 2014 13:17 |
RFZ
wo soll denn dein Nullpunkt liegen? deine Y-Achse ist falsch herum wenn ich das richtig sehe...
Normal ist der Nullpunkt bei dir vorne links. Das heisst das Hotend bewegt sich nach rechts in positive Richtung, dein Endstop dort ist also ein X_MAX und fürs Homing musst du positiv (1) fahren.
Deine Y-Achse sollte nach hinten gehen, das Bett fährt also für positive Y-Richtung nach vorne, dein Endstop dort ist also Y_MIN und du solltest fürs Homing negativ fahren (-1).
Dein Z geht nach Oben und du hast da einen Z_MIN Endstop, fürs Homen also negativ fahren.
Dein Y ist also irgendwie falsch konfiguriert...
Re: Prusa i3 endstop-definition 19. November 2014 15:16 |
