Newbie mit seinem Prusa i2 ![]() 12. January 2015 15:59 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 36 |
#define NUM_EXTRUDER 1 #define MOTHERBOARD 402 #include "pins.h" #define FAN_BOARD_PIN ORIG_FAN2_PIN #define MIXING_EXTRUDER 0 #define DRIVE_SYSTEM 0 #define XAXIS_STEPS_PER_MM 320.4578 //320 #define YAXIS_STEPS_PER_MM 320.6413 //320 #define ZAXIS_STEPS_PER_MM 10222.9617 //10240 #define EXTRUDER_FAN_COOL_TEMP 40 #define PDM_FOR_EXTRUDER 1 #define PDM_FOR_COOLER 1 #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20 #define DECOUPLING_TEST_MIN_TEMP_RISE 1 #define RETRACT_ON_PAUSE 2 #define PAUSE_START_COMMANDS "" #define PAUSE_END_COMMANDS "" #define EXT0_X_OFFSET 0 #define EXT0_Y_OFFSET 0 #define EXT0_STEPS_PER_MM 3707 //3040 #define EXT0_TEMPSENSOR_TYPE 1 #define EXT0_TEMPSENSOR_PIN TEMP_0_PIN #define EXT0_HEATER_PIN HEATER_0_PIN #define EXT0_STEP_PIN ORIG_E0_STEP_PIN #define EXT0_DIR_PIN ORIG_E0_DIR_PIN #define EXT0_INVERSE 0 #define EXT0_ENABLE_PIN E0_ENABLE_PIN #define EXT0_ENABLE_ON 0 #define EXT0_MAX_FEEDRATE 50 #define EXT0_MAX_START_FEEDRATE 10 #define EXT0_MAX_ACCELERATION 400 #define EXT0_HEAT_MANAGER 3 #define EXT0_WATCHPERIOD 1 #define EXT0_PID_INTEGRAL_DRIVE_MAX 230 #define EXT0_PID_INTEGRAL_DRIVE_MIN 40 #define EXT0_PID_PGAIN_OR_DEAD_TIME 7 #define EXT0_PID_I 2 #define EXT0_PID_D 40 #define EXT0_PID_MAX 255 #define EXT0_ADVANCE_K 0 #define EXT0_ADVANCE_L 0 #define EXT0_ADVANCE_BACKLASH_STEPS 0 #define EXT0_WAIT_RETRACT_TEMP 150 #define EXT0_WAIT_RETRACT_UNITS 0 #define EXT0_SELECT_COMMANDS "" #define EXT0_DESELECT_COMMANDS "" #define EXT0_EXTRUDER_COOLER_PIN -1 #define EXT0_EXTRUDER_COOLER_SPEED 255 #define EXT0_DECOUPLE_TEST_PERIOD 12000 #define RETRACT_DURING_HEATUP true #define PID_CONTROL_RANGE 20 #define SKIP_M109_IF_WITHIN 2 #define SCALE_PID_TO_MAX 1 #define TEMP_HYSTERESIS 0 #define EXTRUDE_MAXLENGTH 160 #define NUM_TEMPS_USERTHERMISTOR0 0 #define USER_THERMISTORTABLE0 {} #define NUM_TEMPS_USERTHERMISTOR1 0 #define USER_THERMISTORTABLE1 {} #define NUM_TEMPS_USERTHERMISTOR2 0 #define USER_THERMISTORTABLE2 {} #define GENERIC_THERM_VREF 5 #define GENERIC_THERM_NUM_ENTRIES 33 #define HEATER_PWM_SPEED 0 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 0 #define DISABLE_E 0 #define INVERT_X_DIR 0 #define INVERT_Y_DIR 0 #define INVERT_Z_DIR 0 #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define X_MAX_LENGTH 180 #define Y_MAX_LENGTH 155 #define Z_MAX_LENGTH 70 #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define DISTORTION_CORRECTION 0 #define DISTORTION_CORRECTION_POINTS 5 #define DISTORTION_CORRECTION_R 100 #define DISTORTION_PERMANENT 1 #define DISTORTION_UPDATE_FREQUENCY 15 #define DISTORTION_START_DEGRADE 0.5 #define DISTORTION_END_HEIGHT 1 #define DISTORTION_EXTRAPOLATE_CORNERS 0 #define FEATURE_BABYSTEPPING 1 #define BABYSTEP_MULTIPLICATOR 1 #define DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for print moves #define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves... habe nicht alles reinkopiert
Re: Newbie mit seinem Prusa i2 ![]() 13. January 2015 14:15 |
Re: Newbie mit seinem Prusa i2 ![]() 13. January 2015 14:43 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 78 |
Re: Newbie mit seinem Prusa i2 ![]() 14. January 2015 03:33 |
#define MAX_FEEDRATE_Z 20 #define HOMING_FEEDRATE_Z 10Was wären den eigentlich, so über den Daumen, normale Geschwindigkeits- und Beschleunigungs-Werte, für einen Prusa i2?
Re: Newbie mit seinem Prusa i2 ![]() 14. January 2015 04:03 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.197 |
Re: Newbie mit seinem Prusa i2 ![]() 14. January 2015 04:17 |
#define MAX_FEEDRATE_X 40 #define MAX_FEEDRATE_Y 40 #define MAX_FEEDRATE_Z 20 #define HOMING_FEEDRATE_X 40 #define HOMING_FEEDRATE_Y 40 #define HOMING_FEEDRATE_Z 10 #define HOMING_ORDER HOME_ORDER_ZXY #define ENABLE_BACKLASH_COMPENSATION 1 #define X_BACKLASH 0 #define Y_BACKLASH 0 #define Z_BACKLASH 0 #define RAMP_ACCELERATION 1 #define STEPPER_HIGH_DELAY 10 #define DIRECTION_DELAY 0 #define STEP_DOUBLER_FREQUENCY 12000 #define ALLOW_QUADSTEPPING 1 #define DOUBLE_STEP_DELAY 1 // time in microseconds #define MAX_HALFSTEP_INTERVAL 1999 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50 #define MAX_JERK 10 #define MAX_ZJERK 0.3Werde ich heute Abend die Beschleunigung wieder raufsetzen und mal ausprobieren.
Re: Newbie mit seinem Prusa i2 ![]() 19. January 2015 11:35 |
