Hephestos wirft Filament aus. 16. February 2015 16:08 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 363 |
Startcode
; -- START GCODE --
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F1200 ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E5 ;extrude 5mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
;M117 Printing...
; -- end of START GCODE --
Endcode
; -- END GCODE --
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G90
;G91 ;relative positioning
G1 E-5 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z200 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
; -- end of END GCODE --
Re: Hephestos wirft Filament aus. 16. February 2015 17:21 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 4.977 |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Hephestos wirft Filament aus. 18. February 2015 12:07 |
