Kossel Mini Einsteigerprobleme 22. February 2016 08:44 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 3 |
; avoid_crossing_perimeters = 0 ; bed_shape = 84.5344x8.88492,83.1425x17.6725,80.8398x26.2664,77.6514x34.5726,73.6122x42.5,68.7664x49.9617,63.1673x56.8761,56.8761x63.1673,49.9617x68.7664,42.5x73.6122,34.5726x77.6514,26.2664x80.8398,17.6725x83.1425,8.88492x84.5344,0x85,-8.88492x84.5344,-17.6725x83.1425,-26.2664x80.8398,-34.5726x77.6514,-42.5x73.6122,-49.9617x68.7664,-56.8761x63.1673,-63.1673x56.8761,-68.7664x49.9617,-73.6122x42.5,-77.6514x34.5726,-80.8398x26.2664,-83.1425x17.6725,-84.5344x8.88492,-85x0,-84.5344x-8.88492,-83.1425x-17.6725,-80.8398x-26.2664,-77.6514x-34.5726,-73.6122x-42.5,-68.7664x-49.9617,-63.1673x-56.8761,-56.8761x-63.1673,-49.9617x-68.7664,-42.5x-73.6122,-34.5726x-77.6514,-26.2664x-80.8398,-17.6725x-83.1425,-8.88492x-84.5344,0x-85,8.88492x-84.5344,17.6725x-83.1425,26.2664x-80.8398,34.5726x-77.6514,42.5x-73.6122,49.9617x-68.7664,56.8761x-63.1673,63.1673x-56.8761,68.7664x-49.9617,73.6122x-42.5,77.6514x-34.5726,80.8398x-26.2664,83.1425x-17.6725,84.5344x-8.88492,85x0 ; bed_temperature = 60 ; before_layer_gcode = ; bridge_acceleration = 0 ; bridge_fan_speed = 100 ; brim_width = 2 ; complete_objects = 0 ; cooling = 1 ; default_acceleration = 0 ; disable_fan_first_layers = 1 ; duplicate_distance = 6 ; end_gcode = M104 S0 ; turn off heater temperature\nM140 S0 ; turn off heated bed\nG28 ; home all axes\nM84 ; disable motors ; extruder_clearance_height = 20 ; extruder_clearance_radius = 20 ; extruder_offset = 0x0 ; extrusion_axis = E ; extrusion_multiplier = 1 ; fan_always_on = 1 ; fan_below_layer_time = 60 ; filament_colour = #FFFFFF ; filament_diameter = 1.75 ; first_layer_acceleration = 0 ; first_layer_bed_temperature = 65 ; first_layer_extrusion_width = 0 ; first_layer_speed = 50 ; first_layer_temperature = 200 ; gcode_arcs = 0 ; gcode_comments = 0 ; gcode_flavor = reprap ; infill_acceleration = 0 ; infill_first = 0 ; layer_gcode = ; max_fan_speed = 100 ; max_print_speed = 60 ; max_volumetric_speed = 0 ; min_fan_speed = 75 ; min_print_speed = 10 ; min_skirt_length = 10 ; notes = ; nozzle_diameter = 0.4 ; only_retract_when_crossing_perimeters = 0 ; ooze_prevention = 0 ; output_filename_format = [input_filename_base].gcode ; perimeter_acceleration = 0 ; post_process = ; pressure_advance = 0 ; resolution = 0 ; retract_before_travel = 1 ; retract_layer_change = 1 ; retract_length = 6 ; retract_length_toolchange = 10 ; retract_lift = 0 ; retract_restart_extra = 0 ; retract_restart_extra_toolchange = 0 ; retract_speed = 40 ; skirt_distance = 20 ; skirt_height = 1 ; skirts = 1 ; slowdown_below_layer_time = 30 ; spiral_vase = 0 ; standby_temperature_delta = -20 ; start_gcode = M104 S[first_layer_temperature] ; Start heating hot end\nG28 ; home all axes\nG32 ; Autocalibrate - disable with ; if not required\nG1 X0 Y0 Z5 F8000 ; centre nozzle 5mm above bed\nM109 S[first_layer_temperature] ; Wait for hot end to reach temperature\n ; temperature = 195 ; threads = 2 ; toolchange_gcode = ; travel_speed = 150 ; use_firmware_retraction = 0 ; use_relative_e_distances = 0 ; use_volumetric_e = 0 ; vibration_limit = 0 ; wipe = 0 ; z_offset = 0 ; dont_support_bridges = 1 ; extrusion_width = 0 ; first_layer_height = 0.3 ; infill_only_where_needed = 0 ; interface_shells = 0 ; layer_height = 0.2 ; raft_layers = 0 ; seam_position = aligned ; support_material = 0 ; support_material_angle = 0 ; support_material_contact_distance = 0.2 ; support_material_enforce_layers = 0 ; support_material_extruder = 1 ; support_material_extrusion_width = 70% ; support_material_interface_extruder = 1 ; support_material_interface_layers = 2 ; support_material_interface_spacing = 1 ; support_material_interface_speed = 100% ; support_material_pattern = rectilinear ; support_material_spacing = 5.5 ; support_material_speed = 60 ; support_material_threshold = 0 ; xy_size_compensation = 0 ; bottom_solid_layers = 2 ; bridge_flow_ratio = 1 ; bridge_speed = 100 ; external_fill_pattern = rectilinear ; external_perimeter_extrusion_width = 0 ; external_perimeter_speed = 100 ; external_perimeters_first = 0 ; extra_perimeters = 1 ; fill_angle = 45 ; fill_density = 30% ; fill_pattern = rectilinear ; gap_fill_speed = 100 ; infill_every_layers = 1 ; infill_extruder = 1 ; infill_extrusion_width = 0 ; infill_overlap = 15% ; infill_speed = 70 ; overhangs = 1 ; perimeter_extruder = 1 ; perimeter_extrusion_width = 0 ; perimeter_speed = 30 ; perimeters = 2 ; small_perimeter_speed = 20 ; solid_infill_below_area = 70 ; solid_infill_every_layers = 0 ; solid_infill_extruder = 1 ; solid_infill_extrusion_width = 0 ; solid_infill_speed = 70 ; thin_walls = 1 ; top_infill_extrusion_width = 0 ; top_solid_infill_speed = 40 ; top_solid_layers = 2
Re: Kossel Mini Einsteigerprobleme 23. February 2016 06:11 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.603 |
Re: Kossel Mini Einsteigerprobleme 06. March 2016 12:48 |
Re: Kossel Mini Einsteigerprobleme 07. March 2016 06:30 |
