Z-Wobble, der keiner ist 17. May 2016 10:25 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 104 |
Re: Z-Wobble, der keiner ist 17. May 2016 10:34 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Z-Wobble, der keiner ist 17. May 2016 10:58 |
Re: Z-Wobble, der keiner ist 17. May 2016 11:36 |
Re: Z-Wobble, der keiner ist 17. May 2016 14:42 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 3.385 |
Re: Z-Wobble, der keiner ist 17. May 2016 14:52 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 4.398 |
Re: Z-Wobble, der keiner ist 17. May 2016 15:02 |
Re: Z-Wobble, der keiner ist 17. May 2016 15:37 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 518 |
Re: Z-Wobble, der keiner ist 17. May 2016 15:38 |
marlin
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
//#define PID_BED_DEBUG // Sends debug data to the serial port.
#define PID_BED_INTEGRAL_DRIVE_MAX MAX_BED_POWER //limit for the integral term
//120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
//from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 10.00
#define DEFAULT_bedKi .023
#define DEFAULT_bedKd 305.4
//from pidautotune
//#define DEFAULT_bedKp 97.1
//#define DEFAULT_bedKi 1.41
//#define DEFAULT_bedKd 1675.16
// FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
Re: Z-Wobble, der keiner ist 17. May 2016 15:44 |
Re: Z-Wobble, der keiner ist 17. May 2016 15:47 |
Re: Z-Wobble, der keiner ist 17. May 2016 15:55 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.197 |
Re: Z-Wobble, der keiner ist 17. May 2016 15:58 |
Kenny-F-Powers
Öhm, hast du mal die Schritte des Extruder kolibriert?
Guck mal die ganzen Rattermaken auf den glatten Flächen an. Sind deine Achsen leichtgängig?
Und jetzt mal her mit Fotos von deinem Drucker, deinen Riemen und und und
Re: Z-Wobble, der keiner ist 17. May 2016 16:03 |
Re: Z-Wobble, der keiner ist 18. May 2016 01:53 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.603 |
Re: Z-Wobble, der keiner ist 18. May 2016 02:42 |
Re: Z-Wobble, der keiner ist 18. May 2016 03:26 |
Re: Z-Wobble, der keiner ist 18. May 2016 04:19 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:18 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 169 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:21 |
Martin hzg
Hallo Jungs..Das Thema ist sehr interessant. Habe die eeprom / marlin software/ firmware. Wie stelle ich Ich Heizbett PID Dingens ein.
Re: Z-Wobble, der keiner ist 18. May 2016 13:22 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:24 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:31 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:34 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:37 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 689 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:51 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 303 |
Re: Z-Wobble, der keiner ist 18. May 2016 13:54 |
Re: Z-Wobble, der keiner ist 18. May 2016 14:06 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 327 |
Re: Z-Wobble, der keiner ist 18. May 2016 14:27 |
