ctc bizzer umbau auf rumba
geschrieben von koschiland
04. October 2016 21:12
Hi Mein mightyboard ist mir hoch gegangen also hab ich mir ein rumba board zu gelegt . da dieses ja auf 24v läuft.
display und bord ausgewählt . so jetzt fängt der ärger an Welche senor verwendet der ctc im original wollte nichts austauschen eigentlich ... ?
Kann mir da wer helfen . hab mal meine config.h angehängt ... wollte eigentlich wieder beide extruder laufen lassen ... aber erst mal mit einem drin stehen alles .
//// Temperature sensor settings:
// -3 is thermocouple with MAX31855 (only for sensor 0)
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is Mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 11 is 100k beta 3950 1% thermistor (4.7k pullup)
// 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
// 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE"
// 20 is the PT100 circuit found in the Ultimainboard V2.x
// 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
// 66 is 4.7M High Temperature thermistor from Dyze Design
// 70 is the 100K thermistor found in the bq Hephestos 2
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
// 1047 is Pt1000 with 4k7 pullup
// 1010 is Pt1000 with 1k pullup (non standard)
// 147 is Pt100 with 4k7 pullup
// 110 is Pt100 with 1k pullup (non standard)
// 998 and 999 are Dummy Tables. They will ALWAYS read 25°C or the temperature defined below.
// Use it for Testing or Development purposes. NEVER for production machine.
Und die motoren werden nicht angesteuert über s3d ..
1-mal bearbeitet. Zuletzt am 04.10.16 21:15.
Öffnen | Download - Configuration.h (51.8 KB)
Re: ctc bizzer umbau auf rumba
05. October 2016 05:35
Moin,
wird so nicht so leicht gehen. Die Hotends am CTC Bizer laufen wie auch im Ultimaker über K-Type Thermocouples. Das unterstützt das Rumba nicht von Haus aus.
Ein bisschen mehr Infos zum Anschluss deiner Motoren, Endstops etc. würden dir vielleicht auch weitere Antworten einbringen.
Das meiste spuckt dir Google auf der ersten Seite der Suchergebnisse aus.
05. October 2016 09:33
OK dann doch bissel umbauen .
Also 10Pcs Reprap Ntc 3950 Thermistor 100K Mit 1 Meter Draht Für 3D-Drucker Diy Neu Schon liegen und gekauft .
[www.ebay.de]
3 optische endstops waren beim board dabei .
Motoren habe ich 1x 17hd4001-33n 1/32 Stepping 200 * 32 / 1,5 = 5120
4x17hd4063-05n 1/32 Stepping 200 * 32 = 6.400 Steps / Umdrehung
[3dprintersuperstore.com.au]
Rumba + DRV8825 1/32 Stepping
netzteil nes-350-24 / 24V 14,6A
motoren werden trotzdem nicht angesteuert .
02. June 2017 07:26
Hi hast du es geschafft? Wieviel Amp schickst du auf die Motoren (bzw auf die y,x und Extruder als acuh den Z motor. Laut Moons schafft der Z motor ja nur 0.4A perCoil. und die Anderen 0.83A pro coil.
