Fragen zum TMC2100 07. July 2017 13:24 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 5 |
Re: Fragen zum TMC2100 08. July 2017 04:41 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 448 |
Re: Fragen zum TMC2100 08. July 2017 11:43 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 87 |
Re: Fragen zum TMC2100 08. July 2017 16:38 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 422 |
Re: Fragen zum TMC2100 08. July 2017 17:45 |
Re: Fragen zum TMC2100 08. July 2017 23:45 |
MeisterMJ12
Ohne Brücke = stealthChop
CFG1 auf GND = spreadCycle
Letzeren ist leiser und hat gleich viel Power.
Re: Fragen zum TMC2100 09. July 2017 07:57 |
Re: Fragen zum TMC2100 10. July 2017 00:16 |
RAMPS 1.4 and RUMBA Notes For most cases the 1/16 stealthChop mode is suitable and we recommend the TMC2100 SilentStepStick with 5V for RAMPS and RUMBA boards, because they use 5V logic. If you remove all jumpers (or open all switches) for MS1+MS2+MS3 on the RAMPS/RUMBA, then the SilentStepStick TMC2100 driver will be in 1/16 spreadCycle mode (CFG1=GND CFG2=open CFG3=open), because there is a pull-down resistor on MS1 on the RAMPS/RUMBA. The pull-down is 100k and in most cases it will set the driver in spreadCycle mode correctly. However if there are problems then short CFG1 to GND or replace the resistor with one which is 30k or less. If you have not an original RAMPS 1.4 or RUMBA, then your schematics can be different and you have to check the MS-Pin configurations on you board.Quelle: [github.com]
