How to use High power Stepper driver(TB6600) in RUMBA board
28. February 2018 07:51
Dear respected sir, Hope you are in good health with success and happiness. I'm really happy for your awesome tutorials. But I'm facing a problem. I'm making a large size 3D printer where I'm using Nema 23 stepper motor which need 3A current.
That's means, I will use 4 Nema 23 Stepper motor.
In X axis 1 Nema 23
Y axis 1 Nema 23
Z axis 2 Nema 23
Those A4988 Stepper motor driver can provide maximum 2A current. Therefore, I am using TB6600 high power stepper driver. But I do not know the Pin-out to connect RUMPA board with TB6600 stepper driver.
Please sir, could you help me?
I will be grateful to you.
Re: How to use High power Stepper driver(TB6600) in RUMBA board
01. March 2018 07:50
You might post this in the english speaking area of the RepRap forum to get more answers.
This should help you
[cohesion3d.com]
It makes the four lines step, dir, enable and ground that are coming from the Rumba available.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
05. March 2018 08:39
And depending on which TB6600 drivers you use, you might have to tweak them a little bit.
I used the HY-DIV268N-5A and there are two tutorials how to improve them in terms of torque and stepping quality.
following links are in this topic:
Changing ICs => Stepping Quality
Changing resistors and bridging two pins => More Torque
1-mal bearbeitet. Zuletzt am 05.03.18 08:40.
Alle Angaben ohne Gewähr grinning smiley
