Filament beim Start abstreifen 30. March 2018 14:54 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 803 |
Re: Filament beim Start abstreifen 30. March 2018 15:28 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.194 |
Re: Filament beim Start abstreifen 30. March 2018 15:49 |
Re: Filament beim Start abstreifen 30. March 2018 16:40 |
Re: Filament beim Start abstreifen 30. March 2018 23:55 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 888 |
* Clean Nozzle Feature -- EXPERIMENTAL
* Adds the G12 command to perform a nozzle cleaning process.
* Parameters:
* P Pattern
* S Strokes / Repetitions
* T Triangles (P1 only)
* Patterns:
* P0 Straight line (default). This process requires a sponge type material
* at a fixed bed location. "S" specifies strokes (i.e. back-forth motions)
* between the start / end points.
* P1 Zig-zag pattern between (X0, Y0) and (X1, Y1), "T" specifies the
* number of zig-zag triangles to do. "S" defines the number of strokes.
* Zig-zags are done in whichever is the narrower dimension.
* For example, "G12 P1 S1 T3" will execute:
* | (X0, Y1) | /\ /\ /\ | (X1, Y1)
* A | | / \ / \ / \ |
* | (X0, Y0) | / \/ \/ \ | (X1, Y0)
* |________|_________|_________|
* T1 T2 T3
* P2 Circular pattern with middle at NOZZLE_CLEAN_CIRCLE_MIDDLE.
* "R" specifies the radius. "S" specifies the stroke count.
* Before starting, the nozzle moves to NOZZLE_CLEAN_START_POINT.
* Caveats: The ending Z should be the same as starting Z.
* Attention: EXPERIMENTAL. G-code arguments may change.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
// Default number of pattern repetitions
#define NOZZLE_CLEAN_STROKES 12
// Default number of triangles
#define NOZZLE_CLEAN_TRIANGLES 3
// Specify positions as { X, Y, Z }
#define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
#define NOZZLE_CLEAN_END_POINT {100, 60, (Z_MIN_POS + 1)}
// Circular pattern radius
#define NOZZLE_CLEAN_CIRCLE_RADIUS 6.5
// Circular pattern circle fragments number
#define NOZZLE_CLEAN_CIRCLE_FN 10
// Middle point of circle
#define NOZZLE_CLEAN_CIRCLE_MIDDLE NOZZLE_CLEAN_START_POINT
// Moves the nozzle to the initial position
#define NOZZLE_CLEAN_GOBACK
#endif
Re: Filament beim Start abstreifen 31. March 2018 02:42 |
Re: Filament beim Start abstreifen 31. March 2018 03:04 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 52 |
Re: Filament beim Start abstreifen 31. March 2018 03:13 |
Re: Filament beim Start abstreifen 31. March 2018 04:56 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 489 |
Da musst du aber vorsichtig sein, denn nach dem Startscript wird immer und bei jedem Slicer ein Retract gemacht.Quote
devil77
Hallo,
neben einem angepasstem Startscript haben ich im Endscript ein Retract eingebaut.
Damit reduziere ich beim aufheizen des Hotends schon das austreten von Fillament.
Grüße Sten
Re: Filament beim Start abstreifen 31. March 2018 08:11 |
