GCode-Frage 18. July 2018 17:47 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 650 |
G90 M82 M106 S255 M140 S65 M190 S65 M104 S185 T0 M109 S185 T0 G28 W ; home all without mesh bed level G80 ; mesh bed leveling G1 Y-3.0 F1000.0 ; go outside print area G92 E0.0 G1 X60.0 E9.0 F1000.0 ; intro line G1 X100.0 E12.5 F1000.0 ; intro line G92 E0.0 G92 E0 G1 E-1.8000 F1800 G1 Z0.090 F1000 ; process Process1 ; layer 1, Z = 0.090 ;BEFORE_LAYER_CHANGE ;[layer_z] T0 ; tool H0.100 W0.400 ; skirt G1 X84.343 Y39.330 F4800 G1 E0.0000 F540 G92 E0 G1 X87.080 Y36.593 E0.0624 F2000 G1 X87.595 Y36.380 E0.0714 G1 X89.035 Y36.380 E0.0947 G1 X90.190 Y34.651 E0.1282 G1 X90.277 Y34.544 E0.1304 G1 X90.932 Y33.889 E0.1454 G1 X91.039 Y33.802 E0.1476 G1 X93.130 Y32.405 E0.1882 G1 X93.130 Y30.845 E0.2133 G1 X93.343 Y30.330 E0.2223 G1 X96.080 Y27.593 E0.2847 G1 X96.595 Y27.380 E0.2937 G1 X153.405 Y27.380 E1.2102 G1 X153.920 Y27.593 E1.2191 G1 X156.657 Y30.330 E1.2816 G1 X156.870 Y30.845 E1.2906 G1 X156.870 Y32.406 E1.3157 G1 X158.960 Y33.802 E1.3563 G1 X159.066 Y33.889 E1.3585 G1 X159.721 Y34.544 E1.3734 G1 X159.808 Y34.651 E1.3757 G1 X160.963 Y36.380 E1.4092
Re: GCode-Frage 27. July 2018 18:42 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 44 |
Re: GCode-Frage 31. July 2018 18:46 |
Re: GCode-Frage 01. August 2018 02:13 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 123 |
Re: GCode-Frage 01. August 2018 04:36 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 966 |
G90 Absolute Positioning M82 Set Extruder to absolute mode M106 S255 Fan on M140 S65 Temperature Bed (fast) M190 S65 Wait for bed temperature to read target temp M104 S185 T0 Set Extruder Temperature Warum T0? M109 S185 T0 Set Extruder Temperature and wait Warum T0? G28 W ; home all without mesh bed level Move to origin (home), if "W" is omitted, G28 will home and perform mesh bed level Kommentar ist falsch G80 ; mesh bed leveling "Cancel Canned Cycle (CNC Specific) Angeblich nur in grbl getestet. Custom in der Firmware eingerichtet? G1 Y-3.0 F1000.0 ; go outside print area G92 E0.0 Set Extruder Position G1 X60.0 E9.0 F1000.0 ; intro line Dieser Zug müsste "relativ" langsam von statten gehen, oder? G1 X100.0 E12.5 F1000.0 ; intro line G92 E0.0 Set Extruder Position G92 E0 Set Extruder Position Warum doppelt? G1 E-1.8000 F1800 Retract um Faktor 1.8 G1 Z0.090 F1000 ; process Process1 ; layer 1, Z = 0.090 ;BEFORE_LAYER_CHANGE ;[layer_z] T0 Der ist mir komplett suspekt. Sofern der hier neu ist, würde ich den auch mal ausklammern. Immerhin heizt er dir ja schon standardmäßig den Extruder auf und bezieht alles darauf. Davon ausgehend, dass du hier T0 als Werkzeug setzt, wäre es "denkbar", dass du mit diesem Command das "Standard Werkzeug" abänderst und deshalb nix passiert. Er ist nicht falsch, aber man sieht ihn nicht oft. ; tool H0.100 W0.400 ; skirt G1 X84.343 Y39.330 F4800 G1 E0.0000 F540 Hier findet der Vorschub der zuvor retracteten Faktors 1.8 - allerdings erneut relativ langsam. G92 E0 Set Extruder position Damit nullst du effektiv den Extruder wieder vor dem Druck. G1 X87.080 Y36.593 E0.0624 F2000 G1 X87.595 Y36.380 E0.0714 G1 X89.035 Y36.380 E0.0947 G1 X90.190 Y34.651 E0.1282 G1 X90.277 Y34.544 E0.1304 G1 X90.932 Y33.889 E0.1454 G1 X91.039 Y33.802 E0.1476 G1 X93.130 Y32.405 E0.1882 G1 X93.130 Y30.845 E0.2133 G1 X93.343 Y30.330 E0.2223 G1 X96.080 Y27.593 E0.2847 G1 X96.595 Y27.380 E0.2937 G1 X153.405 Y27.380 E1.2102 G1 X153.920 Y27.593 E1.2191 G1 X156.657 Y30.330 E1.2816 G1 X156.870 Y30.845 E1.2906 G1 X156.870 Y32.406 E1.3157 G1 X158.960 Y33.802 E1.3563 G1 X159.066 Y33.889 E1.3585 G1 X159.721 Y34.544 E1.3734 G1 X159.808 Y34.651 E1.3757 G1 X160.963 Y36.380 E1.4092Hab jetzt mal den Gcode bisschen farbig kommentiert. Vom Prinzip her sieht das alles nicht so verkehrt aus.
Re: GCode-Frage 06. August 2018 06:26 |
Re: GCode-Frage 07. August 2018 02:27 |
Re: GCode-Frage 07. August 2018 11:50 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.361 |
