Druckqualität Delta Drucker (Hexagon V2) 30. January 2019 05:54 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 324 |
Re: Druckqualität Delta Drucker (Hexagon V2) 04. February 2019 04:05 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.603 |
Re: Druckqualität Delta Drucker (Hexagon V2) 04. February 2019 09:45 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.112 |
Protoprinter
...Einen leichten Moiré Effekt wirst Du beim Delta immer haben.
Re: Druckqualität Delta Drucker (Hexagon V2) 05. February 2019 13:52 |
Re: Druckqualität Delta Drucker (Hexagon V2) 05. February 2019 15:17 |
Re: Druckqualität Delta Drucker (Hexagon V2) 06. February 2019 04:41 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 966 |
nebbian
In conclusion:
If you have lines on your prints, the easiest thing to do is to adjust your layer height. Use the following table:
If your steps/mm is a multiple (or very close to):
80 / 160 : Use layer heights of 0.0809, 0.1618, or 0.3236
100/200 : Use layer heights of 0.1294, 0.2589, 0.3883
The next thing to do is to mod your drivers to go into the one decay mode at all times. Switching decay modes is what causes ripples in the print.
Finally, if you’ve done all that, and you are convinced that what you’re seeing are segments, lower your segments per second value and see if that helps. If not, then upgrade to a 32 bit controller board like a Smoothie or Duet.
Re: Druckqualität Delta Drucker (Hexagon V2) 06. February 2019 13:19 |
Re: Druckqualität Delta Drucker (Hexagon V2) 06. April 2019 12:09 |
