i3 - Problem mit der Z-Achse - NEWBIE - kleine Vorstellung 20. March 2019 05:51 |
Registrierungsdatum: 5 Jahre zuvor Beiträge: 7 |
Connecting... start Printer is now online. echo: External Reset Marlin 1.1.8 echo: Last Updated: 2017-12-25 12:00 | Author: (none, default config) echo:Compiled: Jan 19 2018 echo: Free Memory: 4045 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded echo: G21 ; Units in mm echo: M149 C ; Units in Celsius echo:Filament settings: Disabled echo: M200 D1.75 echo: M200 D0 echoteps per unit: echo: M92 X79.88 Y79.69 Z3952.52 E495.00 echo:Maximum feedrates (units/s): echo: M203 X300.00 Y300.00 Z2.00 E25.00 echo:Maximum Acceleration (units/s2): echo: M201 X1000 Y1000 Z5 E3000 echo:Acceleration (units/s2): P R T echo: M204 P1000.00 R1000.00 T1000.00 echo:Advanced: S T B X Z E echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.30 E5.00 echo:Home offset: echo: M206 X0.00 Y0.00 Z0.00 echo:Material heatup parameters: echo: M145 S0 H180 B70 F0 echo: M145 S1 H240 B110 F0 echoID settings: echo: M301 P22.20 I1.08 D114.00 echoD init fail
Connecting... start Printer is now online. echo: External Reset Marlin bugfix-1.1.x echo: Last Updated: 2018-07-31 | Author: Balzes Release 0.1 echo:Compiled: Mar 19 2019 echo: Free Memory: 4141 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded echo: G21 ; (mm) echo: M149 C ; Units in Celsius echo:Filament settings: Disabled echo: M200 D1.75 echo: M200 D0 echoteps per unit: echo: M92 X80.00 Y80.00 Z4000.00 E500.00 echo:Maximum feedrates (units/s): echo: M203 X300.00 Y300.00 Z2.00 E25.00 echo:Maximum Acceleration (units/s2): echo: M201 X1000 Y1000 Z5 E3000 echo:Acceleration (units/s2): P R T echo: M204 P1000.00 R1000.00 T1000.00 echo:Advanced: Q S T X Y Z E echo: M205 Q20000 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00 echo:Home offset: echo: M206 X0.00 Y0.00 Z0.00 echo:Material heatup parameters: echo: M145 S0 H180 B70 F0 echo: M145 S1 H240 B110 F0 echoID settings: echo: M301 P22.20 I1.08 D114.00
Re: i3 - Problem mit der Z-Achse - NEWBIE - kleine Vorstellung 20. March 2019 06:31 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 820 |
Re: i3 - Problem mit der Z-Achse - NEWBIE - kleine Vorstellung 20. March 2019 06:54 |
Re: i3 - Problem mit der Z-Achse - NEWBIE - kleine Vorstellung 20. March 2019 07:02 |
; generated by Slic3r Prusa Edition 1.41.3+win64 on 2019-03-12 at 11:25:12 ; ; external perimeters extrusion width = 0.56mm ; perimeters extrusion width = 0.56mm ; infill extrusion width = 0.56mm ; solid infill extrusion width = 0.56mm ; top infill extrusion width = 0.50mm ; first layer extrusion width = 0.70mm M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2 M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2 M205 X10.00 Y10.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec M107 M190 S60 ; set bed temperature and wait for it to be reached M104 S200 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle ; Filament gcode .......
Re: i3 - Problem mit der Z-Achse - NEWBIE - kleine Vorstellung 20. March 2019 07:55 |
Re: i3 - Problem mit der Z-Achse - NEWBIE - kleine Vorstellung 20. March 2019 11:04 |
