Mendel90 Octoprint Auto Bed Leveling 18. November 2019 05:39 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 17 |
Re: Mendel90 Octoprint Auto Bed Leveling 18. November 2019 05:59 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 647 |
Re: Mendel90 Octoprint Auto Bed Leveling 18. November 2019 06:25 |
Re: Mendel90 Octoprint Auto Bed Leveling 18. November 2019 16:17 |
Re: Mendel90 Octoprint Auto Bed Leveling 18. November 2019 17:40 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 300 |
Drucker ein Prusa Mendel i2 + RAMPS 1.4 & LCD 12864 Graphic Smart Controller,|
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 00:55 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 01:51 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.610 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 04:09 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 05:49 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 12:18 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 12:43 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 16:30 |
Re: Mendel90 Octoprint Auto Bed Leveling 19. November 2019 19:13 |
G28 G1 Z0 G29
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 01:36 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 12:01 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 12:30 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 13:08 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 13:25 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 13:34 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 14:08 |
Re: Mendel90 Octoprint Auto Bed Leveling 20. November 2019 14:45 |
Re: Mendel90 Octoprint Auto Bed Leveling 24. November 2019 13:54 |
Re: Mendel90 Octoprint Auto Bed Leveling 24. November 2019 14:20 |
...Krass,..wirklich......und jetzt schon mal tausend !!!!!!!!!!!!!!!! Dank für Deine Arbeit. |
Re: Mendel90 Octoprint Auto Bed Leveling 25. November 2019 16:17 |
Re: Mendel90 Octoprint Auto Bed Leveling 03. December 2019 03:01 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 22 |
Re: Mendel90 Octoprint Auto Bed Leveling 03. December 2019 04:37 |
Re: Mendel90 Octoprint Auto Bed Leveling 04. December 2019 14:14 |
Micro3D
@Hallo Bodo
Hier ist die Config.h für die Marlin 1.1.9 , die du Erstzen musst.
Dann lade dir mal die neue Arduino IDE 1.8.10 runter.
Für dein MELZI Board braust du noch die Treiber ( Sanguino )
https://raw.githubusercontent.com/Lauszus/Sanguino/master/package_lauszus_sanguino_index.json
Per Drag & Drop da rein ziehen
[attachment 113497 Bildschirmfoto2019-11-24um19.35.08.png]
Und dann unter Board/Verwalter... nach Sanguino suchen und Installieren.
Ich habe deine X und Y Endstops auf Max Konfiguriert und dein ABL Sensor erst mal als Z_MIN eingestellt.
Bitte erst kein Homing machen , erst mal Die Endstops über prüfen
Wenn du soweit bist dann gibt bescheid.
MFG Stefan
Re: Mendel90 Octoprint Auto Bed Leveling 04. December 2019 15:32 |
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area. // // With this feature enabled: // // - Allow Z homing only after X and Y homing AND stepper drivers still enabled. // - If stepper drivers time out, it will need X and Y homing again before Z homing. // - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28). // - Prevent Z homing when the Z probe is outside bed area. // #define Z_SAFE_HOMING #if ENABLED(Z_SAFE_HOMING) #define Z_SAFE_HOMING_X_POINT ((X_BED_SIZE) / 2) // X point for Z homing when homing all axes (G28). #define Z_SAFE_HOMING_Y_POINT ((Y_BED_SIZE) / 2) // Y point for Z homing when homing all axes (G28). #endif
Re: Mendel90 Octoprint Auto Bed Leveling 04. December 2019 15:52 |
Micro3D
@Hallo
ich habe das Z_SAFE_HOMING eingeschaltet , das heisst du musst zu erst X & Y Homen und dann Z
MFG Stefan
Re: Mendel90 Octoprint Auto Bed Leveling 04. December 2019 16:14 |
