Prusa i3 Z-Achse 16. January 2016 08:53 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 5 |
Re: Prusa i3 Z-Achse 16. January 2016 10:37 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 303 |
Re: Prusa i3 Z-Achse 16. January 2016 12:13 |
Re: Prusa i3 Z-Achse 16. January 2016 12:46 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.197 |
Re: Prusa i3 Z-Achse 16. January 2016 13:03 |
Re: Prusa i3 Z-Achse 16. January 2016 14:26 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 513 |
//// MOVEMENT SETTINGS #define HOMING_FEEDRATE {50*60, 50*60, 2*60, 0} // set the homing speeds (mm/min) #define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 4000, 730} #define DEFAULT_MAX_FEEDRATE {200, 200, 2, 45} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {800, 800, 20, 500} // X, Y, Z, E maximum start speed for accelerated moves. #define DEFAULT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Prusa i3 Z-Achse 16. January 2016 17:50 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 838 |
Zizibee
Ich kann zwar nicht versprechen, dass das die idealen Werte sind, aber mein Prusa i3 funktioniert damit
Grüße
Re: Prusa i3 Z-Achse 17. January 2016 07:29 |
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 4000,989.831516} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {250, 250, 3.3, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Prusa i3 Z-Achse 17. January 2016 08:20 |
Re: Prusa i3 Z-Achse 17. January 2016 09:17 |
Re: Prusa i3 Z-Achse 17. January 2016 09:19 |
Re: Prusa i3 Z-Achse 17. January 2016 09:42 |
SteBa
Du hast eine default ACC von 1000, Max ACC liegt jedoch darunter.
SteBa
MAX ruhig deutlich höher, 2000 für X+Y, 90 für Z und je nach Extruder bis zu 10 000. Default ist abhängig vom Aufbau, mit meinem Graber kann ich default ACC von 3000 fahren, mit dem China i3 geht auch nicht mehr wie 1000.
Z-Feedrate kannst du auf 3 setzen und E Feedrate auch deutlich höher. So beschränkst du deinen retract Geschwindigkeit auf 45mm/s.
XY-Jerk darf auch mindestens 15 sein.
Re: Prusa i3 Z-Achse 17. January 2016 15:51 |
