Neue Slic3r 0.7.0 Version nun verfügbar ! 26. February 2012 17:29 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 675 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 27. February 2012 04:27 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 256 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 28. February 2012 06:19 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 282 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 28. February 2012 15:02 |
Administrator Registrierungsdatum: 12 Jahre zuvor Beiträge: 819 |
aacceleration = 0 bottom_layer_speed_ratio = 0.3 bridge_fan_speed = 100 bridge_flow_ratio = 1 bridge_speed = 70 cooling = 1 disable_fan_first_layers = 1 duplicate_distance = 6 duplicate_x = 1 duplicate_y = 1 end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors extrusion_axis = E extrusion_multiplier = 1 extrusion_width_ratio = 0 fan_below_layer_time = 30 filament_diameter = 2.9 fill_angle = 45 fill_density = 0.3 fill_pattern = rectilinear first_layer_height_ratio = 0.1 first_layer_temperature = 195 g0 = 0 gcode_arcs = 0 gcode_comments = 0 gcode_flavor = reprap infill_acceleration = 50 infill_every_layers = 1 infill_speed = 50 layer_height = 0.4 max_fan_speed = 100 min_fan_speed = 35 min_print_speed = 10 notes = nozzle_diameter = 0.5 output_filename_format = [input_filename_base].gcode perimeter_acceleration = 25 perimeter_speed = 25 perimeters = 3 post_process = print_center = 80,95 retract_before_travel = 2 retract_length = 3 retract_lift = 0.5 retract_restart_extra = 0 retract_speed = 30 rotate = 0 scale = 1 skirt_distance = 6 skirt_height = 1 skirts = 0 slowdown_below_layer_time = 20 small_perimeter_speed = 25 solid_fill_pattern = rectilinear solid_infill_speed = 40 solid_layers = 3 start_gcode = M140 S60 // set bed temp\nM109 S190 // set ext temp\nM109 // wait for ext\nM190 // wait for bed\nG28 // Homeeee\nG90 // absoulte Coordinates\nG21 // all units are mm\nG92 E0 // IMPORTANT: Reset Extruder to 0\n; some spitting of crap\nG1 E0.0\nG1 F400.0\nG1 Y5.0 X10.0\nG1 X110.0 E3.0\nG1 Y10.0 E3.5\nG1 X10.0 E8.0\nG1 E 5.0 // Retraction\nG92 E0 // IMPORTANT: Reset Extruder to 0 support_material = 1 support_material_tool = 0 temperature = 185 travel_speed = 130 use_relative_e_distances = 0 z_offset = 0
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 29. February 2012 12:46 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.916 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 29. February 2012 12:54 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.004 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 01. March 2012 02:59 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 01. March 2012 03:01 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 01. March 2012 03:40 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 01. March 2012 04:15 |
Re: Neue Slic3r 0.7.0 Version nun verfügbar ! 01. March 2012 11:07 |
