repetier-host marlin-firmware 24. March 2012 10:07 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.004 |
Re: repetier-host marlin-firmware 24. March 2012 12:38 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 236 |
Re: repetier-host marlin-firmware 24. March 2012 12:48 |
Re: repetier-host marlin-firmware 24. March 2012 13:04 |
Re: repetier-host marlin-firmware 24. March 2012 14:29 |
Re: repetier-host marlin-firmware 24. March 2012 14:51 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 193 |
Set the EEPROM_MODE to 0 if you always wan't to use the settings in this configuration file. If not, set it to a value not stored in the first EEPROM-byte used. If you later want to overwrite your current eeprom settings with configuration defaults, just select an other value. On the first call to epr_init() it will detect a mismatch of the first byte and copys default values into EEPROM. If the first byte matches, the stored values are used to overwrite the settings. IMPORTANT: With mode <>0 some changes in configuration.h are not set any more, as they are taken from the EEPROM. */ #define EEPROM_MODE 1 //#define EEPROM_MODE 0
Re: repetier-host marlin-firmware 24. March 2012 14:58 |
Re: repetier-host marlin-firmware 24. March 2012 15:21 |
Re: repetier-host marlin-firmware 24. March 2012 15:33 |
Re: repetier-host marlin-firmware 24. March 2012 16:21 |
//-------------------- S E R - T E S T ----------------------------------------------- void setup() { Serial.begin(115200); } //---------------------------------------------------------------------------------------- void loop() { Serial.print("01234567890_ABCDEFGHIJKLMNOPQRSTUVWXYZ-abcdefghijklmnopqrstuvwxyz\r\n"); }
Re: repetier-host marlin-firmware 24. March 2012 16:40 |
Re: repetier-host marlin-firmware 24. March 2012 18:49 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 2.705 |
Re: repetier-host marlin-firmware 25. March 2012 13:03 |
Re: repetier-host marlin-firmware 26. March 2012 03:02 |
Re: repetier-host marlin-firmware 26. March 2012 03:16 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 3.742 |
repetier
Was ich aber nicht verstehe ist, was der Gerätemanager damit zu tun hat.
Re: repetier-host marlin-firmware 26. March 2012 06:06 |
Re: repetier-host marlin-firmware 26. March 2012 06:22 |
Re: repetier-host marlin-firmware 26. March 2012 06:26 |
Re: repetier-host marlin-firmware 26. March 2012 07:13 |
Re: repetier-host marlin-firmware 26. March 2012 10:43 |
Re: repetier-host marlin-firmware 26. March 2012 11:25 |
Re: repetier-host marlin-firmware 26. March 2012 20:52 |
Re: repetier-host marlin-firmware 27. March 2012 03:17 |
Re: repetier-host marlin-firmware 27. March 2012 06:14 |
