OpenSCAD kann Objekte nicht berechnen 20. May 2013 13:35 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 93 |
Re: OpenSCAD kann Objekte nicht berechnen 20. May 2013 15:08 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 254 |
/* * OpenSCAD Shapes Library (www.openscad.org) * Copyright (C) 2010-2011 Giles Bathgate * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, * LGPL version 2.1, or (at your option) any later version of the GPL. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA * */ // 2D regular shapes module triangle(radius) { o=radius/2; //equivalent to radius*sin(30) a=radius*sqrt(3)/2; //equivalent to radius*cos(30) polygon(points=[[-a,-o],[0,radius],[a,-o]],paths=[[0,1,2]]); } module reg_polygon(sides,radius) { function dia(r) = sqrt(pow(r*2,2)/2); //sqrt(r*2^2/2) if only we had an exponention op if(sides<2) square([radius,0]); if(sides==3) triangle(radius); if(sides==4) square([dia(radius),dia(radius)],center=true); if(sides>4) circle(r=radius,$fn=sides); } module pentagon(radius) { reg_polygon(5,radius); } module hexagon(radius) { reg_polygon(6,radius); } module heptagon(radius) { reg_polygon(7,radius); } module octagon(radius) { reg_polygon(8,radius); } module nonagon(radius) { reg_polygon(9,radius); } module decagon(radius) { reg_polygon(10,radius); } module hendecagon(radius) { reg_polygon(11,radius); } module dodecagon(radius) { reg_polygon(12,radius); } module ellipse(width, height) { scale([1, height/width, 1]) circle(r=width/2); } module egg_outline(width, length){ union(){ difference(){ ellipse(width, 2*length-width); translate([-length/2, 0, 0]) square(length); } circle(r=width/2); } } //3D regular shapes module cone(height, radius, center = false) { cylinder(height, radius, 0, center); } module oval_prism(height, rx, ry, center = false) { scale([1, rx/ry, 1]) cylinder(h=height, r=ry, center=center); } module oval_tube(height, rx, ry, wall, center = false) { difference() { scale([1, ry/rx, 1]) cylinder(h=height, r=rx, center=center); translate([0,0,-height/2]) scale([(rx-wall)/rx, (ry-wall)/rx, 2]) cylinder(h=height, r=rx, center=center); } } module cylinder_tube(height, radius, wall, center = false) { tubify(radius,wall) cylinder(h=height, r=radius, center=center); } //Tubifies any regular prism module tubify(radius,wall) { difference() { child(0); translate([0, 0, -0.1]) scale([(radius-wall)/radius, (radius-wall)/radius, 2]) child(0); } } module triangle_prism(height,radius) { linear_extrude(height=height) triangle(radius); } module triangle_tube(height,radius,wall) { tubify(radius,wall) triangle_prism(height,radius); } module pentagon_prism(height,radius) { linear_extrude(height=height) pentagon(radius); } module pentagon_tube(height,radius,wall) { tubify(radius,wall) pentagon_prism(height,radius); } module hexagon_prism(height,radius) { linear_extrude(height=height) hexagon(radius); } module heptagon_prism(height,radius) { linear_extrude(height=height) heptagon(radius); } module octagon_prism(height,radius) { linear_extrude(height=height) octagon(radius); } module nonagon_prism(height,radius) { linear_extrude(height=height) nonagon(radius); } module decagon_prism(height,radius) { linear_extrude(height=height) decagon(radius); } module hendecagon_prism(height,radius) { linear_extrude(height=height) hendecagon(radius); } module dodecagon_prism(height,radius) { linear_extrude(height=height) dodecagon(radius); } module torus(outerRadius, innerRadius) { r=(outerRadius-innerRadius)/2; rotate_extrude() translate([innerRadius+r,0,0]) circle(r); } module triangle_pyramid(radius) { o=radius/2; //equivalent to radius*sin(30) a=radius*sqrt(3)/2; //equivalent to radius*cos(30) polyhedron(points=[[-a,-o,-o],[a,-o,-o],[0,radius,-o],[0,0,radius]],triangles=[[0,1,2],[1,2,3],[0,1,3],[0,2,3]]); } module square_pyramid(base_x, base_y,height) { w=base_x/2; h=base_y/2; polyhedron(points=[[-w,-h,0],[-w,h,0],[w,h,0],[w,-h,0],[0,0,height]],triangles=[[0,3,2,1], [0,1,4], [1,2,4], [2,3,4], [3,0,4]]); } // Tests: translate([0,0,6.5]) torus(25,12,$fn=100); translate([45,0,0]) cylinder(10,20,12,$fn=100); translate([0,45,0]) cylinder(30,12,12,$fn=100); translate([-45,0,0]) rotate([0,0,0]) cylinder(60,12,12,$fn=100); translate([-45,45,12]) sphere(12,$fn=100); translate([0,-45,12]) sphere(12,$fn=100); translate([45,45,22]) sphere(22,$fn=100); translate([45,-45,18]) sphere(18,$fn=100); translate([-45,-45,12]) sphere(12,$fn=100);
Re: OpenSCAD kann Objekte nicht berechnen 20. May 2013 15:21 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.916 |
Re: OpenSCAD kann Objekte nicht berechnen 20. May 2013 16:09 |
Re: OpenSCAD kann Objekte nicht berechnen 21. May 2013 04:11 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.133 |
Re: OpenSCAD kann Objekte nicht berechnen 21. May 2013 04:18 |
Re: OpenSCAD kann Objekte nicht berechnen 21. May 2013 07:45 |
Re: OpenSCAD kann Objekte nicht berechnen 21. May 2013 12:50 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.004 |
Re: OpenSCAD kann Objekte nicht berechnen 21. May 2013 14:56 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 675 |
