Marlin FW Autotemp 06. September 2013 10:05 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 88 |
AutoTemp:
If your gcode contains a wide spread of extruder velocities, or you realtime change the building speed, the temperature should be changed accordingly. Usually, higher speed requires higher temperature. This can now be performed by the AutoTemp function By calling M109 S T F you enter the autotemp mode.
You can leave it by calling M109 without any F. If active, the maximal extruder stepper rate of all buffered moves will be calculated, and named "maxerate" [steps/sec]. The wanted temperature then will be set to t=tempmin+factor*maxerate, while being limited between tempmin and tempmax. If the target temperature is set manually or by gcode to a value less then tempmin, it will be kept without change. Ideally, your gcode can be completely free of temperature controls, apart from a M109 S T F in the start.gcode, and a M109 S0 in the end.gcode.
Re: Marlin FW Autotemp 07. September 2013 00:50 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 675 |
Re: Marlin FW Autotemp 07. September 2013 04:17 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 531 |
Re: Marlin FW Autotemp 07. September 2013 21:44 |
Re: Marlin FW Autotemp 10. September 2013 07:29 |
