AutoBedLeveling Marlin Z Höhe falsch 02. September 2015 13:24 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 8 |
//=========================================================================== //============================ Bed Auto Leveling ============================ //=========================================================================== // @section bedlevel #define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) //#define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled. #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to specify probing locations // // - "grid" mode // Probe several points in a rectangular grid. // You specify the rectangle and the density of sample points. // This mode is preferred because there are more measurements. // // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You specify the XY coordinates of all 3 points. // Enable this to sample the bed in a grid (least squares solution) // Note: this feature generates 10KB extra code size #define AUTO_BED_LEVELING_GRID #ifdef AUTO_BED_LEVELING_GRID #define LEFT_PROBE_BED_POSITION 50 #define RIGHT_PROBE_BED_POSITION 150 #define FRONT_PROBE_BED_POSITION 50 #define BACK_PROBE_BED_POSITION 150 #define MIN_PROBE_EDGE 10 // The probe square sides can be no smaller than this // Set the number of grid points per dimension // You probably don't need more than 3 (squared=9) #define AUTO_BED_LEVELING_GRID_POINTS 2 #else // !AUTO_BED_LEVELING_GRID // Arbitrary points to probe. A simple cross-product // is used to estimate the plane of the bed. #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // AUTO_BED_LEVELING_GRID // Offsets to the probe relative to the extruder tip (Hotend - Probe) // X and Y offsets must be integers #define X_PROBE_OFFSET_FROM_EXTRUDER -38 // Probe on: -left +right #define Y_PROBE_OFFSET_FROM_EXTRUDER -50 // Probe on: -front +behind #define Z_PROBE_OFFSET_FROM_EXTRUDER -1.9 // -below (always!) #define Z_RAISE_BEFORE_HOMING 1 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 2000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 2 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 2 //How much the extruder will be raised when traveling from between next probing points #define Z_RAISE_AFTER_PROBING 0 //How much the extruder will be raised after the last probing point. // #define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10" //These commands will be executed in the end of G29 routine. //Useful to retract a deployable probe. //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like. //If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28) #endif // Support for a dedicated Z PROBE endstop separate from the Z MIN endstop. // If you would like to use both a Z PROBE and a Z MIN endstop together or just a Z PROBE with a custom pin, uncomment #define Z_PROBE_ENDSTOP and read the instructions below. // If you want to still use the Z min endstop for homing, disable Z_SAFE_HOMING above. Eg; to park the head outside the bed area when homing with G28. // WARNING: The Z MIN endstop will need to set properly as it would without a Z PROBE to prevent head crashes and premature stopping during a print. // To use a separate Z PROBE endstop, you must have a Z_PROBE_PIN defined in the pins.h file for your control board. // If you are using a servo based Z PROBE, you will need to enable NUM_SERVOS, Z_ENDSTOP_SERVO_NR and SERVO_ENDSTOPS_ANGLES in the R/C Servo below. // RAMPS 1.3/1.4 boards may be able to use the 5V, Ground and the D32 pin in the Aux 4 section of the RAMPS board. Use 5V for powered sensors, otherwise connect to ground and D32 // for normally closed configuration and 5V and D32 for normally open configurations. Normally closed configuration is advised and assumed. // The D32 pin in Aux 4 on RAMPS maps to the Arduino D32 pin. Z_PROBE_PIN is setting the pin to use on the Arduino. Since the D32 pin on the RAMPS maps to D32 on Arduino, this works. // D32 is currently selected in the RAMPS 1.3/1.4 pin file. All other boards will need changes to the respective pins_XXXXX.h file. // WARNING: Setting the wrong pin may have unexpected and potentially disastrous outcomes. Use with caution and do your homework. //#define Z_PROBE_ENDSTOP #endif // ENABLE_AUTO_BED_LEVELING
Re: AutoBedLeveling Marlin Z Höhe falsch 02. September 2015 13:26 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
