Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 18. April 2020 14:34 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 4 |
. . . C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:77:71: error: 'X_HOME_BUMP_MM' was not declared in this scope #define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT } ^ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS' XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM); ^~~~~~~~~~ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:77:71: note: suggested alternative: 'HOMING_BUMP_MM' #define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT } ^ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS' XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM); ^~~~~~~~~~ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:77:80: error: 'Y_HOME_BUMP_MM' was not declared in this scope #define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT } ^ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS' XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM); ^~~~~~~~~~ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:77:80: note: suggested alternative: 'HOMING_BUMP_MM' #define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT } ^ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS' XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM); ^~~~~~~~~~ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:77:89: error: 'Z_HOME_BUMP_MM' was not declared in this scope #define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT } ^ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS' XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM); ^~~~~~~~~~ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:77:89: note: suggested alternative: 'HOMING_BUMP_MM' #define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT } ^ C:\Users\Ronny\AppData\Local\Temp\arduino_build_202509\sketch\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS' XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM); ^~~~~~~~~~ Bibliothek LiquidCrystal in Version 1.0.7 im Ordner: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal wird verwendet exit status 1 Fehler beim Kompilieren für das Board Anet V1.0.
Re: Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 18. April 2020 16:32 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 18. April 2020 18:26 |
Re: Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 19. April 2020 04:52 |
Re: Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 19. April 2020 05:57 |
. . . Error while detecting libraries included by C:\Users\MeinName\AppData\Local\Temp\arduino_build_714168\sketch\src\gcode\host\M115.cpp . . . Error while detecting libraries included by C:\Users\MeinName\AppData\Local\Temp\arduino_build_714168\sketch\src\module\temperature.cpp . . .
Re: Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 19. April 2020 09:23 |
Re: Merlin 2.0.5.3 auf Anet 8 - Fehler beim Kompilieren 19. April 2020 12:14 |
