BLTouch ABL Unified 2 FW auf Ender 5 Z-Anzeige 24. December 2022 12:54 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 21 |
/** * For directions on how to use this firmware visit [uf2.th3dstudio.com] and click on your printer/board link * NO IMPLIED SUPPORT OR WARRANTY IS PROVIDED WITH THIS FIRMWARE AND IS PROVIDED AS-IS */ #pragma once #define CONFIGURATION_H_VERSION 02000903 //=========================================================================== //============================ TH3D Configuration =========================== //=========================================================================== // ONLY UNCOMMENT ONE PRINTER AT A TIME!!! IF YOU HAVE MULTIPLE MACHINES FLASH THEM ONE AT A TIME. // UNCOMMENT MEANS REMOVING THE // IN FRONT OF A #define XXXXXX LINE. // If you have a 512K CPU and/or a GD32 CPU please read the notes in the platformio.ini file for details on // compiling for these chips. Most boards regardless of the CPU will work as-is but if you have issues with // the board flashing the firmware you may have to change the default_envs value as noted in platformio.ini. //=========================================================================== // *********** CREALITY PRINTERS W/V4.2.7 BOARD - F103 CPU ************** //=========================================================================== //#define ENDER2_PRO //Requires Motor Adapter Cable from TH3D due to stock connections using 5 pins //#define ENDER3 //#define ENDER3_NEO //#define ENDER3_MAX //#define ENDER3_MAX_NEO //#define ENDER3_V2 //#define ENDER3_V2_NEO #define ENDER5 //#define ENDER5_PLUS //#define CR10 //#define CR10_MINI //#define CR10_S4 //#define CR10_S5 // NOTE: It is HIGHLY recommended to use an external bed MOSFET with the CR-10 series machines due to the high load the beds have. // While these boards work on 12V machines, they are designed for 24V printers that pull less current (specifically on the bed). // If you need a MOSFET, we carry one here: [www.th3dstudio.com] //------------------------------ Upgrade Settings ------------------------------- // EZOut Filament Sensor Kit - LCD Header Connection // If you are using our EZOut V1/V2 filament sensor kit please follow the install guide // and then uncomment the #define EZOUT_ENABLE line below. // Do NOT ever connect our filament sensor without the supplied adapter board. //#define EZOUT_ENABLE // EZOut Filament Sensor Kit - J1 Plug Connection // If you are using our EZOut V2 filament sensor kit please follow the install guide // and then uncomment the #define EZOUT_ENABLE_J1 line below. // Do NOT ever connect our filament sensor without the supplied adapter board. //#define EZOUT_ENABLE_J1 // Creality CR-10S Series Filament Sensor // Connect the stock sensor to the "J1" port and uncomment the below line to enable the filament sensor. //#define CR10S_STOCKFILAMENTSENSOR // EZABL Probe Mounts - Uncomment the mount you are using for your EZABL to enable EZABL support in the firmware. //#define CR10_OEM //#define ENDER2_PRO_OEM //#define ENDER2_PRO_OEM_MICRO //#define ENDER3_OEM //#define ENDER3_V2_OEM //#define ENDER3_MAX_OEM //#define ENDER5_OEM //#define ENDER5_PLUS_OEM //#define ENDER6_OEM //#define ENDER6_PETSFANG //Source: [support.th3dstudio.com] //#define SPRITE_EXTRUDER_18MM_MOUNT // Mounts to the stock CRTouch bracket #define CUSTOM_PROBE // Ender 3 NEO Series/Ender 3 V2 LCD - LCD Setting // If you converted your Ender 3 NEO Series OR V2 LCD to the 12864 Version, Uncomment the below line. // Get the conversion kit here: [www.th3dstudio.com] //#define ENDER3_12864_LCD_KIT // Ender 5 - Leadscrew Setting // If you have the new Ender 5/5 Pro Model that has the new 800steps/mm Z leadscrew uncomment the below option to set the correct steps/mm #define ENDER5_NEW_LEADSCREW // Ender 5 Plus ONLY ABL Settings // By default the Ender 5 Plus comes with a BL Touch. Enabling the ENDER5_PLUS_EZABL or ENDER5_PLUS_NOABL will override the BL Touch setting // If you are using the stock BL Touch with a non-stock mount enable the CUSTOM_PROBE line above and enter the offsets below for the new mount. //#define ENDER5_PLUS_EZABL //#define ENDER5_PLUS_NOABL // EZNeo Settings // If you are using an EZNeo strip on your printer, uncomment the line for what strip you are using. // Specify your IO pin below as well as this board does not have a dedicated NEOPIXEL header on it. //#define EZNEO_220 // EZNeo Manual IO Pin Setting // If you have the EZNeo wired with your own 5V power provided, specify the pin used below. //#define NEOPIXEL_PIN PA4 //=========================================================================== // ************************* END PRINTER SECTION ************************* //=========================================================================== //=========================================================================== // EZABL Advanced Settings - EZABL_POINTS & EZABL_PROBE_EDGE are also used for other probes //=========================================================================== // Probing Grid Points - If you want more or less EZABL probe points change the number below, use odd numbers. Total points is # times #. #define EZABL_POINTS 3 // Probe Edge - How far from the edge of the bed to probe from. Use 50 if using binder clips. This also sets the edge inset value for MANUAL_MESH_LEVELING. #define EZABL_PROBE_EDGE 35 // Fast Probing - Works with most machines and all EZABL sensors (8mm/s) #define EZABL_FASTPROBE // Superfast Probing - Only works with the EZABL Pro Sensors (15mm/s) //#define EZABL_SUPERFASTPROBE // Heaters on During Probing - Heaters will stay on during probing - May reduce accuracy do not use unless told to by support //#define HEATERS_ON_DURING_PROBING // Probing Steppers Off - This will cycle the XYE stepper motors during probing to reduce interference from them. When using this do NOT touch the X or Y during probing as they will not be locked. //#define PROBING_STEPPERS_OFF // Slow Down Moves - Does your machine make weird noises/vibrations when it is probing the mesh? Enable this to slow down the speed between probe points. //#define SLOWER_PROBE_MOVES // Grid Extrapolation - This will use the mesh data to make assumptions of the bed outside the probe area. Disable if you are getting incorrect results on the edges of the bed. #define EXTRAPOLATE_BEYOND_GRID //================================================================================ // CUSTOM PROBE SETTINGS - FOR EZABL OR BL TOUCH // If you have a probe mount that is not pre-setup in the firmware then uncomment // the CUSTOM_PROBE line above and enter your probe offsets below //================================================================================ #if ENABLED(CUSTOM_PROBE) /** * Z Probe to nozzle (X,Y) offset, relative to (0, 0). * * In the following example the X and Y offsets are both positive: * * #define NOZZLE_TO_PROBE_OFFSET { 10, 10, 0 } * * +-- BACK ---+ * | | * L | (+) P | R <-- probe (10,10) * E | | I * F | (-) N (+) | G <-- nozzle (0,0) * T | | H * | (-) | T * | | * O-- FRONT --+ * (0,0) * * Specify a Probe position as { X, Y, Z } * Do NOT enter an number for the Z position in here. Store your offset in EEPROM. * * When is the offset POSITIVE? * If the probe is right of the nozzle the offset on X is POSITIVE * If the probe is behind of the nozzle the offset on Y is POSITIVE * * When is the offset NEGATIVE? * If the probe is left of the nozzle the offset on X is NEGATIVE * If the probe is in front of the nozzle the offset on Y is NEGATIVE */ #define NOZZLE_TO_PROBE_OFFSET { -40, 0, 0 } #endif //=========================================================================== //******************** EXTRA FEATURES AND TWEAKS **************************** //=========================================================================== // EXTRUDER SETTINGS ------------------------------- // Use to set custom esteps and/or reverse your E Motor direction if you are installing an extruder that needs the direction reversed. // If you reversed the wiring on your E motor already (like the Bondtech Guide says to do) then you do not need to reverse it in the firmware here. // If you want to change the Esteps for your printer you can uncomment the below line and set CUSTOM_ESTEPS_VALUE to what you want - USE WHOLE NUMBERS ONLY // This option sets the esteps from the CUSTOM_ESTEPS_VALUE line below. // If you need to reverse the e motor direction also enabled the REVERSE_E_MOTOR_DIRECTION option. // Example EStep Values: TH3D Aluminum Extruder - 95 ESteps, TH3D Tough Extruder - 410 ESteps, BMG Extruder - 415 ESteps // When installing a Tough Extruder or E3D Titan or Bondtech that is Geared you likely need to enable the REVERSE_E_MOTOR_DIRECTION option #define CUSTOM_ESTEPS #define CUSTOM_ESTEPS_VALUE 93 #define REVERSE_E_MOTOR_DIRECTION // FILAMENT SENSOR UNLOAD SETTINGS ----------------- // If you have a filament sensor that is physically mounted to the machine you can enable MOUNTED_FILAMENT_SENSOR to set the unload length to 5mm to prevent filament from backing up in the sensor by uncommenting MOUNTED_FILAMENT_SENSOR //#define MOUNTED_FILAMENT_SENSOR // If you have a direct drive machine with a filament sensor uncomment DIRECT_DRIVE_PRINTER to decrease the unload length from 100mm to 20mm //#define DIRECT_DRIVE_PRINTER // THERMISTOR SETTINGS ----------------------------- // If you are using an E3D V6 Hotend (or Hemera) with their cartridge thermistor (not glass version) uncomment the below line. //#define V6_HOTEND // If you are using a Tough Hotend from TH3D or any thermistors TH3D sells for your hotend uncomment the below line. //#define TH3D_HOTEND_THERMISTOR // If you are using a known hotend thermistor value uncomment the below 2 lines and enter the thermistor number replacing the X after the #define KNOWN_HOTEND_THERMISTOR_VALUE //#define KNOWN_HOTEND_THERMISTOR //#define KNOWN_HOTEND_THERMISTOR_VALUE X // If you have a hotend and thermistor capable of over 290C you can set the max temp value below. // Setting this higher than 290C on a stock or traditional thermistor will damage it. Refer to your thermistor documentation to see what max temp is. //#define HIGH_TEMP_THERMISTOR #define HIGH_TEMP_THERMISTOR_TEMP 350 // BED THERMISTOR SETTINGS ------------------------- // If you are using a thermistor TH3D sells for your bed uncomment the below line. //#define TH3D_BED_THERMISTOR // If you are using a Keenovo with SSR and the Keenovo temperature sensor uncomment the below line. //#define KEENOVO_TEMPSENSOR // If you are using a known bed thermistor value uncomment the below 2 lines and enter the thermistor number replacing the X after the #define KNOWN_BED_THERMISTOR_VALUE //#define KNOWN_BED_THERMISTOR //#define KNOWN_BED_THERMISTOR_VALUE X // If you are using an AC bed with a standalone controller (Keenovo) uncomment the below line to disable the heated bed in the firmware //#define AC_BED // MISC -------------------------------------------- // LCD Knob Direction // Turning your LCD knob clockwise should move DOWN in the menus/make values increase and counter-clockwise should move UP in the menus/make values decrease // If yours is behaving opposite then enable the REVERSE_KNOB_DIRECTION option below //#define REVERSE_KNOB_DIRECTION // If you have a 5015 fan that whines when under 100% speed uncomment the below line. //#define FAN_FIX // Use your own printer name - Uncomment both lines #define CUSTOM_PRINTER_NAME #define USER_PRINTER_NAME "Jockis Ender 5" // If your printer is homing to the endstops hard uncomment this to change the homing speed/divisor to make it less aggressive. //#define SLOWER_HOMING // Axis Direction Settings // If you need to reverse the direction of a motor uncomment the below option for that axis. // E motor settings are below in the Extruder Settings Section //#define REVERSE_X_MOTOR //#define REVERSE_Y_MOTOR //#define REVERSE_Z_MOTOR //=========================================================================== //****************** COMMUNITY REQUESTED FEATURES *************************** //*** COMMUNITY REQUESTED FEATURES ARE ALL NOT SUPPORTED BY TH3D SUPPORT **** //=========================================================================== // ENDER XTENDER KIT SETTINGS ---------------------- // Ender Xtender Kits for Ender 3/3 Pro/3 V2 //#define XTENDER_E3_300 //300x300x250 Size //#define XTENDER_E3_300XL //300x300x400 Size //#define XTENDER_E3_400 //400x400x250 Size //#define XTENDER_E3_400Z //235x235x400 Size //#define XTENDER_E3_400XL //400x400x500 Size //#define XTENDER_E3_500Z //235x235x500 Size // Ender Xtender Kits for Ender 5/5 Pro //#define XTENDER_E5_5XL //235x235x500 Size // Ender Xtender Kits for Ender 5 Plus //#define XTENDER_E5P_400 //510x510x400 Size //#define XTENDER_E5P_500 //510x510x500 Size // HOME OFFSET ADJUSTMENT -------------------------- // If you need to adjust your XY home offsets from defaults then you can uncomment the HOME_ADJUST line below and enter your // custom XY offsets. This is provided for convenience and is unsupported with included product support. // How to use - measure (home XY then jog using the LCD 1mm at a time) the X and Y distance the nozzle is off // the build plate and then put those as NEGATIVE values below, positive values will NOT work (move your endstops to fix a positive offset). //#define HOME_ADJUST #define X_HOME_LOCATION -10 #define Y_HOME_LOCATION -10 // PID BED TEMPERATURE CONTROL --------------------- // If you want PID Bed Temperature control enable the below line. You will need to tune it for your machine. // See the PID Bed setup guide here: [support.th3dstudio.com] //#define ENABLE_PIDBED // FINE BABYSTEPPING ------------------------------- // Enabling the below line will set the babystep resolution from 0.025mm to 0.010mm for finer control. //#define FINE_BABYSTEPPING // LINEAR ADVANCE ---------------------------------- // See here on how to use Linear Advance: [marlinfw.org] //#define LINEAR_ADVANCE // Change the K Value here or use M900 KX.XX in your starting code (recommended). #define LINEAR_ADVANCE_K 0 // BL TOUCH ---------------------------------------- // There are 2 ways to connect the BL Touch to the V4.2.X boards - All on the 5 pin header or using 3 pins on the 5 pin header + Z Endstop port // For details on these 2 types of connections refer to our help center article here: [support.th3dstudio.com] // If you want to use the BL-Touch uncomment the BLTOUCH line below and uncomment #define CUSTOM_PROBE above and then enter in your offsets above in the CUSTOM PROBE section. #define BLTOUCH // If you are using the 5 pin header for all the BL Touch connections, uncomment the below line #define BLTOUCH_ON_5PIN // MANUAL MESH LEVELING ---------------------------- // If you want to use manual mesh leveling you can enable the below option. This is for generating a MANUAL mesh WITHOUT a probe. // Mesh Bed Leveling Documentation: [marlinfw.org] // NOTE: If you want to automate the leveling process our EZABL kits do this for you. Check them out here: [EZABL.TH3DStudio.com] //#define MANUAL_MESH_LEVELING // POWER LOSS RECOVERY ----------------------------- // Continue after Power-Loss feature will store the current state to the SD Card at the start of each layer // during SD printing. If this is found at bootup it will ask you if you want to resume the print. // // NOTE: This feature causes excessive wear on your SD card. //#define POWER_LOSS_RECOVERY // ARC Support Override ---------------------------- // Arc support is enabled by default on all builds but this takes up extra space. If you get compile errors due to the size being too large when enabling other options, then disable ARC_SUPPORT // by uncommenting the DISABLE_ARC_SUPPORT line below. //#define DISABLE_ARC_SUPPORT //=========================================================================== // ********************** END CONFIGURATION SETTINGS ********************* //=========================================================================== /** * ****************************DO NOT TOUCH ANYTHING BELOW THIS COMMENT************************** * Core machine settings are below. Do NOT modify these unless you understand what you are doing. */ /** * Sanity Checks */ //V42X with TMC Driver Sanity Checks #define V42X_TMC220X_DRIVERS #if BOTH(V42X_TMC220X_DRIVERS, LINEAR_ADVANCE) #error "Linear Advance does NOT work on the V4.2.X boards with the TMC drivers due to how Creality has them setup. Disable Linear Advance to continue or comment this line out to continue compile at your own risk." #endif //Ender 3 NEO Settings #if ENABLED(ENDER3_V2_NEO) #define ENDER3_V2 #if NONE(BLTOUCH, ENDER3_V2_OEM) #define BLTOUCH #define CUSTOM_PROBE #define NOZZLE_TO_PROBE_OFFSET { -40, -14, 0 } #define BLTOUCH_ON_5PIN #define CRTOUCH_PROBE_NAMING #endif #endif //Ender 3 NEO Settings #if ENABLED(ENDER3_NEO) #define ENDER3 #if NONE(BLTOUCH, ENDER3_OEM) #define BLTOUCH #define CUSTOM_PROBE #define NOZZLE_TO_PROBE_OFFSET { -40, -14, 0 } #define BLTOUCH_ON_5PIN #define CRTOUCH_PROBE_NAMING #endif #if DISABLED(ENDER3_12864_LCD_KIT) #define ENDER3_NEO_LCD #endif #endif //Ender 3 Max NEO Settings #if ENABLED(ENDER3_MAX_NEO) #define ENDER3_MAX #if NONE(BLTOUCH, ENDER3_MAX_OEM) #define BLTOUCH #define CUSTOM_PROBE #define NOZZLE_TO_PROBE_OFFSET { -40, -14, 0 } #define BLTOUCH_ON_5PIN #define CRTOUCH_PROBE_NAMING #endif #if DISABLED(ENDER3_12864_LCD_KIT) #define ENDER3_NEO_LCD #endif #if NONE(EZOUT_ENABLE, EZOUT_ENABLE_J1) #define EZOUT_ENABLE_J1 #endif #endif /** * Machine Configuration Settings */ #if ENABLED(EZOUT_ENABLE_J1) #define EZOUT_ENABLE #endif //CR-10 Series V427 Settings #if ENABLED(CR10) || ENABLED(CR10_MINI) || ENABLED(CR10_S4) || ENABLED(CR10_S5) #define SERIAL_PORT 1 #define PRINTER_VOLTAGE_12 #define BAUDRATE 115200 #define CR10_STOCKDISPLAY #define RET6_12864_LCD #if ENABLED(REVERSE_KNOB_DIRECTION) #define REVERSE_ENCODER_DIRECTION #endif #define MOTHERBOARD BOARD_CREALITY_V427 #if ENABLED(CUSTOM_ESTEPS) #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, CUSTOM_ESTEPS_VALUE } #else #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 95 } #endif #define SHOW_BOOTSCREEN #define EXTRUDERS 1 #if ENABLED(CR10) #define X_BED_SIZE 300 #define Y_BED_SIZE 300 #define Z_MAX_POS 400 #define PRINTER_VOLTAGE_12 #endif #if ENABLED(CR10_MINI) #define X_BED_SIZE 300 #define Y_BED_SIZE 220 #define Z_MAX_POS 300 #define PRINTER_VOLTAGE_12 #endif #if ENABLED(CR10_S4) #define X_BED_SIZE 400 #define Y_BED_SIZE 400 #define Z_MAX_POS 400 #define PRINTER_VOLTAGE_12 #define SLOWER_PROBE_MOVES #endif #if ENABLED(CR10_S5) #define X_BED_SIZE 500 #define Y_BED_SIZE 500 #define Z_MAX_POS 500 #define PRINTER_VOLTAGE_12 #define SLOWER_PROBE_MOVES #endif #if ENABLED(HOME_ADJUST) #define X_MIN_POS X_HOME_LOCATION #define Y_MIN_POS Y_HOME_LOCATION #else #define X_MIN_POS 0 #define Y_MIN_POS 0 #endif #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #if NONE(V6_HOTEND, TH3D_HOTEND_THERMISTOR, KNOWN_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 1 #else #if ENABLED(EZBOARD_PT100) #define TEMP_SENSOR_0 20 #elif ENABLED(V6_HOTEND) #define TEMP_SENSOR_0 5 #elif ENABLED(KNOWN_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 KNOWN_HOTEND_THERMISTOR_VALUE #elif ENABLED(TH3D_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 1 #endif #endif #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_4 0 #define TEMP_SENSOR_5 0 #define TEMP_SENSOR_6 0 #define TEMP_SENSOR_7 0 #if NONE(TH3D_BED_THERMISTOR, KEENOVO_TEMPSENSOR, KNOWN_BED_THERMISTOR, AC_BED) #define TEMP_SENSOR_BED 1 #else #if ENABLED(AC_BED) #define TEMP_SENSOR_BED 0 #elif ENABLED(KNOWN_BED_THERMISTOR) #define TEMP_SENSOR_BED KNOWN_BED_THERMISTOR_VALUE #elif ENABLED(TH3D_BED_THERMISTOR) #define TEMP_SENSOR_BED 1 #elif ENABLED(KEENOVO_TEMPSENSOR) #define TEMP_SENSOR_BED 11 #endif #endif #define TEMP_SENSOR_PROBE 0 #define TEMP_SENSOR_CHAMBER 0 #define ENDSTOPPULLUPS #define X_MIN_ENDSTOP_INVERTING false #define Y_MIN_ENDSTOP_INVERTING false #define Z_MIN_ENDSTOP_INVERTING false #define X_MAX_ENDSTOP_INVERTING false #define Y_MAX_ENDSTOP_INVERTING false #define Z_MAX_ENDSTOP_INVERTING false #define Z_MIN_PROBE_ENDSTOP_INVERTING false #if ENABLED(BLTOUCH_ON_5PIN) #define USE_PROBE_FOR_Z_HOMING #else #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN #endif #define X_DRIVER_TYPE TMC2208_STANDALONE #define Y_DRIVER_TYPE TMC2208_STANDALONE #define Z_DRIVER_TYPE TMC2208_STANDALONE #define E0_DRIVER_TYPE TMC2208_STANDALONE #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 #if ENABLED(REVERSE_X_MOTOR) #define INVERT_X_DIR true #else #define INVERT_X_DIR false #endif #if ENABLED(REVERSE_Y_MOTOR) #define INVERT_Y_DIR true #else #define INVERT_Y_DIR false #endif #if ENABLED(REVERSE_Z_MOTOR) #define INVERT_Z_DIR false #else #define INVERT_Z_DIR true #endif #if ENABLED(REVERSE_E_MOTOR_DIRECTION) #define INVERT_E0_DIR true #else #define INVERT_E0_DIR false #endif #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false #define INVERT_E4_DIR false #define INVERT_E5_DIR false #define INVERT_E6_DIR false #define INVERT_E7_DIR false #define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 1 #if ENABLED(EZOUT_ENABLE) #define FILAMENT_RUNOUT_SENSOR #if DISABLED(EZOUT_ENABLE_J1) #define SPEAKER_KILL #endif #endif #if ENABLED(EZOUT_ENABLE) || ENABLED(CR10S_STOCKFILAMENTSENSOR) #define FILAMENT_RUNOUT_SENSOR #endif #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #if ENABLED(EZOUT_ENABLE) #define FIL_RUNOUT_STATE LOW // Pin state indicating that filament is NOT present. #else #define FIL_RUNOUT_STATE HIGH // Pin state indicating that filament is NOT present. #endif #define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins. //#define FIL_RUNOUT_PULLDOWN // Use internal pulldown for filament runout pins. // Set one or more commands to execute on filament runout. // (After 'M412 H' Marlin will ask the host to handle the process.) #define FILAMENT_RUNOUT_SCRIPT "M600" // After a runout is detected, continue printing this length of filament // before executing the runout script. Useful for a sensor at the end of // a feed tube. Requires 4 bytes SRAM per sensor, plus 4 bytes overhead. //#define FILAMENT_RUNOUT_DISTANCE_MM 25 #ifdef FILAMENT_RUNOUT_DISTANCE_MM // Enable this option to use an encoder disc that toggles the runout pin // as the filament moves. (Be sure to set FILAMENT_RUNOUT_DISTANCE_MM // large enough to avoid false positives.) //#define FILAMENT_MOTION_SENSOR #endif #endif #if ENABLED(EZNEO_220) #define RGB_LIGHTS #define NEOPIXEL_LED #if ENABLED(NEOPIXEL_LED) #define NEOPIXEL_TYPE NEO_GRB // NEO_GRBW / NEO_GRB - four/three channel driver type (defined in Adafruit_NeoPixel.h) #define NEOPIXEL_PIXELS 15 // Number of LEDs in the strip. (Longest strip when NEOPIXEL2_SEPARATE is disabled.) #define NEOPIXEL_IS_SEQUENTIAL // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once. #define NEOPIXEL_BRIGHTNESS 255 // Initial brightness (0-255) #define NEOPIXEL_STARTUP_TEST // Cycle through colors at startup #endif /** * Printer Event LEDs * * During printing, the LEDs will reflect the printer status: * * - Gradually change from blue to violet as the heated bed gets to target temp * - Gradually change from violet to red as the hotend gets to temperature * - Change to white to illuminate work surface * - Change to green once print has finished * - Turn off after the print has finished and the user has pushed a button */ #if ANY(BLINKM, RGB_LED, RGBW_LED, PCA9632, PCA9533, NEOPIXEL_LED) #define PRINTER_EVENT_LEDS #endif #endif #endif // End CR-10 Series V427 Settings //Ender 2 Pro/3/3 MAX/5/5 Plus V427 Board Settings #if ANY(ENDER2_PRO, ENDER3, ENDER5, ENDER3_MAX, ENDER5_PLUS) #if ANY(ENDER3_MAX, ENDER5_PLUS) #define MOUNTED_FILAMENT_SENSOR #endif #define PRINTER_VOLTAGE_24 #define SERIAL_PORT 1 #define BAUDRATE 115200 #if DISABLED(ENDER3_NEO_LCD) #define CR10_STOCKDISPLAY #define RET6_12864_LCD #else #define LCD_SERIAL_PORT 3 #define NO_LCD_REINIT 1 //Different Ender 3 V2 LCD Display Options - Change at your own risk!!! //#define DWIN_CREALITY_LCD // Creality UI //#define DWIN_CREALITY_LCD_ENHANCED // Enhanced UI //#define DWIN_CREALITY_LCD_JYERSUI // Jyers UI by Jacob Myers #define DWIN_MARLINUI_PORTRAIT // MarlinUI (portrait orientation) //#define DWIN_MARLINUI_LANDSCAPE // MarlinUI (landscape orientation) #endif #if ANY(DWIN_CREALITY_LCD, DWIN_CREALITY_LCD_JYERSUI, DWIN_CREALITY_LCD_ENHANCED) #define ENABLE_PIDBED #define POWER_LOSS_RECOVERY #endif #define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 1 #define Z_PROBE_OFFSET_RANGE_MIN -10 #define Z_PROBE_OFFSET_RANGE_MAX 10 #define EXTRUDE_MAXLENGTH 1000 #if ENABLED(REVERSE_KNOB_DIRECTION) && DISABLED(ENDER5_PLUS) #define REVERSE_ENCODER_DIRECTION #endif #ifndef MOTHERBOARD #define MOTHERBOARD BOARD_CREALITY_V427 #endif #if ENABLED(ENDER5_NEW_LEADSCREW) #define CREALITY_Z_STEPS 800 #else #define CREALITY_Z_STEPS 400 #endif #if ENABLED(CUSTOM_ESTEPS) #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, CREALITY_Z_STEPS, CUSTOM_ESTEPS_VALUE } #else #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, CREALITY_Z_STEPS, 95 } #endif #define SHOW_BOOTSCREEN #define EXTRUDERS 1 #if ENABLED(ENDER3) #if ENABLED(XTENDER_E3_300) #define X_BED_SIZE 300 #define Y_BED_SIZE 300 #define Z_MAX_POS 250 #elif ENABLED(XTENDER_E3_300XL) #define X_BED_SIZE 300 #define Y_BED_SIZE 300 #define Z_MAX_POS 400 #elif ENABLED(XTENDER_E3_400) #define X_BED_SIZE 400 #define Y_BED_SIZE 400 #define Z_MAX_POS 250 #elif ENABLED(XTENDER_E3_400Z) #define X_BED_SIZE 235 #define Y_BED_SIZE 235 #define Z_MAX_POS 400 #elif ENABLED(XTENDER_E3_400XL) #define X_BED_SIZE 400 #define Y_BED_SIZE 400 #define Z_MAX_POS 500 #elif ENABLED(XTENDER_E3_500Z) #define X_BED_SIZE 235 #define Y_BED_SIZE 235 #define Z_MAX_POS 500 #else #define X_BED_SIZE 235 #define Y_BED_SIZE 235 #define Z_MAX_POS 250 #endif #endif #if ENABLED(ENDER2_PRO) #define X_BED_SIZE 165 #define Y_BED_SIZE 168 #define Z_MAX_POS 180 #endif #if ENABLED(ENDER3_MAX) #define X_BED_SIZE 300 #define Y_BED_SIZE 300 #define Z_MAX_POS 340 #endif #if ENABLED(ENDER5) #if ENABLED(XTENDER_E5_5XL) #define X_BED_SIZE 235 #define Y_BED_SIZE 235 #define Z_MAX_POS 500 #else #define X_BED_SIZE 220 #define Y_BED_SIZE 220 #define Z_MAX_POS 300 #endif #endif #if ENABLED(ENDER5_PLUS) #if ENABLED(XTENDER_E5P_400) #define X_BED_SIZE 510 #define Y_BED_SIZE 510 #define Z_MAX_POS 400 #elif ENABLED(XTENDER_E5P_500) #define X_BED_SIZE 510 #define Y_BED_SIZE 510 #define Z_MAX_POS 500 #else #define X_BED_SIZE 350 #define Y_BED_SIZE 350 #define Z_MAX_POS 400 #endif #if DISABLED(REVERSE_KNOB_DIRECTION) #define REVERSE_ENCODER_DIRECTION #endif #define ENDER5_NEW_LEADSCREW #endif #if ENABLED(HOME_ADJUST) #define X_MIN_POS X_HOME_LOCATION #define Y_MIN_POS Y_HOME_LOCATION #elif ENABLED(ENDER2_PRO_OEM) #define X_MIN_POS -9 #define Y_MIN_POS -4 #elif ENABLED(ENDER2_PRO_OEM_MICRO) #define X_MIN_POS -9 #define Y_MIN_POS -4 #elif ENABLED(ENDER2_PRO) #define X_MIN_POS -20 #define Y_MIN_POS -4 #else #define X_MIN_POS 0 #define Y_MIN_POS 0 #endif #if ANY(ENDER5, ENDER5_PLUS) #define USE_XMAX_PLUG #define USE_YMAX_PLUG #define USE_ZMIN_PLUG #else #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG #endif #if ANY(ENDER5, ENDER5_PLUS) #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1 #else #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #endif #if NONE(V6_HOTEND, TH3D_HOTEND_THERMISTOR, KNOWN_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 1 #else #if ENABLED(EZBOARD_PT100) #define TEMP_SENSOR_0 20 #elif ENABLED(V6_HOTEND) #define TEMP_SENSOR_0 5 #elif ENABLED(KNOWN_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 KNOWN_HOTEND_THERMISTOR_VALUE #elif ENABLED(TH3D_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 1 #endif #endif #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_4 0 #define TEMP_SENSOR_5 0 #define TEMP_SENSOR_6 0 #define TEMP_SENSOR_7 0 #if NONE(TH3D_BED_THERMISTOR, KEENOVO_TEMPSENSOR, KNOWN_BED_THERMISTOR, AC_BED) #define TEMP_SENSOR_BED 1 #else #if ENABLED(AC_BED) #define TEMP_SENSOR_BED 0 #elif ENABLED(KNOWN_BED_THERMISTOR) #define TEMP_SENSOR_BED KNOWN_BED_THERMISTOR_VALUE #elif ENABLED(TH3D_BED_THERMISTOR) #define TEMP_SENSOR_BED 1 #elif ENABLED(KEENOVO_TEMPSENSOR) #define TEMP_SENSOR_BED 11 #endif #endif #define TEMP_SENSOR_PROBE 0 #define TEMP_SENSOR_CHAMBER 0 #define DEFAULT_Kp 28.72 #define DEFAULT_Ki 2.62 #define DEFAULT_Kd 78.81 #define DEFAULT_bedKp 462.10 #define DEFAULT_bedKi 85.47 #define DEFAULT_bedKd 624.59 #define ENDSTOPPULLUPS #define X_MIN_ENDSTOP_INVERTING false #define Y_MIN_ENDSTOP_INVERTING false #define Z_MIN_ENDSTOP_INVERTING false #define X_MAX_ENDSTOP_INVERTING false #define Y_MAX_ENDSTOP_INVERTING false #define Z_MAX_ENDSTOP_INVERTING false #define Z_MIN_PROBE_ENDSTOP_INVERTING false #if ENABLED(BLTOUCH_ON_5PIN) #define USE_PROBE_FOR_Z_HOMING #else #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN #endif #define X_DRIVER_TYPE TMC2208_STANDALONE #define Y_DRIVER_TYPE TMC2208_STANDALONE #define Z_DRIVER_TYPE TMC2208_STANDALONE #define E0_DRIVER_TYPE TMC2208_STANDALONE #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 #if ENABLED(ENDER2_PRO) #if ENABLED(REVERSE_X_MOTOR) #define INVERT_X_DIR false #else #define INVERT_X_DIR true #endif #else #if ENABLED(REVERSE_X_MOTOR) #define INVERT_X_DIR true #else #define INVERT_X_DIR false #endif #endif #if ENABLED(ENDER2_PRO) #if ENABLED(REVERSE_Y_MOTOR) #define INVERT_Y_DIR false #else #define INVERT_Y_DIR true #endif #else #if ENABLED(REVERSE_Y_MOTOR) #define INVERT_Y_DIR true #else #define INVERT_Y_DIR false #endif #endif #if ANY(ENDER5, ENDER5_PLUS, ENDER2_PRO) #if ENABLED(REVERSE_Z_MOTOR) #define INVERT_Z_DIR true #else #define INVERT_Z_DIR false #endif #else #if ENABLED(REVERSE_Z_MOTOR) #define INVERT_Z_DIR false #else #define INVERT_Z_DIR true #endif #endif #if ENABLED(ENDER2_PRO) #if ENABLED(REVERSE_E_MOTOR_DIRECTION) #define INVERT_E0_DIR false #else #define INVERT_E0_DIR true #endif #else #if ENABLED(REVERSE_E_MOTOR_DIRECTION) #define INVERT_E0_DIR true #else #define INVERT_E0_DIR false #endif #endif #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false #define INVERT_E4_DIR false #define INVERT_E5_DIR false #define INVERT_E6_DIR false #define INVERT_E7_DIR false #define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 1 #if ENABLED(ENDER5_PLUS) #if DISABLED(ENDER5_PLUS_NOABL) && DISABLED(ENDER5_PLUS_EZABL) #define BLTOUCH #ifndef EZABL_PROBE_EDGE #define EZABL_PROBE_EDGE 35 #endif #ifndef EZABL_POINTS #define EZABL_POINTS 5 #endif #if DISABLED(CUSTOM_PROBE) #define CUSTOM_PROBE #define NOZZLE_TO_PROBE_OFFSET { -44, -9, 0} #endif #endif #if DISABLED(ENDER5_PLUS_NOABL) #define ABL_ENABLE #endif #endif #if ENABLED(EZOUT_ENABLE) #define FILAMENT_RUNOUT_SENSOR #if DISABLED(EZOUT_ENABLE_J1) #define SPEAKER_KILL #endif #endif #if ANY(ENDER3_MAX, ENDER5_PLUS) #define FILAMENT_RUNOUT_SENSOR #endif #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #define FIL_RUNOUT_STATE LOW // Pin state indicating that filament is NOT present. #define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins. //#define FIL_RUNOUT_PULLDOWN // Use internal pulldown for filament runout pins. // Set one or more commands to execute on filament runout. // (After 'M412 H' Marlin will ask the host to handle the process.) #define FILAMENT_RUNOUT_SCRIPT "M600" // After a runout is detected, continue printing this length of filament // before executing the runout script. Useful for a sensor at the end of // a feed tube. Requires 4 bytes SRAM per sensor, plus 4 bytes overhead. //#define FILAMENT_RUNOUT_DISTANCE_MM 25 #ifdef FILAMENT_RUNOUT_DISTANCE_MM // Enable this option to use an encoder disc that toggles the runout pin // as the filament moves. (Be sure to set FILAMENT_RUNOUT_DISTANCE_MM // large enough to avoid false positives.) //#define FILAMENT_MOTION_SENSOR #endif #endif #if ENABLED(EZNEO_220) #define RGB_LIGHTS #define NEOPIXEL_LED #if ENABLED(NEOPIXEL_LED) #define NEOPIXEL_TYPE NEO_GRB // NEO_GRBW / NEO_GRB - four/three channel driver type (defined in Adafruit_NeoPixel.h) #define NEOPIXEL_PIXELS 15 // Number of LEDs in the strip. (Longest strip when NEOPIXEL2_SEPARATE is disabled.) #define NEOPIXEL_IS_SEQUENTIAL // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once. #define NEOPIXEL_BRIGHTNESS 255 // Initial brightness (0-255) #define NEOPIXEL_STARTUP_TEST // Cycle through colors at startup #endif /** * Printer Event LEDs * * During printing, the LEDs will reflect the printer status: * * - Gradually change from blue to violet as the heated bed gets to target temp * - Gradually change from violet to red as the hotend gets to temperature * - Change to white to illuminate work surface * - Change to green once print has finished * - Turn off after the print has finished and the user has pushed a button */ #if ANY(BLINKM, RGB_LED, RGBW_LED, PCA9632, PCA9533, NEOPIXEL_LED) #define PRINTER_EVENT_LEDS #endif #endif #endif // End Ender 3/3 MAX/5/5 Plus V427 Board Settings // Ender 3 V2 Settings V427 #if ENABLED(ENDER3_V2) #define SERIAL_PORT 1 #define BAUDRATE 115200 #ifndef MOTHERBOARD #define MOTHERBOARD BOARD_CREALITY_V427 #endif #if ENABLED(CUSTOM_ESTEPS) #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, CUSTOM_ESTEPS_VALUE } #else #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 95 } #endif #define SHOW_BOOTSCREEN #define EXTRUDERS 1 #if ENABLED(ENDER3_V2) #if ENABLED(XTENDER_E3_300) #define X_BED_SIZE 300 #define Y_BED_SIZE 300 #define Z_MAX_POS 250 #define MACHINE_SIZE "300x300x250" #elif ENABLED(XTENDER_E3_300XL) #define X_BED_SIZE 300 #define Y_BED_SIZE 300 #define Z_MAX_POS 400 #define MACHINE_SIZE "300x300x400" #elif ENABLED(XTENDER_E3_400) #define X_BED_SIZE 400 #define Y_BED_SIZE 400 #define Z_MAX_POS 250 #define MACHINE_SIZE "400x400x250" #elif ENABLED(XTENDER_E3_400Z) #define X_BED_SIZE 220 #define Y_BED_SIZE 220 #define Z_MAX_POS 400 #define MACHINE_SIZE "220x220x400" #elif ENABLED(XTENDER_E3_400XL) #define X_BED_SIZE 400 #define Y_BED_SIZE 400 #define Z_MAX_POS 500 #define MACHINE_SIZE "400x400x500" #elif ENABLED(XTENDER_E3_500Z) #define X_BED_SIZE 220 #define Y_BED_SIZE 220 #define Z_MAX_POS 500 #define MACHINE_SIZE "220x220x500" #else #define X_BED_SIZE 220 #define Y_BED_SIZE 220 #define Z_MAX_POS 250 #define MACHINE_SIZE "220x220x250" #endif #endif #if ENABLED(HOME_ADJUST) #define X_MIN_POS X_HOME_LOCATION #define Y_MIN_POS Y_HOME_LOCATION #else #define X_MIN_POS 0 #define Y_MIN_POS 0 #endif #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #if NONE(V6_HOTEND, TH3D_HOTEND_THERMISTOR, KNOWN_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 1 #else #if ENABLED(EZBOARD_PT100) #define TEMP_SENSOR_0 20 #elif ENABLED(V6_HOTEND) #define TEMP_SENSOR_0 5 #elif ENABLED(KNOWN_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 KNOWN_HOTEND_THERMISTOR_VALUE #elif ENABLED(TH3D_HOTEND_THERMISTOR) #define TEMP_SENSOR_0 1 #endif #endif #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_4 0 #define TEMP_SENSOR_5 0 #define TEMP_SENSOR_6 0 #define TEMP_SENSOR_7 0 #if NONE(TH3D_BED_THERMISTOR, KEENOVO_TEMPSENSOR, KNOWN_BED_THERMISTOR, AC_BED) #define TEMP_SENSOR_BED 1 #else #if ENABLED(AC_BED) #define TEMP_SENSOR_BED 0 #elif ENABLED(KNOWN_BED_THERMISTOR) #define TEMP_SENSOR_BED KNOWN_BED_THERMISTOR_VALUE #elif ENABLED(TH3D_BED_THERMISTOR) #define TEMP_SENSOR_BED 1 #elif ENABLED(KEENOVO_TEMPSENSOR) #define TEMP_SENSOR_BED 11 #endif #endif #define TEMP_SENSOR_PROBE 0 #define TEMP_SENSOR_CHAMBER 0 #define DEFAULT_Kp 28.72 #define DEFAULT_Ki 2.62 #define DEFAULT_Kd 78.81 #define DEFAULT_bedKp 462.10 #define DEFAULT_bedKi 85.47 #define DEFAULT_bedKd 624.59 #define ENDSTOPPULLUPS #define X_MIN_ENDSTOP_INVERTING false #define Y_MIN_ENDSTOP_INVERTING false #define Z_MIN_ENDSTOP_INVERTING false #define X_MAX_ENDSTOP_INVERTING false #define Y_MAX_ENDSTOP_INVERTING false #define Z_MAX_ENDSTOP_INVERTING false #define Z_MIN_PROBE_ENDSTOP_INVERTING false #if ENABLED(BLTOUCH_ON_5PIN) #define USE_PROBE_FOR_Z_HOMING #else #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN #endif #define X_DRIVER_TYPE TMC2208_STANDALONE #define Y_DRIVER_TYPE TMC2208_STANDALONE #define Z_DRIVER_TYPE TMC2208_STANDALONE #define E0_DRIVER_TYPE TMC2208_STANDALONE #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 #if ENABLED(REVERSE_X_MOTOR) #define INVERT_X_DIR true #else #define INVERT_X_DIR false #endif #if ENABLED(REVERSE_Y_MOTOR) #define INVERT_Y_DIR true #else #define INVERT_Y_DIR false #endif #if ENABLED(REVERSE_Z_MOTOR) #define INVERT_Z_DIR false #else #define INVERT_Z_DIR true #endif #if ENABLED(REVERSE_E_MOTOR_DIRECTION) #define INVERT_E0_DIR true #else #define INVERT_E0_DIR false #endif #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false #define INVERT_E4_DIR false #define INVERT_E5_DIR false #define INVERT_E6_DIR false #define INVERT_E7_DIR false #if ENABLED(ENDER3_12864_LCD_KIT) #define CR10_STOCKDISPLAY #define RET6_12864_LCD #else //Not working yet with the DACAI LCD, OK with the DWIN LCD - Background Issues #define LCD_SERIAL_PORT 3 #define NO_LCD_REINIT 1 //Different Ender 3 V2 LCD Display Options - Change at your own risk!!! //#define DWIN_CREALITY_LCD // Creality UI //#define DWIN_CREALITY_LCD_ENHANCED // Enhanced UI //#define DWIN_CREALITY_LCD_JYERSUI // Jyers UI by Jacob Myers #define DWIN_MARLINUI_PORTRAIT // MarlinUI (portrait orientation) //#define DWIN_MARLINUI_LANDSCAPE // MarlinUI (landscape orientation) #endif #if ANY(DWIN_CREALITY_LCD, DWIN_CREALITY_LCD_JYERSUI, DWIN_CREALITY_LCD_ENHANCED) #define ENABLE_PIDBED #define POWER_LOSS_RECOVERY #endif #define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 1 #define Z_PROBE_OFFSET_RANGE_MIN -10 #define Z_PROBE_OFFSET_RANGE_MAX 10 #define EXTRUDE_MAXLENGTH 1000 #if ENABLED(EZOUT_ENABLE) #define FILAMENT_RUNOUT_SENSOR #if DISABLED(EZOUT_ENABLE_J1) #define SPEAKER_KILL #endif #endif #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #define FIL_RUNOUT_STATE LOW // Pin state indicating that filament is NOT present. #define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins. //#define FIL_RUNOUT_PULLDOWN // Use internal pulldown for filament runout pins. // Set one or more commands to execute on filament runout. // (After 'M412 H' Marlin will ask the host to handle the process.) #define FILAMENT_RUNOUT_SCRIPT "M600" // After a runout is detected, continue printing this length of filament // before executing the runout script. Useful for a sensor at the end of // a feed tube. Requires 4 bytes SRAM per sensor, plus 4 bytes overhead. //#define FILAMENT_RUNOUT_DISTANCE_MM 25 #ifdef FILAMENT_RUNOUT_DISTANCE_MM // Enable this option to use an encoder disc that toggles the runout pin // as the filament moves. (Be sure to set FILAMENT_RUNOUT_DISTANCE_MM // large enough to avoid false positives.) //#define FILAMENT_MOTION_SENSOR #endif #endif #if ENABLED(EZNEO_220) #define RGB_LIGHTS #define NEOPIXEL_LED #if ENABLED(NEOPIXEL_LED) #define NEOPIXEL_TYPE NEO_GRB // NEO_GRBW / NEO_GRB - four/three channel driver type (defined in Adafruit_NeoPixel.h) #define NEOPIXEL_PIXELS 15 // Number of LEDs in the strip. (Longest strip when NEOPIXEL2_SEPARATE is disabled.) #define NEOPIXEL_IS_SEQUENTIAL // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once. #define NEOPIXEL_BRIGHTNESS 255 // Initial brightness (0-255) #define NEOPIXEL_STARTUP_TEST // Cycle through colors at startup #endif /** * Printer Event LEDs * * During printing, the LEDs will reflect the printer status: * * - Gradually change from blue to violet as the heated bed gets to target temp * - Gradually change from violet to red as the hotend gets to temperature * - Change to white to illuminate work surface * - Change to green once print has finished * - Turn off after the print has finished and the user has pushed a button */ #if ANY(BLINKM, RGB_LED, RGBW_LED, PCA9632, PCA9533, NEOPIXEL_LED) #define PRINTER_EVENT_LEDS #endif #endif #endif // End Ender 3 V2 Settings V427 /* * All other settings are stored in the Configuration_backend.h and Configuration_speed.h files. Do not change unless you know what you are doing. */ #include "Configuration_backend.h" #include "Configuration_speed.h"
Re: BLTouch ABL Unified 2 FW auf Ender 5 Z-Anzeige 25. December 2022 19:35 |
