slic3er dual-extr. problem 12. June 2013 15:23 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 1.004 |
Re: slic3er dual-extr. problem 12. June 2013 16:04 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 1.916 |
Re: slic3er dual-extr. problem 12. June 2013 16:14 |
Re: slic3er dual-extr. problem 12. June 2013 16:51 |
Re: slic3er dual-extr. problem 12. June 2013 18:18 |
Re: slic3er dual-extr. problem 13. June 2013 02:09 |
bed_size = 200,200 end_gcode = M104 S0 T0 ; Extruder aus\nM104 S0 T1 ; Extruder aus\nM140 S0 ; Bett aus\nG28 X0 ; home X axis\nM84 ; disable motors\nG1 X10 Y0 F500 ; Go to corner of bed extruder_offset = 0x0,22.9x-0.45 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.35,0.35 print_center = 100,100 retract_before_travel = 2,2 retract_layer_change = 1,1 retract_length = 4,4 retract_length_toolchange = 8,8 retract_lift = 0,0 retract_restart_extra = -0.4,-0.4 retract_restart_extra_toolchange = -0.3,-0.3 retract_speed = 500,500 start_gcode = M42 P5 S255; Extruder Kuehler an\nM106 S130; Ramps Luefter an\nG1 Z7.5 F150 ; Lift up, to prevent clash with clamp\nG28 Z X Y ; goto X und Y home\nG21 ; Set units to millimeters\n G91 ; Set to relative positioning\nM109 S240 T0;\nM109 S240 T1; toolchange_gcode = use_relative_e_distances = 0 vibration_limit = 0 z_offset = 0
Re: slic3er dual-extr. problem 13. June 2013 05:55 |
Re: slic3er dual-extr. problem 13. June 2013 06:32 |
Re: slic3er dual-extr. problem 13. June 2013 13:55 |
