Re: Problem bei Autoleveling mit Repetier 21. July 2014 11:42 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 159 |
// #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMINmuss das bei Dir sein? Was kommt raus, wenn Du mit dem Drucker auf Home fährst und "M119" eingibst? Was kommt raus, wenn Du einfach in die Mitte des Druckerbetts fährst und "M119" eingibst?
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.Mach mal ein Bild von Deinem Drucker (mit den Stops) und markiere, wo Deine Home Pos ist.
// Travel limits after homing #define X_MAX_POS 190 #define X_MIN_POS 0 #define Y_MAX_POS 180 #define Y_MIN_POS 0 #define Z_MAX_POS 185 #define Z_MIN_POS 0
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 2560, 159.105} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 4, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {180, 180, 10, 200} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retractsbei mir sieht das so aus:
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,495,480} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 2, 45} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,300} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 300 //3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Problem bei Autoleveling mit Repetier 29. August 2014 13:08 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 3.969 |
Re: Problem bei Autoleveling mit Repetier 29. August 2014 15:15 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 99 |
Re: Problem bei Autoleveling mit Repetier 29. August 2014 16:17 |
Re: Problem bei Autoleveling mit Repetier 31. August 2014 09:02 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 197 |
Fridi
Moin moin aus HU.
Ich auch. ;o)
Vielleicht verstehe ich das ja falsch.
Hintergrund.
Ich fahre X,Y und Z auf 0.
Dann mache ich mit G32 eine Z-Probe. Dann fahre ich die 3 Achsen wieder auf 0. Jetzt habe ich wieder die 2,2mm Abstand von der Düse zum HB. Wie sage ich dem Drucker, dass er beim Start des Druckes 2,2mm weiter runter fährt. Mein Z-Sensor spricht an und stopt das. Was verstehe ich falsch.
Mein Sensor ist der Min-Endstop, den ich auch nicht einklappen kann. der steht fest. Mein Induktive-Endstop reagiert auf die Metallfolie, die sich unter ihm befindet.
Frithjof
Fridi
Kämpfe schon die ganze Woche damit und habe auch einige Beiträge gelesen. Komischerweise haben die Anderen User nicht das Problem. Scheinbar habe ich wieder ein Brett vor dem Kopf.
