"Out of Filament"-Sensor 05. April 2015 09:21 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 54 |
Re: "Out of Filament"-Sensor 19. April 2015 09:22 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 236 |
Re: "Out of Filament"-Sensor 19. April 2015 09:59 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 4.398 |
Re: "Out of Filament"-Sensor 19. April 2015 10:21 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: "Out of Filament"-Sensor 19. April 2015 12:53 |
Re: "Out of Filament"-Sensor 19. April 2015 13:53 |
Re: "Out of Filament"-Sensor 20. April 2015 04:12 |
//=========================================================================== //============================= Filament Runout Sensor ====================== //=========================================================================== //#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament // In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made. // It is assumed that when logic high = filament available // when logic low = filament ran out //const bool FIL_RUNOUT_INVERTING = true; // Should be uncommented and true or false should assigned //#define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined. // M600: Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal] //#define FILAMEN_RUNOUT_SCRIPT "M600 X100 Y10 Z3 E-3 L100" // config your runout. If commented 'M600' is send.
Re: "Out of Filament"-Sensor 20. April 2015 06:20 |
Re: "Out of Filament"-Sensor 20. April 2015 16:47 |
Re: "Out of Filament"-Sensor 21. April 2015 03:26 |
Re: "Out of Filament"-Sensor 21. April 2015 06:41 |
Re: "Out of Filament"-Sensor 28. April 2015 06:23 |
Re: "Out of Filament"-Sensor 28. April 2015 07:11 |
Re: "Out of Filament"-Sensor 28. April 2015 16:16 |
Re: "Out of Filament"-Sensor 28. April 2015 18:08 |
//=========================================================================== //============================= Filament Runout Sensor ====================== //=========================================================================== #define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament // In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made. // It is assumed that when logic high = filament available // when logic low = filament ran out const bool FIL_RUNOUT_INVERTING = true; // Should be uncommented and true or false should assigned #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
#ifdef ULTIPANEL #define FILAMENTCHANGEENABLE
Re: "Out of Filament"-Sensor 01. May 2015 15:04 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 99 |
Re: "Out of Filament"-Sensor 03. May 2015 08:42 |
Re: "Out of Filament"-Sensor 03. May 2015 17:58 |
