Prusa i2 - zAchse Schrittverluste 28. May 2015 16:58 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 14 |
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 03:23 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 208 |
#define HOMING_FEEDRATE {100, 100, 100, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,135.8246} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {250, 250, 3, 100} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {2000,3000,2.5,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 500 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 10000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 2.5 // (mm/sec)
#define DEFAULT_ZJERK 0.0 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 07:06 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 77 |
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,592.1573} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {250, 250, 2.5, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {4000,4000,5,4000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 08:41 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 4.977 |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 09:47 |
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 09:58 |
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 10:31 |
Bin davon ausgegangen das es eigentlich übern Daumen doppelt so hoch sein sollte.
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 10:47 |
Registrierungsdatum: 16 Jahre zuvor Beiträge: 3.742 |
Re: Prusa i2 - zAchse Schrittverluste 29. May 2015 10:52 |
