OpenScad Library Probleme? 29. December 2015 03:01 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 152 |
// Challenge coin generator.
// All dimensions in millimeters.
// preview[view:south, tilt:top diagonal]
use
/* [Text] */
TOP_TEXT = "Hello, World";
BOTTOM_TEXT = "August 2013";
REVERSE_TOP = "Reverse Top";
REVERSE_BOTTOM = "Bottom";
/* [Coin Properties] */
// (mm)
DIAMETER = 39;
// (mm)
THICKNESS = 3.2;
/* [Text Properties] */
// Letter height (mm)
TEXT_HEIGHT = 5.0;
// ratio (1.0 is nominal)
SPACING = 0.8;
// Print height (mm)
RELIEF = 1.0;
/* [Hidden] */
// Epsilon
E = 0.01;
module coin(
top_text="", // Text of centered top text
bottom_text="", // Text of centered bottom text
rev_top_text="", // Reverse top text
rev_bottom_text="", // Reverse bottom text
size=DIAMETER, // Diameter of coin
thickness=THICKNESS, // Total coin thickness
relief=RELIEF, // Height of raised (relief) features
text_height=TEXT_HEIGHT, // Height of a text letter
spacing=SPACING, // 1.0 == nominal spacing (ratio)
rim_width=0.5 // Rim edge thickness
difference() {
union() {
cylinder(r=size / 2, h=thickness - relief, $fa=3);
translate([0, 0, thickness - relief - E])
face(top_text, bottom_text, size, relief + E, text_height, spacing, rim_width);
translate([0, 0, relief])
rotate(a=180, v=[1, 0, 0])
face(rev_top_text, rev_bottom_text, size, relief + E, text_height, spacing, rim_width,
rim=false);
module face(
size=39, // Diameter of coin
relief=0.5, // Height of raised (relief) features
text_height=5.0, // Height of a text letter
spacing=1.0, // 1.0 == nominal spacing (ratio)
rim_width=0.5, // Rim edge thickness
rim=true, // Boolean control drawing rim ridge
image_file="" // Optional face image (DXF file)
if (rim) {
ring(r=size / 2, thickness=rim_width, height=relief);
arc_text(top_text, size / 2 - rim_width * 4, text_height, relief, spacing, true);
arc_text(bottom_text, size / 2 - rim_width * 4, text_height, relief, spacing, false);
if (image_file != "") {
linear_extrude(height=relief, center=true, convexity=10)
import_dxf(file=image_file, layer="none");
module arc_text(
text,
r,
text_height=3.0,
height=1.0,
spacing=1.0,
top=true
ang = spacing * atan2(text_height, r);
start_ang = (len(text) - 1) / 2 * ang;
ang_sgn = top ? -1 : 1;
offset_sgn = top ? 1 : -1;
for (i = [0 : len(text) - 1]) {
rotate(a=ang_sgn * (ang * i - start_ang), v=[0, 0, 1])
translate([0, offset_sgn * (r - text_height / 2), height / 2])
write(text, h=text_height, t=height, center=true);
// Ring around origin (at z=0)
module ring(r, thickness, height) {
translate([0, 0, height / 2]) {
difference() {
cylinder(h=height, r=r, $fa=3, center=true);
cylinder(h=height + 2 * E, r=r - thickness, $fa=3, center=true);
coin(top_text=TOP_TEXT,
bottom_text=BOTTOM_TEXT,
rev_top_text=REVERSE_TOP,
rev_bottom_text=REVERSE_BOTTOM
Wenn ich dann die F5 Taste drücke das ich die fertige Schrift angezeigt bekomme schreibt er mir den Fehler aus WARNING: Can't open library 'write/Write.scad'. und ignoriert das Modul Write. Habe es auch mal in der VM unter Windows 7 OpenScad installiert und dort geschaut und auch der selbe Fehler. Installiert ist: OpenSCAD version 2015.03-1 unter Linux und bei Windows: OpenSCAD version 2015.03-2|
Re: OpenScad Library Probleme? 29. December 2015 03:53 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.610 |
Re: OpenScad Library Probleme? 29. December 2015 11:23 |
