Temperatur Anzeige und Realität... 16. August 2016 16:17 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 22 |
Re: Temperatur Anzeige und Realität... 16. August 2016 17:19 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 632 |
Re: Temperatur Anzeige und Realität... 18. August 2016 13:03 |
//=========================================================================== //=============================Thermal Settings ============================ //=========================================================================== // //--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table // //// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is Mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // 11 is 100k beta 3950 1% thermistor (4.7k pullup) // 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) // 20 is the PT100 circuit found in the Ultimainboard V2.x // 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup) // // 1047 is Pt1000 with 4k7 pullup // 1010 is Pt1000 with 1k pullup (non standard) // 147 is Pt100 with 4k7 pullup // 110 is Pt100 with 1k pullup (non standard) // 70 is 500C thermistor for Pico hot end #define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 -1 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1
Re: Temperatur Anzeige und Realität... 18. August 2016 13:37 |
Re: Temperatur Anzeige und Realität... 18. August 2016 14:22 |
Re: Temperatur Anzeige und Realität... 18. August 2016 16:23 |
Re: Temperatur Anzeige und Realität... 18. August 2016 16:43 |
Haha, der war gut ... Der Verkäufer ist nicht mal fähig zwischen Firmware und Slicer zu unterscheiden...Den brauche ich dazu bestimmt nicht fragen .Quote
Pieps
...In der thermistortables.h findest du die ganzen Wertetabellen dazu. Nützt dir aber auch nicht so viel. Du müsstest erst deine Wertetabelle haben. Bzw. erst mal die Bezeichnung deines Thermistors.
Am Besten du fragst deinen Verkäufer.
Re: Temperatur Anzeige und Realität... 19. August 2016 00:28 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
Re: Temperatur Anzeige und Realität... 20. August 2016 12:59 |
Re: Temperatur Anzeige und Realität... 21. August 2016 01:22 |
Re: Temperatur Anzeige und Realität... 21. August 2016 01:30 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Temperatur Anzeige und Realität... 21. August 2016 15:21 |
