Slic3r: Bindenaht/ Seam Position festlegen 13. February 2017 11:49 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 422 |
Random - This will choose a different point for each layer, thus making the seam less noticeable. Nearest - This will try to choose a concave non-overhang vertex so that the seam is hidden in the inside of the concave angle. If no concave non-overhang vertices are available, it will choose a convex non-overhang vertex. If none are available, it will choose a non-overhang vertex. The choice among the candidates is operated so that the start point is the nearest to the previous extruder position. So this option will optimize for short travels. Aligned - This will use the same logic as Nearest for finding the candidates, but it will choose the one that is nearest to the start point of the previous layer. This will ensure the seam is mostly aligned throughout the whole object.
Re: Slic3r: Bindenaht/ Seam Position festlegen 13. February 2017 13:47 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 57 |
Added an experimental "rear" seam option. While Slic3r is good at hiding seams into corners, there are no corners on round objects. The "rear" seam option moves those seams to the rear side of the object. It is left to the user to orient the object with the less important details facing the rear side of the print bed.
Re: Slic3r: Bindenaht/ Seam Position festlegen 13. February 2017 15:20 |
Re: Slic3r: Bindenaht/ Seam Position festlegen 14. February 2017 06:51 |
Re: Slic3r: Bindenaht/ Seam Position festlegen 14. February 2017 08:48 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.604 |
Slic3r ist nach wie vor mein Liebling. Ich sehe S3D nur bei Support vorne...|
Re: Slic3r: Bindenaht/ Seam Position festlegen 15. February 2017 03:17 |
