K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 15:04 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 29 |
//=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // Uncomment the following line to enable CoreXY kinematics // #define COREXY // corse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. //#define DISABLE_MAX_ENDSTOPS // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z true #define DISABLE_E false // For all extruders #define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true //If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 200 #define X_MIN_POS 0 #define Y_MAX_POS 200 #define Y_MIN_POS 0 #define Z_MAX_POS 220 #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS) // The position of the homing switches //#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 0 //// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {64.25,64.25,2133.333,600} // default steps per unit for ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 5, 500} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 15:33 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 15:55 |
AlterBastler
Das ist alles:
// #define ENDSTOPPULLUP_XMAX ;Striche weg ... #define X_HOME_DIR -1 ;auf 1 setzenHerzl. Grüße
muss ich bei #define ENDSTOPPULLUP_XMIN noch die // Striche davor machen?
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 17:06 |
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 17:20 |
AlterBastler
#define INVERT_X_DIR false ;auf true ändert die Richtung
Die Richtung beim Homen wird durch X_HOME_DIR bestimmt. Bei 1 fährt er nach Max, bei -1 nach Min.
Die Pullup-Einstellung für X_MIN kannst Du auskommentieren, spielt aber keine Rolle.
Herzl. Grüße
#define ENDSTOPPULLUP_XMAX ; Der Endstop MAX wird aktiv // #define ENDSTOPPULLUP_XMIN ; "//" Striche hinzufügen, der Endstop MIN wird deaktiviert ... #define INVERT_X_DIR true ; Heißt, das die Richtung des Motors generell umgedreht wird ... #define X_HOME_DIR 1 ; Heißt, beim Homen fährt dieser auf MAX, sprich der Motor dreht in die andere Richtung wie MIN
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 17:27 |
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 17:33 |
AlterBastler
Ja. Wobei der Pullup den Endstop nicht "aktiviert".
Der Pullup ist erforderlich, weil hier der Endstop gegen Masse schaltet.
Am Pin liegt dadurch eine 1 (High) an, bei betätigtem Endstop eine 0 (Low).
Herzl. Grüße
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 23. December 2017 17:39 |
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 28. December 2017 15:38 |
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 28. December 2017 17:11 |
// The position of the homing switches #define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: #define MANUAL_X_HOME_POS 200Herzl. Grüße
Re: K8200: Software / Firmware Änderung bzgl. Umbau X-Achse vom Tisch zu Extruder 28. December 2017 17:32 |
AlterBastler
Tut mir leid, kann ich nicht nachvollziehen. Ist auch eine ältere Marlin-Version.
Ich kann nur raten. Versuch das mal:
