TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 01. June 2019 16:28 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 448 |
Re: TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 03. June 2019 15:02 |
#define X_CS_PIN 64 #define Y_CS_PIN 40 #define Z_CS_PIN 42 #define E0_CS_PIN 44 #define TMC_SW_MOSI 66 #define TMC_SW_MISO 44 #define TMC_SW_SCK 64
/** * Stepper Drivers * * These settings allow Marlin to tune stepper driver timing and enable advanced options for * stepper drivers that support them. You may also override timing options in Configuration_adv.h. * * A4988 is assumed for unspecified drivers. * * Options: A4988, A5984, DRV8825, LV8729, L6470, TB6560, TB6600, TMC2100, * TMC2130, TMC2130_STANDALONE, TMC2208, TMC2208_STANDALONE, * TMC26X, TMC26X_STANDALONE, TMC2660, TMC2660_STANDALONE, * TMC2160, TMC2160_STANDALONE, TMC5130, TMC5130_STANDALONE, * TMC5160, TMC5160_STANDALONE * :['A4988', 'A5984', 'DRV8825', 'LV8729', 'L6470', 'TB6560', 'TB6600', 'TMC2100', 'TMC2130', 'TMC2130_STANDALONE', 'TMC2160', 'TMC2160_STANDALONE', 'TMC2208', 'TMC2208_STANDALONE', 'TMC26X', 'TMC26X_STANDALONE', 'TMC2660', 'TMC2660_STANDALONE', 'TMC5130', 'TMC5130_STANDALONE', 'TMC5160', 'TMC5160_STANDALONE'] */ #define X_DRIVER_TYPE TMC5160 //TMC zugewiesen #define Y_DRIVER_TYPE TMC2130 //TMC zugewiesen #define Z_DRIVER_TYPE TMC2130 //TMC zugewiesen //#define X2_DRIVER_TYPE A4988 //#define Y2_DRIVER_TYPE A4988 //#define Z2_DRIVER_TYPE A4988 //#define Z3_DRIVER_TYPE A4988 #define E0_DRIVER_TYPE TMC2130 //TMC zugewiesen //#define E1_DRIVER_TYPE A4988 //#define E2_DRIVER_TYPE A4988 //#define E3_DRIVER_TYPE A4988 //#define E4_DRIVER_TYPE A4988 //#define E5_DRIVER_TYPE A4988
/** * To use TMC2130, TMC2160, TMC2660, TMC5130, TMC5160 stepper drivers in SPI mode * connect your SPI pins to the hardware SPI interface on your board and define * the required CS pins in your `pins_MYBOARD.h` file. (e.g., RAMPS 1.4 uses AUX3 * pins `X_CS_PIN 53`, `Y_CS_PIN 49`, etc.). <<-- Sind an die verwendeten Pins angepasst * You may also use software SPI if you wish to use general purpose IO pins. * * To use TMC2208 stepper UART-configurable stepper drivers connect #_SERIAL_TX_PIN * to the driver side PDN_UART pin with a 1K resistor. * To use the reading capabilities, also connect #_SERIAL_RX_PIN to PDN_UART without * a resistor. * The drivers can also be used with hardware serial. * * TMCStepper library is required to use TMC stepper drivers. * [github.com] #if HAS_TRINAMIC #define HOLD_MULTIPLIER 0.5 // Scales down the holding current from run current #define INTERPOLATE true // Interpolate X/Y/Z_MICROSTEPS to 256 #if AXIS_IS_TMC(X) #define X_CURRENT 1000 // (mA) RMS current. Multiply by 1.414 for peak current. #define X_MICROSTEPS 16 // 0..256 #define X_RSENSE 0.11 #endif …. #if AXIS_IS_TMC(Y) #define Y_CURRENT 1000 #define Y_MICROSTEPS 16 #define Y_RSENSE 0.11 … #if AXIS_IS_TMC(Z) #define Z_CURRENT 1000 #define Z_MICROSTEPS 16 #define Z_RSENSE 0.11 … #if AXIS_IS_TMC(E0) #define E0_CURRENT 1000 #define E0_MICROSTEPS 16 #define E0_RSENSE 0.11 … /** * Override default SPI pins for TMC2130, TMC2160, TMC2660, TMC5130 and TMC5160 drivers here. * The default pins can be found in your board's pins file. */ #define X_CS_PIN 64 #define Y_CS_PIN 40 #define Z_CS_PIN 42 //#define X2_CS_PIN -1 //#define Y2_CS_PIN -1 //#define Z2_CS_PIN -1 //#define Z3_CS_PIN -1 #define E0_CS_PIN 44 … /** * Use software SPI for TMC2130. * Software option for SPI driven drivers (TMC2130, TMC2160, TMC2660, TMC5130 and TMC5160). * The default SW SPI pins are defined the respective pins files, * but you can override or define them here. */ #define TMC_USE_SW_SPI #define TMC_SW_MOSI 66 #define TMC_SW_MISO 44 #define TMC_SW_SCK 64 /** * Software enable * * Use for drivers that do not use a dedicated enable pin, but rather handle the same * function through a communication line such as SPI or UART. */ #define SOFTWARE_DRIVER_ENABLE … * TMC2130, TMC2160, TMC2208, TMC5130 and TMC5160 only * Use Trinamic's ultra quiet stepping mode. * When disabled, Marlin will use spreadCycle stepping mode. */ #define STEALTHCHOP_XY #define STEALTHCHOP_Z #define STEALTHCHOP_E … #define CHOPPER_TIMING CHOPPER_DEFAULT_24V #if ENABLED(MONITOR_DRIVER_STATUS) #define CURRENT_STEP_DOWN 50 // [mA] #define REPORT_CURRENT_CHANGE #define STOP_ON_ERROR #endif /** * TMC2130, TMC2160, TMC2208, TMC5130 and TMC5160 only * The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD. * This mode allows for faster movements at the expense of higher noise levels. * STEALTHCHOP_(XY|Z|E) must be enabled to use HYBRID_THRESHOLD. * M913 X/Y/Z/E to live tune the setting */ #define HYBRID_THRESHOLD //aktivier 21.5.19 #define X_HYBRID_THRESHOLD 100 // [mm/s] //ist 1 bei Marlin 1.9.x #define X2_HYBRID_THRESHOLD 100 #define Y_HYBRID_THRESHOLD 100 //ist 1 bei Marlin 1.9.x #define Y2_HYBRID_THRESHOLD 100 #define Z_HYBRID_THRESHOLD 1 #define Z2_HYBRID_THRESHOLD 3 #define Z3_HYBRID_THRESHOLD 3 #define E0_HYBRID_THRESHOLD 0.1 …
Re: TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 04. June 2019 14:51 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 360 |
Re: TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 05. June 2019 02:27 |
Re: TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 17. June 2019 18:45 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 1 |
pins_MKS_GEN_L.h
// CS Pins wired to avoid conflict with the LCD
// See [www.thingiverse.com]
#ifndef X_CS_PIN
#define X_CS_PIN 59
#endif
#ifndef Y_CS_PIN
#define Y_CS_PIN 63
#endif
#include "pins_RAMPS.h"
configuration.h
#define Y_DRIVER_TYPE TMC5160
#define Z_DRIVER_TYPE TMC2100
#define E0_DRIVER_TYPE TMC2100
configuration_adv.h
#if HAS_TRINAMIC
#if AXIS_IS_TMC(X)
#define X_CURRENT 760 // (mA) RMS current. Multiply by 1.414 for peak current.
#define X_RSENSE 0.075
#endif
#if AXIS_IS_TMC(Y)
#define Y_CURRENT 760
#define Y_RSENSE 0.075
#endif
#if AXIS_IS_TMC(Z)
#define Z_CURRENT 800
#endif
#if AXIS_IS_TMC(E0)
#define E0_CURRENT 800
#endif
Re: TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 03. July 2021 12:21 |
Registrierungsdatum: 2 Jahre zuvor Beiträge: 2 |
Re: TMC5160 (Watterott) mit Marlin 2.x auf Ramps 1.4 04. July 2021 04:55 |
