Hello everybody,
I have a AnyCubic i3+, not the mega, and I'm trying to modify it, to print chocolate, but after I mounted the extension pack, I wanted to print. I didn't worked, because the Extruder wanted to be at atleast 180°, so I run a file that should set the temperature limit down, but after I run the file, the Heat Bed didn't moved anymore. So because I already know a little bit C, I installed marlin 1.1.9, tried to calibrate it with the files I found online, but a bunch of errors came back. So I tried it with the Anet A8 software (that was already as example in the downloaded files for marlin), because they are actually pretty similar. Everything went fine, until I restarted the 3D-Printer. Then the LCD-Screen turned on, but nothing appeared, besides of every second line completely filled with white blocks. Now I waited about 15 minutes, and still nothing happens.
