PrusaSlicer 2.1.0 - Custom G-Codes ? 02. November 2019 12:15 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 350 |
M109 S220 ; set temperature and wait for it to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; Filament gcode !!!!! Failed to process the custom G-code template before_layer_gcode Parsing error at line 1. {if [layer_num] == 1}M221 S110 ^ !!!!! End of an error report for the custom G-code template before_layer_gcode G1 Z0.200 F7800.000 G1 E-6.50000 F2400.00000 G92 E0 G1 X13.610 Y7.597 F7800.000 G1 E6.50000 F2400.00000
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 04. November 2019 07:10 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Lass die eckigen Klammern weg.Quote
Note: This language is only available in Slic3r PE and is not compatible with Slic3r conditional expressions.
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 04. November 2019 11:37 |
AlterBastler
!!!!! Failed to process the custom G-code template before_layer_gcode Parsing error at line 1. Expecting tag literal-char {if layer_num == 1} M221 S110 ^ !!!!! End of an error report for the custom G-code template before_layer_gcode
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 04. November 2019 13:38 |
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 04. November 2019 14:32 |
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 06. November 2019 10:51 |
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 07. November 2019 08:40 |
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 11. November 2019 08:05 |
Also the variables are printed out on the command line (run prusa-slicer with the --help-fff resp. --help-sla for FFF resp. SLA parameters
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 11. November 2019 09:28 |
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 12. November 2019 07:03 |
Re: PrusaSlicer 2.1.0 - Custom G-Codes ? 12. November 2019 13:58 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.112 |
AlterBastler
Mach es mal so:
M221 S{if layer_num == 1}110{else}100{endif}
Herzl. Grüße
