RADDS 1.6 und BLTOUCH funktionieren nicht 07. March 2020 22:55 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 7 |
#define FEATURE_SERVO 1 #define SERVO0_PIN 5 #define SERVO1_PIN -1 #define SERVO2_PIN -1 #define SERVO3_PIN -1 #define SERVO0_NEUTRAL_POS 1500 #define SERVO1_NEUTRAL_POS -1 #define SERVO2_NEUTRAL_POS -1 #define SERVO3_NEUTRAL_POS -1 #define UI_SERVO_CONTROL 0 #define FAN_KICKSTART_TIME 200 #define MAX_FAN_PWM 255 #define FEATURE_WATCHDOG 1 // #################### Z-Probing ##################### #define Z_PROBE_Z_OFFSET 0 #define Z_PROBE_Z_OFFSET_MODE 0 #define UI_BED_COATING 1 #define FEATURE_Z_PROBE 1 #define EXTRUDER_IS_Z_PROBE 0 #define Z_PROBE_DISABLE_HEATERS 0 #define Z_PROBE_BED_DISTANCE 5 #define Z_PROBE_PIN ORIG_Z_MIN_PIN #define Z_PROBE_PULLUP 1 #define Z_PROBE_ON_HIGH 1 #define Z_PROBE_X_OFFSET 46.8 #define Z_PROBE_Y_OFFSET -50.45 #define Z_PROBE_WAIT_BEFORE_TEST 0 #define Z_PROBE_SPEED 4 #define Z_PROBE_XY_SPEED 150 #define Z_PROBE_SWITCHING_DISTANCE 4 #define Z_PROBE_REPETITIONS 2 #define Z_PROBE_USE_MEDIAN 0 #define Z_PROBE_HEIGHT 0 #define Z_PROBE_DELAY 0 #define Z_PROBE_START_SCRIPT "M340 P0 S700" #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500" #define Z_PROBE_RUN_AFTER_EVERY_PROBE "" #define Z_PROBE_REQUIRES_HEATING 0 #define Z_PROBE_MIN_TEMPERATURE 150 #define FEATURE_AUTOLEVEL 1 #define FEATURE_SOFTWARE_LEVELING 0 #define Z_PROBE_X1 60 #define Z_PROBE_Y1 60 #define Z_PROBE_X2 240 #define Z_PROBE_Y2 60 #define Z_PROBE_X3 60 #define Z_PROBE_Y3 240 #define BED_LEVELING_METHOD 0 #define BED_CORRECTION_METHOD 1 #define BED_LEVELING_GRID_SIZE 3 #define BED_LEVELING_REPETITIONS 5 #define BED_MOTOR_1_X 150 #define BED_MOTOR_1_Y 338 #define BED_MOTOR_2_X -92 #define BED_MOTOR_2_Y -4 #define BED_MOTOR_3_X 392 #define BED_MOTOR_3_Y -4 #define BENDING_CORRECTION_A 0 #define BENDING_CORRECTION_B 0 #define BENDING_CORRECTION_C 0 #define FEATURE_AXISCOMP 0 #define AXISCOMP_TANXY 0 #define AXISCOMP_TANYZ 0 #define AXISCOMP_TANXZ 0
Re: RADDS 1.6 und BLTOUCH funktionieren nicht 08. March 2020 03:22 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: RADDS 1.6 und BLTOUCH funktionieren nicht 14. March 2020 23:57 |
Re: RADDS 1.6 und BLTOUCH funktionieren nicht 15. March 2020 11:20 |
Re: RADDS 1.6 und BLTOUCH funktionieren nicht 17. March 2020 06:58 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 26 |
Re: RADDS 1.6 und BLTOUCH funktionieren nicht 17. March 2020 08:10 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 3.969 |
AlterBastler
Ich kenne mich mit Repetier nicht aus, aber nach meinem Verständnis ist Z_PROBE_HEIGHT ein positiver Wert
und Z_PROBE_Z_OFFSET ist nur für kapazitive oder induktive Sensoren relevant.
[www.repetier.com]
Herzl. Grüße
