Pi 3 reset full-speed USB device --> disconnect 31. March 2020 10:38 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 46 |
2020-03-31 12:42:06: start printjob KettenradLaufradRadkappe on printer FireXX 2020-03-31 12:45:14: error: Reading serial conection failed: End of file. Closing connection. 2020-03-31 12:45:14: Port closed for FireXX 2020-03-31 12:45:14: Connection closed: FireXX 2020-03-31 12:45:44: Connection started: FireXX 2020-03-31 12:45:44: Reset printer FireXX 2020-03-31 12:46:18: Starting print recover KettenradLaufradRadkappe 2020-03-31 12:46:18: start printjob KettenradLaufradRadkappe on printer FireXX 2020-03-31 12:46:35: killing printjob KettenradLaufradRadkappe on printer FireXX
[Tue Mar 31 12:36:40 2020] sda: sda1 [Tue Mar 31 12:39:41 2020] sd 0:0:0:0: timing out command, waited 180s [Tue Mar 31 12:39:41 2020] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 [Tue Mar 31 12:39:41 2020] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current] [Tue Mar 31 12:39:41 2020] sd 0:0:0:0: [sda] tag#0 ASC=0x0 ASCQ=0x0 [Tue Mar 31 12:39:41 2020] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 1e 44 f8 00 00 08 00 [Tue Mar 31 12:39:41 2020] print_req_error: I/O error, dev sda, sector 1983736 [Tue Mar 31 12:42:26 2020] INFO: task systemd-udevd:1032 blocked for more than 120 seconds. [Tue Mar 31 12:42:26 2020] Tainted: G C 4.19.106-v7+ #1297 [Tue Mar 31 12:42:26 2020] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [Tue Mar 31 12:42:26 2020] systemd-udevd D 0 1032 142 0x00000085 [Tue Mar 31 12:42:26 2020] [<8086274c>] (__schedule) from [<80862dbc>] (schedule+0x50/0xa8) [Tue Mar 31 12:42:26 2020] [<80862dbc>] (schedule) from [<808632f4>] (io_schedule+0x20/0x40) [Tue Mar 31 12:42:26 2020] [<808632f4>] (io_schedule) from [<8025a3f0>] (__lock_page+0x11c/0x174) [Tue Mar 31 12:42:26 2020] [<8025a3f0>] (__lock_page) from [<802724b4>] (truncate_inode_pages_range+0x40c/0x888) [Tue Mar 31 12:42:26 2020] [<802724b4>] (truncate_inode_pages_range) from [<80272958>] (truncate_inode_pages+0x28/0x30) [Tue Mar 31 12:42:26 2020] [<80272958>] (truncate_inode_pages) from [<80311fd4>] (kill_bdev+0x48/0x4c) [Tue Mar 31 12:42:26 2020] [<80311fd4>] (kill_bdev) from [<803140d8>] (__blkdev_put+0x88/0x230) [Tue Mar 31 12:42:26 2020] [<803140d8>] (__blkdev_put) from [<803142d4>] (blkdev_put+0x54/0x160) [Tue Mar 31 12:42:26 2020] [<803142d4>] (blkdev_put) from [<80314408>] (blkdev_close+0x28/0x30) [Tue Mar 31 12:42:26 2020] [<80314408>] (blkdev_close) from [<802d1d9c>] (__fput+0xa4/0x1e8) [Tue Mar 31 12:42:26 2020] [<802d1d9c>] (__fput) from [<802d1f50>] (____fput+0x18/0x1c) [Tue Mar 31 12:42:26 2020] [<802d1f50>] (____fput) from [<80140afc>] (task_work_run+0xbc/0xe0) [Tue Mar 31 12:42:26 2020] [<80140afc>] (task_work_run) from [<8012533c>] (do_exit+0x44c/0xc18) [Tue Mar 31 12:42:26 2020] [<8012533c>] (do_exit) from [<80125ba0>] (do_group_exit+0x4c/0xe4) [Tue Mar 31 12:42:26 2020] [<80125ba0>] (do_group_exit) from [<80131ba0>] (get_signal+0x1a4/0x8cc) [Tue Mar 31 12:42:26 2020] [<80131ba0>] (get_signal) from [<8010c908>] (do_signal+0x274/0x474) [Tue Mar 31 12:42:26 2020] [<8010c908>] (do_signal) from [<8010cd14>] (do_work_pending+0xdc/0xf4) [Tue Mar 31 12:42:26 2020] [<8010cd14>] (do_work_pending) from [<80101034>] (slow_work_pending+0xc/0x20) [Tue Mar 31 12:42:26 2020] Exception stack(0xa91f3fb0 to 0xa91f3ff8) [Tue Mar 31 12:42:26 2020] 3fa0: fffffffc 01dde8f0 00000200 00000000 [Tue Mar 31 12:42:26 2020] 3fc0: 01df991c 00000000 01df98d0 00000003 01dde8d0 01dde8e8 76da91e0 00000000 [Tue Mar 31 12:42:26 2020] 3fe0: 0000006c 7e99add0 76d5e2c0 76eac880 60000010 0000000f [Tue Mar 31 12:42:41 2020] sd 0:0:0:0: timing out command, waited 180s [Tue Mar 31 12:42:41 2020] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 [Tue Mar 31 12:42:41 2020] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current] [Tue Mar 31 12:42:41 2020] sd 0:0:0:0: [sda] tag#0 ASC=0x0 ASCQ=0x0 [Tue Mar 31 12:42:41 2020] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 1e 44 f8 00 00 08 00 [Tue Mar 31 12:42:41 2020] print_req_error: I/O error, dev sda, sector 1983736 [Tue Mar 31 12:42:41 2020] Buffer I/O error on dev sda, logical block 247967, async page read [Tue Mar 31 12:45:14 2020] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg [Tue Mar 31 12:45:14 2020] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device [Tue Mar 31 12:45:14 2020] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x03 driverbyte=0x00 [Tue Mar 31 12:45:14 2020] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 1e 45 80 00 00 08 00 [Tue Mar 31 12:45:14 2020] print_req_error: I/O error, dev sda, sector 1983872 [Tue Mar 31 12:45:14 2020] dwc_otg: DEVICE:004 : update_urb_state_xfer_comp:751:trimming xfer length [Tue Mar 31 12:45:14 2020] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg [Tue Mar 31 12:45:14 2020] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device [Tue Mar 31 12:45:14 2020] sd 0:0:0:0: timing out command, waited 60s
[Tue Mar 31 14:31:17 2020] sd 0:0:0:0: timing out command, waited 180s [Tue Mar 31 14:31:17 2020] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 [Tue Mar 31 14:31:17 2020] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current] [Tue Mar 31 14:31:17 2020] sd 0:0:0:0: [sda] tag#0 ASC=0x0 ASCQ=0x0 [Tue Mar 31 14:31:17 2020] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 1e 45 80 00 00 08 00 [Tue Mar 31 14:31:17 2020] print_req_error: I/O error, dev sda, sector 1983872 [Tue Mar 31 14:31:17 2020] Buffer I/O error on dev sda, logical block 247984, async page read [Tue Mar 31 14:34:17 2020] sd 0:0:0:0: timing out command, waited 180s [Tue Mar 31 14:34:17 2020] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 [Tue Mar 31 14:34:17 2020] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current] [Tue Mar 31 14:34:17 2020] sd 0:0:0:0: [sda] tag#0 ASC=0x0 ASCQ=0x0 [Tue Mar 31 14:34:17 2020] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 1e 45 80 00 00 08 00 [Tue Mar 31 14:34:17 2020] print_req_error: I/O error, dev sda, sector 1983872 [Tue Mar 31 14:37:07 2020] INFO: task systemd-udevd:23913 blocked for more than 120 seconds. [Tue Mar 31 14:37:07 2020] Tainted: G C 4.19.106-v7+ #1297 [Tue Mar 31 14:37:07 2020] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Re: Pi 3 reset full-speed USB device --> disconnect 03. April 2020 15:19 |
/** * Select the serial port on the board to use for communication with the host. * This allows the connection of wireless adapters (for instance) to non-default port pins. * Note: The first serial port (-1 or 0) will always be used by the Arduino bootloader. * * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ #define SERIAL_PORT -1 /** * Select a secondary serial port on the board to use for communication with the host. * This allows the connection of wireless adapters (for instance) to non-default port pins. * Serial port -1 is the USB emulated serial port, if available. * * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ #define SERIAL_PORT_2 0
