Marlin Konfiguration für Deltas 12. April 2021 08:36 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 136 |
//=========================================================================== //============================== Endstop Settings =========================== //=========================================================================== // @section homing // Specify here all the endstop connectors that are connected to any endstop or probe. // Almost all printers will be using one per axis. Probes will use one or more of the // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. // #define USE_XMIN_PLUG // #define USE_YMIN_PLUG #define USE_ZMIN_PLUG #define USE_XMAX_PLUG #define USE_YMAX_PLUG #define USE_ZMAX_PLUG // Enable pullup for all endstops to prevent a floating state #define ENDSTOPPULLUPS #if DISABLED(ENDSTOPPULLUPS) // Disable ENDSTOPPULLUPS to set pullups individually //#define ENDSTOPPULLUP_XMAX //#define ENDSTOPPULLUP_YMAX //#define ENDSTOPPULLUP_ZMAX //#define ENDSTOPPULLUP_XMIN //#define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN //#define ENDSTOPPULLUP_ZMIN_PROBE #endif // Enable pulldown for all endstops to prevent a floating state //#define ENDSTOPPULLDOWNS #if DISABLED(ENDSTOPPULLDOWNS) // Disable ENDSTOPPULLDOWNS to set pulldowns individually //#define ENDSTOPPULLDOWN_XMAX //#define ENDSTOPPULLDOWN_YMAX //#define ENDSTOPPULLDOWN_ZMAX //#define ENDSTOPPULLDOWN_XMIN //#define ENDSTOPPULLDOWN_YMIN //#define ENDSTOPPULLDOWN_ZMIN //#define ENDSTOPPULLDOWN_ZMIN_PROBE #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // Set to true to invert the logic of the probe. ====================================================================== // @section homing //#define NO_MOTION_BEFORE_HOMING // Inhibit movement until all axes have been homed. Also enable HOME_AFTER_DEACTIVATE for extra safety. //#define HOME_AFTER_DEACTIVATE // Require rehoming after steppers are deactivated. Also enable NO_MOTION_BEFORE_HOMING for extra safety. /** * Set Z_IDLE_HEIGHT if the Z-Axis moves on its own when steppers are disabled. * - Use a low value (i.e., Z_MIN_POS) if the nozzle falls down to the bed. * - Use a large value (i.e., Z_MAX_POS) if the bed falls down, away from the nozzle. */ //#define Z_IDLE_HEIGHT Z_HOME_POS //#define Z_HOMING_HEIGHT 4 // (mm) Minimal Z height before homing (G28) for Z clearance above the bed, clamps, ... // Be sure to have this much clearance over your Z_MAX_POS to prevent grinding. //#define Z_AFTER_HOMING 10 // (mm) Height to move to after homing Z // Direction of endstops when homing; 1=MAX, -1=MIN // Deltas have three max endstops. For other configurations set these values appropriately. // :[-1,1] #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR 1 // @section machine // The size of the print bed #define X_BED_SIZE ((DELTA_PRINTABLE_RADIUS) * 2) #define Y_BED_SIZE ((DELTA_PRINTABLE_RADIUS) * 2) // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS -(DELTA_PRINTABLE_RADIUS) #define Y_MIN_POS -(DELTA_PRINTABLE_RADIUS) #define Z_MIN_POS 0 #define X_MAX_POS (DELTA_PRINTABLE_RADIUS) #define Y_MAX_POS (DELTA_PRINTABLE_RADIUS) #define Z_MAX_POS MANUAL_Z_HOME_POS /** * Software Endstops * * - Prevent moves outside the set machine bounds. * - Individual axes can be disabled, if desired. * - X and Y only apply to Cartesian robots. * - Use 'M211' to set software endstops on/off or report current state */ // Min software endstops constrain movement within minimum coordinate bounds #define MIN_SOFTWARE_ENDSTOPS #if ENABLED(MIN_SOFTWARE_ENDSTOPS) #define MIN_SOFTWARE_ENDSTOP_X #define MIN_SOFTWARE_ENDSTOP_Y #define MIN_SOFTWARE_ENDSTOP_Z #endif // Max software endstops constrain movement within maximum coordinate bounds #define MAX_SOFTWARE_ENDSTOPS #if ENABLED(MAX_SOFTWARE_ENDSTOPS) #define MAX_SOFTWARE_ENDSTOP_X #define MAX_SOFTWARE_ENDSTOP_Y #define MAX_SOFTWARE_ENDSTOP_Z #endif
Re: Marlin Konfiguration für Deltas 12. April 2021 14:49 |
1. Wenn beim Einschalten die Achsen irgendwo in der Mitte stehen, kann ich sie nur in eine Richtung (+) bewegen. Warum nicht auch in die andere (-) ?
Antwort:
1. Das ist Absicht, vor dem Homen kannst Du nur in Richtung Endstop fahren, das soll Beschädigungen des Druckers verhindern.
#define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR 1zu
#define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1Ändern.
Re: Marlin Konfiguration für Deltas 13. April 2021 05:36 |
Registrierungsdatum: 5 Jahre zuvor Beiträge: 143 |
Re: Marlin Konfiguration für Deltas 15. April 2021 15:58 |
#define IGNORE_ENDSTOPS_AND_DESTROY_BELTSoder so?
// Direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR 1
Re: Marlin Konfiguration für Deltas 16. April 2021 03:09 |
Moderator Registrierungsdatum: 6 Jahre zuvor Beiträge: 820 |
Re: Marlin Konfiguration für Deltas 16. April 2021 05:49 |
Re: Marlin Konfiguration für Deltas 16. April 2021 07:21 |
Junkie
Und dass der Kompiler durch Zugriff auf die pins.h weißt welchen Pin er wie definieren muss
#define_board
Re: Marlin Konfiguration für Deltas 16. April 2021 13:06 |
// // TMC StallGuard DIAG pins // #define X_DIAG_PIN P1_29 // X-STOP #define Y_DIAG_PIN P1_28 // Y-STOP #define Z_DIAG_PIN P1_27 // Z-STOP #define E0_DIAG_PIN P1_26 // E0DET #define E1_DIAG_PIN P1_25 // E1DET // // Limit Switches // #ifdef X_STALL_SENSITIVITY #define X_STOP_PIN X_DIAG_PIN #if X_HOME_DIR < 0 #define X_MAX_PIN P1_26 // E0DET #else #define X_MIN_PIN P1_26 // E0DET #endif #elif ENABLED(X_DUAL_ENDSTOPS) #ifndef X_MIN_PIN #define X_MIN_PIN P1_29 // X-STOP #endif #ifndef X_MAX_PIN #define X_MAX_PIN P1_26 // E0DET #endif #else #define X_STOP_PIN P1_29 // X-STOP #endif #ifdef Y_STALL_SENSITIVITY #define Y_STOP_PIN Y_DIAG_PIN #if Y_HOME_DIR < 0 #define Y_MAX_PIN P1_25 // E1DET #else #define Y_MIN_PIN P1_25 // E1DET #endif #elif ENABLED(Y_DUAL_ENDSTOPS) #ifndef Y_MIN_PIN #define Y_MIN_PIN P1_28 // Y-STOP #endif #ifndef Y_MAX_PIN #define Y_MAX_PIN P1_25 // E1DET #endif #else #define Y_STOP_PIN P1_28 // Y-STOP #endif #ifdef Z_STALL_SENSITIVITY #define Z_STOP_PIN Z_DIAG_PIN #if Z_HOME_DIR < 0 #define Z_MAX_PIN P1_00 // PWRDET #else #define Z_MIN_PIN P1_00 // PWRDET #endif #elif ENABLED(Z_MULTI_ENDSTOPS) #ifndef Z_MIN_PIN #define Z_MIN_PIN P1_27 // Z-STOP #endif #ifndef Z_MAX_PIN #define Z_MAX_PIN P1_00 // PWRDET #endif #else #ifndef Z_STOP_PIN #define Z_STOP_PIN P1_27 // Z-STOP #endif #endif // // Z Probe (when not Z_MIN_PIN) // #define Z_MIN_PIN P0_10 // #ifndef Z_MIN_PROBE_PIN // #define Z_MIN_PROBE_PIN P0_10 // #endif
//#define SENSORLESS_HOMING // StallGuard capable drivers only //#define SENSORLESS_PROBING #if EITHER(SENSORLESS_HOMING, SENSORLESS_PROBING) // TMC2209: 0...255. TMC2130: -64...63 #define X_STALL_SENSITIVITY 8 #define X2_STALL_SENSITIVITY X_STALL_SENSITIVITY #define Y_STALL_SENSITIVITY 8 #define Y2_STALL_SENSITIVITY Y_STALL_SENSITIVITY //#define Z_STALL_SENSITIVITY 8 //#define Z2_STALL_SENSITIVITY Z_STALL_SENSITIVITY //#define Z3_STALL_SENSITIVITY Z_STALL_SENSITIVITY //#define Z4_STALL_SENSITIVITY Z_STALL_SENSITIVITY //#define SPI_ENDSTOPS // TMC2130 only //#define IMPROVE_HOMING_RELIABILITY #endif
// TMC StallGuard DIAG pins // #define X_DIAG_PIN P1_29 // X-STOP #define Y_DIAG_PIN P1_28 // Y-STOP #define Z_DIAG_PIN P1_27 // Z-STOP #define E0_DIAG_PIN P1_26 // E0DET #define E1_DIAG_PIN P1_25 // E1DET #define X_STOP_PIN P1_29 // X-STOP #define Y_STOP_PIN P1_28 // Y-STOP #define Z_STOP_PIN P1_27 // Z-STOP #define Z_MIN_PIN P0_10
Re: Marlin Konfiguration für Deltas 16. April 2021 13:09 |
Re: Marlin Konfiguration für Deltas 16. April 2021 14:27 |
After homing in z, the hardware z endstop is deactivated (unless you have set ENDSTOPS_ALWAYS_ON_DEFAULT in configuration_adv.h, which can be overridden by M120, M121), but to protect the hardware a software endstop is activated
Re: Marlin Konfiguration für Deltas 16. April 2021 16:30 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 199 |
Re: Marlin Konfiguration für Deltas 17. April 2021 08:46 |
/** * M355 Case Light on-off / brightness */ #define CASE_LIGHT_ENABLE #if ENABLED(CASE_LIGHT_ENABLE) //#define CASE_LIGHT_PIN 4 // Override the default pin if needed #define INVERT_CASE_LIGHT false // Set true if Case Light is ON when pin is LOW
Re: Marlin Konfiguration für Deltas 17. April 2021 12:01 |
Re: Marlin Konfiguration für Deltas 17. April 2021 13:15 |
In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\HAL.cpp:24: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1727:1: error: user-defined literal in preprocessor expression | ^ ~~~~~~~~~~~~ Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1729:9: error: user-defined literal in preprocessor expression 1729 | #elif CASE_LIGHT_PIN == FAN_PIN | ^~~~~~~~~~~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\HAL_SPI.cpp:51: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1727:1: error: user-defined literal in preprocessor expression 1727 | #if !PIN_EXISTS(CASE_LIGHT) | ^ ~~~~~~~~~~~~ Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1729:9: error: user-defined literal in preprocessor expression 1729 | #elif CASE_LIGHT_PIN == FAN_PIN | ^~~~~~~~~~~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\MarlinSerial.cpp:26: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1727:1: error: user-defined literal in preprocessor expression 1727 | #if !PIN_EXISTS(CASE_LIGHT) | ^ ~~~~~~~~~~~~ Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1729:9: error: user-defined literal in preprocessor expression 1729 | #elif CASE_LIGHT_PIN == FAN_PIN | ^~~~~~~~~~~~~~ *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\MarlinSerial.cpp.o] Error 1 ================================================= [ FAILED ] Took 3.68 seconds
Re: Marlin Konfiguration für Deltas 18. April 2021 04:57 |
Re: Marlin Konfiguration für Deltas 18. April 2021 13:38 |
Junkie
@Admin: ist das doch eher was fürs Elektronik-Forum?
