Status Repetier Firmware v2? 13. May 2021 07:10 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 482 |
Re: Status Repetier Firmware v2? 13. May 2021 10:55 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 2.094 |
Re: Status Repetier Firmware v2? 15. May 2021 08:25 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 68 |
Re: Status Repetier Firmware v2? 16. May 2021 08:52 |
PC - usb -> RPi - usb -> Arduinooder
PC - Ethernet-> RPi - usb -> Arduinoaussehen, oder muss sie so
PC - Ethernet-> Router - Ethernet -> RPi - usb -> Arduinoaussehen?
Re: Status Repetier Firmware v2? 16. May 2021 09:08 |
Re: Status Repetier Firmware v2? 23. May 2021 09:32 |
In file included from Marlin\src\HAL\DUE\../../core/../inc/../HAL/./DUE/../shared/Marduino.h:36:0,
from Marlin\src\HAL\DUE\../../core/../inc/../HAL/./DUE/HAL.h:30,
from Marlin\src\HAL\DUE\../../core/../inc/../HAL/HAL.h:26,
from Marlin\src\HAL\DUE\../../core/../inc/MarlinConfig.h:31,
from Marlin\src\HAL\DUE\../../core/serial.h:24,
from Marlin\src\HAL\DUE\DebugMonitor.cpp:25:
C:\Users\danie\.platformio\packages\framework-arduino-sam\cores\arduino/Arduino.h:42:10: fatal error: chip.h: No such file or directory
* Looking for chip.h dependency? Check our library registry!
* CLI > platformio lib search "header:chip.h"
* Web > [platformio.org]
#include
compilation terminated.
In file included from Marlin\src\HAL\DUE\../../inc/../HAL/./DUE/../shared/Marduino.h:36:0,
from Marlin\src\HAL\DUE\../../inc/../HAL/./DUE/HAL.h:30,
from Marlin\src\HAL\DUE\../../inc/../HAL/HAL.h:26,
from Marlin\src\HAL\DUE\../../inc/MarlinConfig.h:31,
from Marlin\src\HAL\DUE\HAL.cpp:27:
#include
*** [.pio\build\DUE\src\src\HAL\DUE\DebugMonitor.cpp.o] Error 1
*** [.pio\build\DUE\src\src\HAL\DUE\HAL.cpp.o] Error 1
from Marlin\src\HAL\DUE\HAL_SPI.cpp:40:
#include
*** [.pio\build\DUE\src\src\HAL\DUE\HAL_SPI.cpp.o] Error 1
from Marlin\src\HAL\DUE\MarlinSerialUSB.cpp:30:
#include
*** [.pio\build\DUE\src\src\HAL\DUE\MarlinSerialUSB.cpp.o] Error 1
from Marlin\src\HAL\DUE\InterruptVectors.cpp:35:
#include
*** [.pio\build\DUE\src\src\HAL\DUE\InterruptVectors.cpp.o] Error 1
from Marlin\src\HAL\DUE\MarlinSerial.cpp:30:
#include
*** [.pio\build\DUE\src\src\HAL\DUE\MarlinSerial.cpp.o] Error 1
========================================================= [FAILED] Took 3.27 seconds =========================================================
Re: Status Repetier Firmware v2? 24. May 2021 04:23 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 143 |
Re: Status Repetier Firmware v2? 24. May 2021 04:49 |
Wintex
Vielleicht liegt es ja daran das der Verzeichnis-Dateinamensbaum von der Zeichen Anzahl die 256 Zeichen überschritten hat und deswegen nicht kompiliert werden kann.
Sowas hatte ich schon.
Seitdem lege ich die Marlin Version immer im obersten Verzeichnis ab. Was natürlich etwas doof ist wegen Sortierung nach Versionen und Boards.
Re: Status Repetier Firmware v2? 24. May 2021 05:26 |
Re: Status Repetier Firmware v2? 30. May 2021 16:41 |
# This file contains common pin mappings for RADDS (v1.5) boards. To # use this config, the firmware should be compiled for the Arduino # Due. # See docs/Config_Reference.md for a description of parameters. # Temp sensor pins: PA16..PA6 # Mosfet Pins: PC23 (Heatbed), PC22, PC21, PD7, PD8, PB27 [stepper_x] step_pin: PA15 dir_pin: PA14 enable_pin: PD1 microsteps: 64 rotation_distance: 39.9 endstop_pin: ^PD3 #endstop_pin: ^PC2 position_endstop: 0 position_max: 440 homing_speed: 50 [stepper_y] step_pin: PA12 dir_pin: !PA13 enable_pin: PB26 microsteps: 64 rotation_distance: 39.9 endstop_pin: ^PD9 #endstop_pin: ^PC4 position_endstop: 0 position_max: 335 homing_speed: 50 [stepper_z] step_pin: PB25 dir_pin: PC28 enable_pin: PD5 microsteps: 128 rotation_distance: 2 endstop_pin: ^PD10 #endstop_pin: ^PC6 position_endstop: 0 position_max: 500 [extruder] step_pin: PA2 dir_pin: PA3 enable_pin: PB17 microsteps: 128 rotation_distance: 22.46 nozzle_diameter: 0.400 filament_diameter: 1.750 heater_pin: PB27 sensor_type: ATC Semitec 104GT-2 sensor_pin: PA16 control: pid pid_Kp: 7.5 pid_Ki: 0.54 pid_Kd: 25.5 min_temp: 0 max_temp: 285 #[extruder1] #step_pin: PB19 #dir_pin: PB18 #enable_pin: PB20 #[extruder2] #step_pin: PC12 #dir_pin: PB14 #enable_pin: PC14 [heater_bed] heater_pin: PC23 sensor_type: EPCOS 100K B57560G104F sensor_pin: PA24 control: watermark min_temp: 0 max_temp: 130 [fan] pin: PC21 #[heater_fan nozzle_cooling_fan] #pin: PC22 [mcu] serial: /dev/ttyACM0 [printer] kinematics: cartesian max_velocity: 500 max_accel: 2000 max_z_velocity: 10 max_z_accel: 100 # "RepRapDiscount 2004 Smart Controller" type displays #[display] #lcd_type: hd44780 #rs_pin: PA19 #e_pin: PA20 #d4_pin: PC19 #d5_pin: PC18 #d6_pin: PC17 #d7_pin: PC16 #encoder_pins: ^PB21, ^PC13 #click_pin: ^!PC15 # "RepRapDiscount 128x64 Full Graphic Smart Controller" type displays #[display] #lcd_type: st7920 #cs_pin: PA19 #sclk_pin: PC19 #sid_pin: PA20
[extruder_stepper my_extra_stepper] #extruder: extruder # The extruder this stepper is synchronized to. The default is # "extruder". #step_pin: #dir_pin: #enable_pin: #microsteps: #rotation_distance: # See the "stepper" section for the definition of the above # parameters.
[extruder_stepper my_extra_stepper] extruder: extruder step_pin: PB19 dir_pin: PB18 enable_pin: PB20 microsteps: 128 rotation_distance: 22.46
Re: Status Repetier Firmware v2? 30. May 2021 17:08 |
Re: Status Repetier Firmware v2? 03. June 2021 09:16 |
Re: Status Repetier Firmware v2? 03. June 2021 09:31 |
Legion 2.3
Der nächste Schritt wäre deshalb wohl, den Arduino in den richtigen Drucker einzubauen. Allerdings komme ich mit der Konfig nicht weiter.
Eine Einstellung bzw einen Parameter konnte ich noch nicht finden: In Repetier gibt ein ein "STEPPER_HIGH_DELAY "und ein "DIRECTION_DELAY". Diese beiden Parameter definieren ja die minimale Pulslänge und Pause vor einem Richtungswechsel und sind abhängig vom verwendeten Schrittmotortreiber.
In der Dokumentation von Klipper gibt es diese Parameter nicht, zumindest habe ich sie nicht gefunden.
Kann man diese Parameter garnicht einstellen? Selber erkennen kann die Firmware diese ja nicht.
Re: Status Repetier Firmware v2? 04. June 2021 15:49 |
Re: Status Repetier Firmware v2? 13. June 2021 16:04 |
Re: Status Repetier Firmware v2? 13. June 2021 16:47 |
Administrator Registrierungsdatum: 19 Jahre zuvor Beiträge: 14.204 |
Re: Status Repetier Firmware v2? 14. June 2021 02:51 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 199 |
Re: Status Repetier Firmware v2? 26. June 2021 14:51 |
Re: Status Repetier Firmware v2? 13. July 2021 14:29 |
