Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 27. January 2022 18:01 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 24 |
{if layer_z==1.6}M104 S265 ; T tower floor 1
{elsif layer_z==11.6}M104 S260 ; T tower floor 2
{elsif layer_z==21.6}M104 S255 ; T tower floor 3
{elsif layer_z==31.6}M104 S250 ; T tower floor 4
{elsif layer_z==41.6}M104 S245 ; T tower floor 5
{elsif layer_z==51.6}M104 S240 ; T tower floor 6
{elsif layer_z==61.6}M104 S235 ; T tower floor 7
{elsif layer_z==71.6}M104 S230; T tower floor 8
{elsif layer_z==81.6}M104 S225 ; T tower floor 9
{elsif layer_z==91.6}M104 S220 ; T tower floor 10
{endif}
Re: Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 28. January 2022 04:27 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.610 |
Re: Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 28. January 2022 05:51 |
AlterBastler
Ersetze die "==" durch "<=", dann funktioniert es.
Herzl. Grüße
Re: Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 28. January 2022 06:07 |
Re: Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 28. January 2022 06:25 |
; generated by Slic3r 1.3.1-dev on 2022-01-28 at 12:21:41
; external perimeters extrusion width = 0.48mm (3.28mm^3/s)
; perimeters extrusion width = 0.48mm (4.37mm^3/s)
; infill extrusion width = 0.48mm (4.37mm^3/s)
; solid infill extrusion width = 0.48mm (2.19mm^3/s)
; top infill extrusion width = 0.48mm (1.75mm^3/s)
M190 S94 ; set bed temperature and wait for it to be reached
M104 S240 ; set temperature
G28; Home all axis
G1 Z15 F{Z_TRAVEL_SPEED}
M109 S240 ; set temperature and wait for it to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
G92 E0
{elsif layer_z<=11.6}M104 S260 ; T tower floor 2
{elsif layer_z<=21.6}M104 S255 ; T tower floor 3
{elsif layer_z<=31.6}M104 S250 ; T tower floor 4
{elsif layer_z<=41.6}M104 S245 ; T tower floor 5
{elsif layer_z<=51.6}M104 S240 ; T tower floor 6
{elsif layer_z<=61.6}M104 S235 ; T tower floor 7
{elsif layer_z<=71.6}M104 S230; T tower floor 8
{elsif layer_z<=81.6}M104 S225 ; T tower floor 9
{endif}
G1 Z0.200 F6000.000
G1 E-4.00000 F2400.00000
G92 E0
G1 X64.589 Y72.944 F6000.000
G1 E4.00000 F2400.00000
G1 F900
G1 X65.740 Y72.058 E4.04938
Re: Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 28. January 2022 06:38 |
Re: Probleme mit gCode für Temp.Tower [Repetier Host/Slic3r] 28. January 2022 09:24 |
M104 S265; T tower floor 1
{if [layer_z]>=1.6}{if [layer_z]<11.6}M104 S265
{if [layer_z]>=11.6}{if [layer_z]<21.6}M104 S260
{if [layer_z]>=21.6}{if [layer_z]<31.6}M104 S255
{if [layer_z]>=31.6}{if [layer_z]<41.6}M104 S250
{if [layer_z]>=41.6}{if [layer_z]<51.6}M104 S245
{if [layer_z]>=51.6}{if [layer_z]<61.6}M104 S240
{if [layer_z]>=61.6}{if [layer_z]<71.6}M104 S235
{if [layer_z]>=71.6}{if [layer_z]<81.6}M104 S230
{if [layer_z]>=81.6}{if [layer_z]<91.6}M104 S225
{if [layer_z]>=91.6}M104 S220
