Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 11. March 2013 18:33 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 6 |
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 11. March 2013 18:58 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.905 |
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 11. March 2013 19:43 |
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 12. March 2013 04:50 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
/configuration.h:24:2: error: #error Please edit configuration.h and at the very least uncomment one of the DEFAULTS definitions that best-matches your hardware.Hast Du das denn gemacht? In der Regel hilft es, Fehlermeldungen zu lesen.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 12. March 2013 05:29 |
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 12. March 2013 07:57 |
In file included from FiveD_GCode_Interpreter.cpp:8:
/hostcom.h: In member function 'void hostcom::putInit()':
hostcom.h:96: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(char*)':
hostcom.h:97: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(const float&)':
hostcom.h:98: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(const long int&)':
hostcom.h:99: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(int)':
hostcom.h:100: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::putEnd()':
hostcom.h:101: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'byte hostcom::gotData()':
hostcom.h:102: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'char hostcom::get()':
hostcom.h:103: error: 'Serial' was not declared in this scope
FiveD_GCode_Interpreter.cpp: In function 'void setup()':
FiveD_GCode_Interpreter:189: error: 'Serial1' was not declared in this scope
FiveD_GCode_Interpreter.cpp: In member function 'bool intercom::talk()':
intercom:55: error: 'Serial1' was not declared in this scope
FiveD_GCode_Interpreter.cpp: In member function 'void intercom::tick()':
intercom:176: error: 'Serial1' was not declared in this scope
intercom:209: error: 'Serial1' was not declared in this scope
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 12. March 2013 12:40 |
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp: In member function 'virtual size_t IPAddress::printTo(Print&) const':
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp:50: error: void value not ignored as it ought to be
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp:50: error: in evaluation of 'operator+=(size_t, void)'
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp:51: error: void value not ignored as it ought to be
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp:51: error: in evaluation of 'operator+=(size_t, void)'
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp:53: error: void value not ignored as it ought to be
F:\Software\arduino-0023\hardware\sanguino\cores\arduino\IPAddress.cpp:53: error: in evaluation of 'operator+=(size_t, void)'
Re: Frage an die alten Hasen (Reprap Motherboard v1.2 sanguino grrf) 12. March 2013 15:27 |
#include HardwareSerial.hdurch "//"
(also "//#include HardwareSerial.h")ausschließen, dann hat es funktioniert.
