Z-Endstopp futzt nicht 31. October 2016 12:09 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 228 |
#define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG //#define USE_ZMAX_PLUG // coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #if DISABLED(ENDSTOPPULLUPS) // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined //#define ENDSTOPPULLUP_XMAX //#define ENDSTOPPULLUP_YMAX //#define ENDSTOPPULLUP_ZMAX //#define ENDSTOPPULLUP_XMIN //#define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN //#define ENDSTOPPULLUP_ZMIN_PROBE #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MIN_PROBE_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. //=========================================================================== //============================= Z Probe Options ============================= //=========================================================================== // Enable Z_MIN_PROBE_ENDSTOP to use _both_ a Z Probe and a Z-min-endstop on the same machine. // With this option the Z_MIN_PROBE_PIN will only be used for probing, never for homing. // // *** PLEASE READ ALL INSTRUCTIONS BELOW FOR SAFETY! *** // // To continue using the Z-min-endstop for homing, be sure to disable Z_SAFE_HOMING. // Example: To park the head outside the bed area when homing with G28. // // To use a separate Z probe, your board must define a Z_MIN_PROBE_PIN. // // For a servo-based Z probe, you must set up servo support below, including // NUM_SERVOS, Z_ENDSTOP_SERVO_NR and SERVO_ENDSTOP_ANGLES. // // - RAMPS 1.3/1.4 boards may be able to use the 5V, GND, and Aux4->D32 pin. // - Use 5V for powered (usu. inductive) sensors. // - Otherwise connect: // - normally-closed switches to GND and D32. // - normally-open switches to 5V and D32. // // Normally-closed switches are advised and are the default. // // The Z_MIN_PROBE_PIN sets the Arduino pin to use. (See your board's pins file.) // Since the RAMPS Aux4->D32 pin maps directly to the Arduino D32 pin, D32 is the // default pin for all RAMPS-based boards. Some other boards map differently. // To set or change the pin for your board, edit the appropriate pins_XXXXX.h file. // // WARNING: // Setting the wrong pin may have unexpected and potentially disastrous consequences. // Use with caution and do your homework. // #define Z_MIN_PROBE_ENDSTOP // Enable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN to use the Z_MIN_PIN for your Z_MIN_PROBE. // The Z_MIN_PIN will then be used for both Z-homing and probing. //#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN // To use a probe you must enable one of the two options above! // This option disables the use of the Z_MIN_PROBE_PIN // To enable the Z probe pin but disable its use, uncomment the line below. This only affects a // Z probe switch if you have a separate Z min endstop also and have activated Z_MIN_PROBE_ENDSTOP above. // If you're using the Z MIN endstop connector for your Z probe, this has no effect. //#define DISABLE_Z_MIN_PROBE_ENDSTOP
Re: Z-Endstopp futzt nicht 31. October 2016 12:45 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: Z-Endstopp futzt nicht 01. November 2016 16:34 |
Re: Z-Endstopp futzt nicht 05. November 2016 13:01 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 47 |
Re: Z-Endstopp futzt nicht 25. November 2016 11:45 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 47 |
