RepRapDiscount LCD Panel - Reset Knopf? 17. August 2012 10:51 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 1.916 |
Re: RepRapDiscount LCD Panel 18. August 2012 02:40 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 1.323 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 19. August 2012 03:35 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 19. August 2012 03:55 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 2.705 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 19. August 2012 04:30 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 19. August 2012 04:42 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 19. August 2012 04:43 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 22. August 2012 09:19 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 4 |
Anonymous User
Re: RepRapDiscount LCD Panel - Reset Knopf? 22. August 2012 20:34 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 26. January 2013 03:19 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 58 |
/** What shall the printer do, when it receives an M112 emergency stop signal? 0 = Disable heaters/motors, wait for ever until someone presses reset. 1 = restart by resetting the AVR controller. The USB connection will not reset if managed by a different chip! */ #define KILL_METHOD 0 .... /** Comment out (using // at the start of the line) to disable SD support: */ #define SDSUPPORT 0
void ui_init_keys() {
UI_KEYS_INIT_CLICKENCODER_LOW(33,31); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
UI_KEYS_INIT_BUTTON_LOW(35); // push button, connects gnd to pin
UI_KEYS_INIT_BUTTON_LOW(41); // EMERGENCY_STOP pin <--- here
// UI_KEYS_INIT_MATRI
32,47,45,43,41,39,37,35);
void ui_check_keys(int &action) {
UI_KEYS_CLICKENCODER_LOW_REV(33,31); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
UI_KEYS_BUTTON_LOW(35,UI_ACTION_OK); // push button, connects gnd to pin
UI_KEYS_BUTTON_LOW(41,UI_ACTION_EMERGENCY_STOP); // EMERGENCY_STOP <--- here
Re: RepRapDiscount LCD Panel - Reset Knopf? 26. January 2013 13:48 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 29. January 2013 02:56 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 29. January 2013 02:58 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 29. January 2013 04:27 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 29. January 2013 13:18 |
Re: RepRapDiscount LCD Panel - Reset Knopf? 29. January 2013 14:07 |
