Megatronics 2.0 Hilfe 11. August 2013 12:30 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 8 |
Re: Megatronics 2.0 Hilfe 17. August 2013 10:01 |
Re: Megatronics 2.0 Hilfe 18. August 2013 14:13 |
Registrierungsdatum: 15 Jahre zuvor Beiträge: 193 |
Re: Megatronics 2.0 Hilfe 20. August 2013 02:30 |
Re: Megatronics 2.0 Hilfe 20. August 2013 16:04 |
Re: Megatronics 2.0 Hilfe 22. August 2013 02:58 |
Re: Megatronics 2.0 Hilfe 23. August 2013 18:41 |
Under other operating systems the USB will not be reset correctly and you will need to adjust the boards.txt. This file is located in /hardware/arduino/boards.txt. Add the following text to the file:
megatronics.name=Megatronics
megatronics.upload.protocol=wiring
megatronics.upload.maximum_size=258048
megatronics.upload.speed=115200
megatronics.bootloader.low_fuses=0xFF
megatronics.bootloader.high_fuses=0xDA
megatronics.bootloader.extended_fuses=0xF5
megatronics.bootloader.path=stk500v2
megatronics.bootloader.file=stk500boot_v2_mega2560.hex
megatronics.bootloader.unlock_bits=0x3F
megatronics.bootloader.lock_bits=0x0F
megatronics.build.mcu=atmega2560
megatronics.build.f_cpu=16000000L
megatronics.build.core=arduino
megatronics.build.variant=mega
Re: Megatronics 2.0 Hilfe 24. August 2013 03:59 |
) Beim
Re: Megatronics 2.0 Hilfe 24. August 2013 06:39 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 15 |
Re: Megatronics 2.0 Hilfe 26. August 2013 17:33 |
Re: Megatronics 2.0 Hilfe 26. August 2013 23:34 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 675 |
Re: Megatronics 2.0 Hilfe 27. August 2013 15:37 |
Re: Megatronics 2.0 Hilfe 29. August 2013 04:57 |
Re: Megatronics 2.0 Hilfe 16. September 2013 08:20 |
