HP-600PB und 5 Volt? 29. March 2014 23:05 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 29 |
Re: HP-600PB und 5 Volt? 30. March 2014 04:53 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: HP-600PB und 5 Volt? 30. March 2014 05:57 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 376 |
Re: HP-600PB und 5 Volt? 30. March 2014 10:33 |
Re: HP-600PB und 5 Volt? 30. March 2014 14:55 |
PIN .......... Ribbon Wire ....... Description . 1 ............ N/A ...................... +5VSB . 2 ............ N/A ...................... +5VSB . 3 ............ N/A ...................... +5VSB . 4 ............ 3 .......................... Fan speed, ground for minimum speed. (For variable speed use ~4.6v to Vcc.) . 5 ............ N/A ...................... -12V . 6 ............ 5 .......................... PsKill, ground this and PsOn to turn on the PS. . 7 ............ 6 .......................... +S (positive sense) . 8 ............ N/A ...................... DC ground . 9 ............ 8 .......................... -S (negative sense) .10 ............ 4 .......................... PsOn, ground this and PsKill to turn on the PS. .11 ............ 9 .......................... Current Share .12 ............ 7 .......................... Power OK/Fault (OK = 3.8V, Fault = 0V). .N/A .......... 1 .......................... Ground from the output board back to the main board (needs to be tied to DC ground). .N/A .......... 2 .......................... Ground from the output board back to the main board (needs to be tied to DC ground). .N/A ........ 10 .......................... Ground from the output board back to the main board (not needed).
Re: HP-600PB und 5 Volt? 30. March 2014 16:39 |
