Re: TMC2100 1/256 Treiber 13. February 2015 07:36 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 115 |
Re: TMC2100 1/256 Treiber 14. February 2015 06:01 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 469 |
Re: TMC2100 1/256 Treiber 14. February 2015 07:30 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
bigfilsing
Managed to read your posts with google translate
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: TMC2100 1/256 Treiber 14. February 2015 13:23 |
Traumflug
bigfilsing
Obviously not sufficiently to recognize that this is not a shop here.
Re: TMC2100 1/256 Treiber 14. February 2015 15:07 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 123 |
Re: TMC2100 1/256 Treiber 14. February 2015 17:48 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 3.385 |
Re: TMC2100 1/256 Treiber 14. February 2015 20:19 |
Re: TMC2100 1/256 Treiber 14. February 2015 20:47 |
Re: TMC2100 1/256 Treiber 14. February 2015 21:41 |
Skimmy
english is no problem as long as you are that kind
I for myself use copper ones, described with photos in my buildlog: [forums.reprap.org]
They are attached with a 0,15mm thick thermal-transfer-glue-pad from 3M.
Re: TMC2100 1/256 Treiber 15. February 2015 06:16 |
Re: TMC2100 1/256 Treiber 15. February 2015 07:27 |
Re: TMC2100 1/256 Treiber 15. February 2015 08:19 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 439 |
bigfilsing
Skimmy
I think that this would be risky, because u could accidentally unsolder the chip itself, because of the heat you put in in the moment...
Good point!
i have also gone off the idea as making it flat/ level wouldn't be easy either.
Re: TMC2100 1/256 Treiber 15. February 2015 11:40 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.516 |
Re: TMC2100 1/256 Treiber 15. February 2015 12:26 |
Re: TMC2100 1/256 Treiber 15. February 2015 13:01 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 2.469 |
Re: TMC2100 1/256 Treiber 15. February 2015 17:18 |
Re: TMC2100 1/256 Treiber 16. February 2015 02:59 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 841 |
Re: TMC2100 1/256 Treiber 16. February 2015 08:32 |
Le-Seaw
Oder Sekundenkleber
Re: TMC2100 1/256 Treiber 16. February 2015 08:36 |
Skimmy
Habe noch keinen guten lösbaren Wärmeleitkleber gefunden, die die ich kenne sind alle "unlösbar". Hast du eine Empfehlung?
Re: TMC2100 1/256 Treiber 16. February 2015 08:50 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 4.398 |
Traumflug
Skimmy
Schraubensicherung, aka "Loctite". Leitet zwar keine Wärme, mit ein wenig andrücken bekommt man aber eine sehr dünne Klebeschicht hin, so dass der Kühlkörper quasi direkt auf dem Chip liegt. Härtet nicht immer sofort aus, manchmal erst wenn der Chip warm wird. Tropfen Loctite auf den Chip, Kühlkörper drauf, andrücken, Controller einschalten, 10 Sekunden warten, fertig.
Re: TMC2100 1/256 Treiber 16. February 2015 09:46 |
Traumflug
Le-Seaw
Oder Sekundenkleber
Hat bei mir keinen ganzen Tag gehalten, dann sind die Kühlkörper einfach runter gefallen. Normaler Sekundenkleber hält nur 70 °C. Es gibt Varianten bis 140 °C, aber das ist immer noch sehr knapp, der Schutzmechanismus im Chip löst erst bei 185 °C aus (bei den Allegro Chips).
Re: TMC2100 1/256 Treiber 16. February 2015 10:06 |
Re: TMC2100 1/256 Treiber 16. February 2015 10:23 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.103 |
Le-Seaw
Und meint ihr nicht das sich die Heatpipe zusetzen mit Loclite?
Re: TMC2100 1/256 Treiber 16. February 2015 12:58 |
Re: TMC2100 1/256 Treiber 16. February 2015 13:07 |
Re: TMC2100 1/256 Treiber 16. February 2015 14:56 |
windiesel
I was wondering if such a design would give any advantages?
[attachment 49395 drivercooler.jpg]
this kind of design could not be used for RAMPS, but I use RADDS.
best regards
Re: TMC2100 1/256 Treiber 16. February 2015 14:59 |
Re: TMC2100 1/256 Treiber 16. February 2015 18:28 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 360 |
Re: TMC2100 1/256 Treiber 17. February 2015 03:39 |
Re: TMC2100 1/256 Treiber 17. February 2015 04:51 |
