Thermistoren Tabellen /Marlin
30. August 2015 10:52
Mal ne Frage, ich habe bislang in meinem Prusa die Thermistoren von 2printbeta mit einem Beta Wert von 4267
Nun habe ich andere von Ebay mit einem Wert von 3950.
Wie erzähle ich das nun meinem Marlin? (Version weiß nicht da vor einem Jahr bei 2printbeta heruntergeladen)
Prusa Air 2
Merlin Hotend (passiv und verlängert)
Eigenbau X300 Y500 mit verlängertem Merlin Hotend
BIQU Magician
JGAURORA A5
Anycubic Photon
Eine Kiwi am Tag deckt den menschlichen Tagesbedarf an Kiwis
Re: Thermistoren Tabellen /Marlin
30. August 2015 14:06
In der Configuration.h
//=============================Thermal Settings  ============================
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is Mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 11 is 100k beta 3950 1% thermistor (4.7k pullup)
// 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
// 13 is 100k Hisens 3950  1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE"
// 20 is the PT100 circuit found in the Ultimainboard V2.x
// 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
//    1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
//                          (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
// 1047 is Pt1000 with 4k7 pullup
// 1010 is Pt1000 with 1k pullup (non standard)
// 147 is Pt100 with 4k7 pullup
// 110 is Pt100 with 1k pullup (non standard)
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 -1
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 60
Wie hier beim Bed z.b
1-mal bearbeitet. Zuletzt am 30.08.15 14:07.
30. August 2015 19:37
Das Teacup Configtool nehmen und die Werte einfach einsetzen:
Wenn Du bei der Marlin bleiben willst: Menü -> File -> Save config.h, dann stehen die Werte in der Datei thermistortable.h. Ansonsten einfach Build und Upload, auch im Menü.
