Sparkube XL Z-Home offset 04. January 2017 17:28 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 52 |
Re: Sparkube XL Z-Home offset 05. January 2017 02:47 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 489 |
... G28 XY G1 X100 Y100 F300 G28 Z ...
Re: Sparkube XL Z-Home offset 05. January 2017 03:10 |
Re: Sparkube XL Z-Home offset 05. January 2017 04:15 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
Re: Sparkube XL Z-Home offset 05. January 2017 05:39 |
Re: Sparkube XL Z-Home offset 05. January 2017 07:37 |
Re: Sparkube XL Z-Home offset 05. January 2017 08:40 |
Re: Sparkube XL Z-Home offset 05. January 2017 11:21 |
Re: Sparkube XL Z-Home offset 05. January 2017 11:43 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 1.112 |
Re: Sparkube XL Z-Home offset 05. January 2017 12:16 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 922 |
Re: Sparkube XL Z-Home offset 05. January 2017 12:25 |
Re: Sparkube XL Z-Home offset 05. January 2017 12:29 |
Re: Sparkube XL Z-Home offset 05. January 2017 12:32 |
Re: Sparkube XL Z-Home offset 05. January 2017 12:35 |
//#define MANUAL_BED_LEVELING // Add display menu option for bed leveling. #if ENABLED(MANUAL_BED_LEVELING) #define MBL_Z_STEP 0.025 // Step size while manually probing Z axis. #endif // MANUAL_BED_LEVELING // Gradually reduce leveling correction until a set height is reached, // at which point movement will be level to the machine's XY plane. // The height can be set with M420 Z #define ENABLE_LEVELING_FADE_HEIGHT #endif // MESH_BED_LEVELING
#if ENABLED(Z_SAFE_HOMING) #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28). #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28). #endifDa wundert es mich dass es noch nicht implementiert wurde obwohl die Funktion doch sehr Sinnvoll ist.
Ja, MarlinQuote
AlexB
Nach Murphy's Law dürfte dann genau in dem Moment wo ich fertig bin jemand mit der perfekten Software-Lösung um die Ecke kommen...
Re: Sparkube XL Z-Home offset 05. January 2017 12:44 |
siggi60
Aber wenn MABL das ist was ich denke, dann kann Marlin das auch:
Re: Sparkube XL Z-Home offset 05. January 2017 12:50 |
Re: Sparkube XL Z-Home offset 05. January 2017 12:52 |
Re: Sparkube XL Z-Home offset 05. January 2017 13:04 |
siggi60
Asche auf mein Haupt
AlexB
ich hab jetzt mal in die Developer reingeschaut, da hat man jetzt mehr Möglichkeiten was die Reihenfolge beim Homing angeht, aber das Z-Save-Homing kann ich nicht entdecken.
Re: Sparkube XL Z-Home offset 05. January 2017 13:06 |
Re: Sparkube XL Z-Home offset 05. January 2017 18:15 |
Re: Sparkube XL Z-Home offset 05. January 2017 18:48 |
Re: Sparkube XL Z-Home offset 06. January 2017 14:54 |
