RADDS MK4DUO Bltouch 28. October 2017 11:27 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 9 |
Re: RADDS MK4DUO Bltouch 28. October 2017 14:56 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Insert the following G-code into Slic3r or Cura (in deinem Fall vielleicht in der Firmware hier einfügen: #define USER_GCODE_1 "G28\nG29") M280 P0 S160 ; BLTouch alarm release G4 P100 ; delay for BLTouch G28 ; home G29 ; auto bed leveling
Herzl. GrüßeQuote
antclabs
blue LED for indicating servo signal and Z-probe(Zmin) Testing
■ If Blue LED is OFF in M280 P0 S60 command and push-pin is at down state.
☞ Servo signal wiring is not correct. Please check the orange wire.
■ If Blue LED is ON in m280 P0 S60 command and push-pin is at up state.
☞ There is a problem with Z-probe. Adjust the solenoid core to the factory settings. If the problem persists, please send email to ANTCLABS for help.
Blues LED in BLTouch is very faint.
Re: RADDS MK4DUO Bltouch 29. October 2017 14:07 |
Re: RADDS MK4DUO Bltouch 29. October 2017 14:56 |
Zeile 220 #define Z_ENDSTOP_SERVO_NR 0 Zeile 380 #define MKSE6_SERVO_INDEX 0 Zeile 397 #define DONDOLO_SERVO_INDEX 0Gibt es für den Drucker keinen Support? Ist schließlich eine Insellösung.
#define USER_GCODE_1 "M280 P0 S160\nG4 P100\nG28\nG29"Herzl. Grüße
antclabs
The BLTouch acts on the following gcode
that can be used manually to diagnose faults etc but you
don’t need to normally worry about them.
M280 P0 S10 ; pushes the pin down
M280 P0 S90 ; pulls the pin up
M280 P0 S120 ; Self test
M280 P0 S160 ; Release alarm
