So mit Reptier connect bekommen. Das ist ist im Log. (Müssen eigentlich die Jumper unter dem Stepper-Driver drin bleiben?)
[spoiler]
15:20:44.130 : Printer reset detected - initalizing
15:20:44.130 : start
15:20:44.130 : echo:Marlin bugfix-1.1.x
15:20:44.130 : echo: Last Updated: 2018-01-20 | Author: (none, default config)
15:20:44.130 : echo:Compiled: May 13 2018
15:20:44.130 : echo: Free Memory: 2972 PlannerBufferBytes: 1264
15:20:44.346 : N1 M110*34
15:20:44.346 : N2 M115*36
15:20:44.346 : N3 M105*36
15:20:44.346 : N4 M114*35
15:20:44.362 : N5 M111 S6*98
15:20:44.362 : N6 T0*60
15:20:44.362 : N7 M20*22
15:20:44.362 : N8 M80*19
15:20:44.362 : N9 M105*46
15:20:45.017 : echo:Hardcoded Default Settings Loaded
15:20:45.017 : echo: G21 ; (mm)
15:20:45.017 : echo: M149 C ; Units in Celsius
15:20:45.017 : echo:Filament settings: Disabled
15:20:45.017 : echo: M200 D3.00
15:20:45.017 : echo: M200 D0
15:20:45.017 : echo
teps per unit:
15:20:45.017 : echo: M92 X80.00 Y80.00 Z400.00 E95.00
15:20:45.017 : echo:Maximum feedrates (units/s):
15:20:45.017 : echo: M203 X500.00 Y500.00 Z15.00 E25.00
15:20:45.017 : echo:Maximum Acceleration (units/s2):
15:20:45.017 : echo: M201 X1000 Y1000 Z1000 E5000
15:20:45.017 : echo:Acceleration (units/s2): P R T
15:20:45.017 : echo: M204 P1000.00 R1000.00 T1000.00
15:20:45.017 : echo:Advanced: S T B X Z E
15:20:45.017 : echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.20 E3.00
15:20:45.017 : echo:Home offset:
15:20:45.017 : echo: M206 X0.00 Y0.00 Z0.00
15:20:45.017 : echo:Mesh Bed Leveling:
15:20:45.017 : echo: M420 S0 Z0.00
15:20:45.017 : echo:Material heatup parameters:
15:20:45.017 : echo: M145 S0 H200 B60 F0
15:20:45.017 : echo: M145 S1 H240 B80 F0
15:20:45.017 : echo
ID settings:
15:20:45.017 : echo: M301 P19.19 I1.45 D63.66
15:20:45.017 : echo: M304 P690.03 I111.47 D1068.83
15:20:45.017 : echo
tepper driver current:
15:20:45.017 : echo: M906 X800
15:20:45.017 : M906 Y800
15:20:45.017 : M906 Z800
15:20:45.017 : M906 T0 E800
15:20:45.017 : echo
ensorless homing threshold:
15:20:45.017 : echo: M914 X8
15:20:45.017 : M914 Y8
15:20:45.017 : M914 Z8
15:20:47.402 : N10 M105*22
15:20:48.057 : FIRMWARE_NAME:Marlin bugfix-1.1.x (Github) SOURCE_CODE_URL:[
github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:MEGAENDER3D Printer EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
15:20:48.057 : Cap
ERIAL_XON_XOFF:0
15:20:48.057 : N11 M220 S100*81
15:20:48.057 : Cap:EEPROM:0
15:20:48.057 : Cap:VOLUMETRIC:1
15:20:48.057 : Cap:AUTOREPORT_TEMP:1
15:20:48.057 : Cap
ROGRESS:0
15:20:48.057 : Cap
RINT_JOB:1
15:20:48.057 : Cap:AUTOLEVEL:0
15:20:48.057 : Cap:Z_PROBE:0
15:20:48.057 : Cap:LEVELING_DATA:1
15:20:48.057 : Cap:BUILD_PERCENT:0
15:20:48.057 : Cap
OFTWARE_POWER:0
15:20:48.057 : Cap:TOGGLE_LIGHTS:0
15:20:48.057 : Cap:CASE_LIGHT_BRIGHTNESS:0
15:20:48.057 : Cap:EMERGENCY_PARSER:0
15:20:48.057 : Cap:AUTOREPORT_SD_STATUS:0
15:20:48.057 : Cap:THERMAL_PROTECTION:1
15:20:48.073 : N12 M221 S100*83
15:20:48.088 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
15:20:48.088 : N13 M111 S6*85
15:20:48.126 : echo
EBUG:INFO,ERRORS
15:20:48.126 : echo:Active Extruder: 0
15:20:48.126 : Begin file list
15:20:48.126 : N14 T0*15
15:20:48.126 : End file list
15:20:48.126 : N15 M155 S1*84
15:20:48.126 : echo:Unknown command: "M80"
15:20:48.126 : echo
EBUG:INFO,ERRORS
15:20:48.142 : echo:Active Extruder: 0
[/spoiler]
... Ich komm nicht dahinter, warum die Motoren nicht rattern wollen.... Jmd. ne Idee?
EDIT: M122 schmeißt das raus
[Spoiler]
16:09:54.381 : N16 M122*21
16:09:54.481 : X Y Z E0
16:09:54.481 : Enabled false false false false
16:09:54.481 : Set current 800 800 800 800
16:09:54.481 : RMS current 1436 1436 1436 1436
16:09:54.481 : MAX current 2025 2025 2025 2025
16:09:54.481 : Run current 25/31 25/31 25/31 25/31
16:09:54.481 : Hold current 5/31 5/31 5/31 5/31
16:09:54.481 : CS actual 0/31 0/31 0/31 0/31
16:09:54.481 : PWM scale 0 0 0 0
16:09:54.481 : vsense 0=.325 0=.325 0=.325 0=.325
16:09:54.481 : stealthChop false false false false
16:09:54.481 : msteps 256 256 256 256
16:09:54.481 : tstep 0 0 0 0
16:09:54.481 : pwm
16:09:54.481 : threshold 0 0 0 0
16:09:54.481 : [mm/s] - - - -
16:09:54.481 : OT prewarn false false false false
16:09:54.481 : OT prewarn has
16:09:54.481 : been triggered false false false false
16:09:54.481 : off time 0 0 0 0
16:09:54.481 : blank time 16 16 16 16
16:09:54.481 : hysteresis
16:09:54.481 : -end -3 -3 -3 -3
16:09:54.481 : -start 1 1 1 1
16:09:54.481 : Stallguard thrs 8 8 8 0
16:09:54.481 : DRVSTATUS X Y Z E0
16:09:54.481 : stallguard
16:09:54.481 : sg_result 0 0 0 0
16:09:54.481 : fsactive
16:09:54.481 : stst
16:09:54.481 : olb
16:09:54.481 : ola
16:09:54.481 : s2gb
16:09:54.481 : s2ga
16:09:54.481 : otpw
16:09:54.481 : ot
16:09:54.481 : Driver registers: X = 0x00:00:00:00
16:09:54.481 : Y = 0x00:00:00:00
16:09:54.481 : Z = 0x00:00:00:00
16:09:54.481 : E0 = 0x00:00:00:00
[/spoiler]
Grüße.
2-mal bearbeitet. Zuletzt am 13.05.18 10:11.
