TMC2130 Overtemperature Warning (0mA) 07. January 2019 07:46 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 24 |
13:35:09.886 : 00:00: X driver overtemperature warning! (0mA) 13:35:10.946 : X driver error detected: 13:35:10.946 : X Y 13:35:10.946 : Enabled true false 13:35:10.946 : Set current 0 0 13:35:10.946 : RMS current 1767 1767 13:35:10.946 : MAX current 2491 2491 13:35:10.946 : Run current 31/31 31/31 13:35:10.946 : Hold current 31/31 31/31 13:35:10.946 : CS actual 31/31 31/31 13:35:10.946 : PWM scale 190 10 13:35:10.946 : vsense 0=.325 0=.325 13:35:10.946 : stealthChop true true 13:35:10.946 : msteps 16 16 13:35:10.946 : tstep 1048575 1048575 13:35:10.946 : pwm 13:35:10.946 : threshold 98 98 13:35:10.946 : [mm/s] 100.22 100.22 13:35:10.946 : OT prewarn true false 13:35:10.946 : OT prewarn has 13:35:10.946 : been triggered true false 13:35:10.946 : off time 5 5 13:35:10.946 : blank time 24 24 13:35:10.946 : hysterisis 13:35:10.946 : -end 2 2 13:35:10.946 : -start 3 3 13:35:10.946 : Stallguard thrs 0 0 13:35:10.946 : DRVSTATUS X Y 13:35:10.946 : stallguard X 13:35:10.946 : sg_result 0 0 13:35:10.946 : fsactive 13:35:10.946 : stst X X 13:35:10.946 : olb 13:35:10.946 : ola 13:35:10.946 : s2gb 13:35:10.946 : s2ga 13:35:10.946 : otpw X 13:35:10.946 : ot 13:35:10.946 : Driver registers: 13:35:10.946 : X = 0x85:1F:00:00 13:35:10.946 : Y = 0x80:1F:00:00 13:35:10.962 : Errorrinter halted. kill() called!
// @section TMC2130, TMC2208
* Enable this for SilentStepStick Trinamic TMC2130 SPI-configurable stepper drivers.
* You'll also need the TMC2130Stepper Arduino library
* (https://github.com/teemuatlut/TMC2130Stepper).
* To use TMC2130 stepper drivers in SPI mode connect your SPI2130 pins to
* the hardware SPI interface on your board and define the required CS pins
* in your `pins_MYBOARD.h` file. (e.g., RAMPS 1.4 uses AUX3 pins `X_CS_PIN 53`, `Y_CS_PIN 49`, etc.).
#define HAVE_TMC2130
* Enable this for SilentStepStick Trinamic TMC2208 UART-configurable stepper drivers.
* Connect #_SERIAL_TX_PIN to the driver side PDN_UART pin.
* To use the reading capabilities, also connect #_SERIAL_RX_PIN
* to #_SERIAL_TX_PIN with a 1K resistor.
* The drivers can also be used with hardware serial.
* You'll also need the TMC2208Stepper Arduino library
* (https://github.com/teemuatlut/TMC2208Stepper).
//#define HAVE_TMC2208
#if ENABLED(HAVE_TMC2130) || ENABLED(HAVE_TMC2208)
// CHOOSE YOUR MOTORS HERE, THIS IS MANDATORY
#define X_IS_TMC2130
//#define X2_IS_TMC2130
#define Y_IS_TMC2130
//#define Y2_IS_TMC2130
//#define Z_IS_TMC2130
//#define Z2_IS_TMC2130
//#define E0_IS_TMC2130
//#define E1_IS_TMC2130
//#define E2_IS_TMC2130
//#define E3_IS_TMC2130
//#define E4_IS_TMC2130
//#define X_IS_TMC2208
//#define X2_IS_TMC2208
//#define Y_IS_TMC2208
//#define Y2_IS_TMC2208
//#define Z_IS_TMC2208
//#define Z2_IS_TMC2208
//#define E0_IS_TMC2208
//#define E1_IS_TMC2208
//#define E2_IS_TMC2208
//#define E3_IS_TMC2208
//#define E4_IS_TMC2208
* Stepper driver settings
#define R_SENSE 0.11 // R_sense resistor for SilentStepStick2130
#define HOLD_MULTIPLIER 0.5 // Scales down the holding current from run current
#define INTERPOLATE 1 // Interpolate X/Y/Z_MICROSTEPS to 256
#define X_CURRENT 800 // rms current in mA. Multiply by 1.41 for peak current.
#define X_MICROSTEPS 16 // 0..256
#define Y_CURRENT 800
#define Y_MICROSTEPS 16
//#define Z_CURRENT 800
//#define Z_MICROSTEPS 16
//#define X2_CURRENT 800
//#define X2_MICROSTEPS 16
//#define Y2_CURRENT 800
//#define Y2_MICROSTEPS 16
//#define Z2_CURRENT 800
//#define Z2_MICROSTEPS 16
//#define E0_CURRENT 800
//#define E0_MICROSTEPS 16
//#define E1_CURRENT 800
//#define E1_MICROSTEPS 16
//#define E2_CURRENT 800
//#define E2_MICROSTEPS 16
//#define E3_CURRENT 800
//#define E3_MICROSTEPS 16
//#define E4_CURRENT 800
//#define E4_MICROSTEPS 16
* Use Trinamic's ultra quiet stepping mode.
* When disabled, Marlin will use spreadCycle stepping mode.
#define STEALTHCHOP
* Monitor Trinamic TMC2130 and TMC2208 drivers for error conditions,
* like overtemperature and short to ground. TMC2208 requires hardware serial.
* In the case of overtemperature Marlin can decrease the driver current until error condition clears.
* Other detected conditions can be used to stop the current print.
* Relevant g-codes:
* M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given.
* M911 - Report stepper driver overtemperature pre-warn condition.
* M912 - Clear stepper driver overtemperature pre-warn condition flag.
* M122 S0/1 - Report driver parameters (Requires TMC_DEBUG)
#define MONITOR_DRIVER_STATUS
#if ENABLED(MONITOR_DRIVER_STATUS)
#define CURRENT_STEP_DOWN 50 // [mA]
#define REPORT_CURRENT_CHANGE
#define STOP_ON_ERROR
#endif
* The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD.
* This mode allows for faster movements at the expense of higher noise levels.
* STEALTHCHOP needs to be enabled.
* M913 X/Y/Z/E to live tune the setting
#define HYBRID_THRESHOLD
#define X_HYBRID_THRESHOLD 100 // [mm/s]
#define X2_HYBRID_THRESHOLD 100
#define Y_HYBRID_THRESHOLD 100
#define Y2_HYBRID_THRESHOLD 100
#define Z_HYBRID_THRESHOLD 3
#define Z2_HYBRID_THRESHOLD 3
#define E0_HYBRID_THRESHOLD 30
#define E1_HYBRID_THRESHOLD 30
#define E2_HYBRID_THRESHOLD 30
#define E3_HYBRID_THRESHOLD 30
#define E4_HYBRID_THRESHOLD 30
* Use stallGuard2 to sense an obstacle and trigger an endstop.
* You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin.
* X and Y homing will always be done in spreadCycle mode.
* X/Y_HOMING_SENSITIVITY is used for tuning the trigger sensitivity.
* Higher values make the system LESS sensitive.
* Lower value make the system MORE sensitive.
* Too low values can lead to false positives, while too high values will collide the axis without triggering.
* It is advised to set X/Y_HOME_BUMP_MM to 0.
* M914 X/Y to live tune the setting
#define SENSORLESS_HOMING // TMC2130 only
#if ENABLED(SENSORLESS_HOMING)
#define X_HOMING_SENSITIVITY 8
#define Y_HOMING_SENSITIVITY 8
#define X_HOME_BUMP_MM 0
#define Y_HOME_BUMP_MM 0
#endif
* Enable M122 debugging command for TMC stepper drivers.
* M122 S0/1 will enable continous reporting.
#define TMC_DEBUG
* You can set your own advanced settings by filling in predefined functions.
* A list of available functions can be found on the library github page
* [github.com]
* [github.com]
* Example:
* #define TMC_ADV() { \
* stepperX.diag0_temp_prewarn(1); \
* stepperY.interpolate(0); \
#define TMC_ADV() { }
#endif // TMC2130 || TMC2208
Re: TMC2130 Overtemperature Warning (0mA) 07. January 2019 08:17 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 448 |
#define X_HYBRID_THRESHOLD 100 // [mm/s] #define X2_HYBRID_THRESHOLD 100 #define Y_HYBRID_THRESHOLD 100 #define Y2_HYBRID_THRESHOLD 100
